My gearbox
Discussion in 'UK Motorcycles' started by Paul Carmichael, Jan 18, 2010.
  1. Worn gearbox dogs.
    Break it for parts. That's a seriously expensive job.
    Niall Rowan, sometime French Runner, had it happen on second gear on his
    ZX9R. I gave him the advice I've just given you. He found a dealer who
    reckoned that it could be done for about £450-500.
    In theory, you just remove the engine, remove the saide casings, clutch,
    ec, invert the engine, remove the botom crankcase half, remove and
    replace the offending gears, and then reverse the procedure.
    In fact, there are *always* other things that need doing. My guess was
    that t would cost him about £1200 and IIRC I was only £100 out.
    The Older Gentleman, Jan 19, 2010
  2. In view of my confession, ie; if I use the clutch it doesn't happen,
    would that affect your diagnosis?
    Oh dear.
    Too late to nige it out as perfect, now I've announced it to the world.
    Haynes says 4 spanners. I was a motor mechanic - albeit 25 years ago -
    and I still have my circlip pliers. Suicide mission?
    Paul Carmichael, Jan 19, 2010
  3. Paul Carmichael
    'Hog Guest
    Find a **** dealer nobody likes. Trade it in. It becomes their problem.
    If it changes gear ok with the clutch the tame droid who takes it round the
    block wont notice.
    Don't do it to a good dealership or an individual though.
    And get a decent bike while you are at it.
    'Hog, Jan 19, 2010
  4. Paul Carmichael
    'Hog Guest
    Does it have bottom frame rails? If not remove the fairing, exhaust and
    fluids then string the bike upside down from the rims with a couple of
    hoists and 4 lads. Lift it right up from the rear until vertical, start on
    the front then lower the rear to working height.
    It sounds insane but getting all the peripherals and electrics off a bike
    like that is a feckin nightmare.
    'Hog, Jan 19, 2010
  5. What, one with character? At least the old thing just started pretty much
    straight away after sitting on the patio without moving for 6 months -
    the last 2 of which it hasn't stopped raining.
  6. Paul Carmichael
    'Hog Guest
    I meant something that wouldn't suffer expensive failures ;o)
    And maybe something with just a flyscreen, it being so warm down there much
    of the time.
    'Hog, Jan 19, 2010
  7. Paul Carmichael
    Two hours tops to get the engine out of pretty much any bike if you're
    handy with spanners. You can do most of the work alone and only need
    asistance for the final lifting out onto a crate or carpetted floor.
    I should know, I've done it enough times.
    Lozzo, Jan 19, 2010
  8. So, Loz, fancy a weekend down south?
  9. Paul Carmichael
    'Hog Guest
    Shhhhhhhhush
    'Hog, Jan 19, 2010
  10. Paul Carmichael
    I can't I'm afraid. Currently laid up with quite a problematic kidney
    disorder. It's so bad that I could only spend 10 minutes out in the
    garage moving my toolchest into position beside my bench today before I
    was too knackered to do anything else, and it's on fucking great
    castors.
    Lozzo, Jan 19, 2010
  11. Paul Carmichael
    Cab Guest
    BTW, I might be in your neck of the woods at the end of Feb. Fancy a
    cerveza?
    Cab, Jan 19, 2010
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Actually, that reminds me.
    If this gets worse, **** the bikes, put me down for your toolchest.
    Wicked Uncle Nigel, Jan 19, 2010
  13. Paul Carmichael
    That subject is a bit close to home at the mo. I was writing my will
    the other day and I cannot for the life of me think who I should leave
    the tools/boxes to. Caz has a Draper top chest that I bought from a
    mate many years ago, and that has all the tools she'll ever need to
    maintain her bikes at home to the level she's capable of - most of
    those tools I bought for her, so there is a sentimental value attached
    to them and she really does look after her stuff. The two other girls
    have no interest in spannering at all, and nor does my son. I can't
    abide my nephews, with the exception of one of them, and he has no
    interest in spannering either.
    So now it's down to choosing between friends, or the estate disposing
    of them and pocketting the cash.
    Lozzo, Jan 19, 2010
  14. Paul Carmichael
    'Hog Guest
    The obvious Geek to leave your tools to is Bee
    'Hog, Jan 20, 2010
  15. That just takes the buscuit. You've turned my rare, on topic, gearbox
    thread into a last will and testament.
    Paul Carmichael, Jan 20, 2010
  16. Paul Carmichael
    But he's had to scribble out the "Being of sound mind..." bit at the
    top.
    CT, Jan 20, 2010
  17. Being a mechanically unsympathetic mong?
    Grimly Curmudgeon, Jan 20, 2010
  18. Are you two going to let me in on what the hell you're on about? Or does
    it not concern me?
  19. Oh, I see. Having seen the issue debated many times over the years, and
    the frequent assertions that smooth changes without the clutch are
    actually better for the bike, I didn't know that it was now official that
    clutchless changes are bad.
    But you're probably right at least in as much as *my* clutchless changes
    have been on occasion less than perfect.
    I shall consider myself ribbed then.
    One thing that noone's answered though - how comes if I use the clutch to
    change up now, it doesn't jump out of gear? Surely, it's either in gear
    or it isn't? Once I've got through this mountain of work, I'll start
    taking things to bits.
  20. Paul Carmichael
    crn Guest
    Clumsy cnut.
    Just learn to use the clutch and the bike will last you a year or two
    longer. Change the gearbox oil to minimise the damage that you have
    already done.
    crn, Jan 20, 2010
