My gearbox
Discussion in 'UK Motorcycles' started by Paul Carmichael, Jan 18, 2010.
  1. Paul Carmichael
    crn Guest
    Obviously the cogs are not fully engaging unless you use the clutch.
    crn, Jan 20, 2010
    #41
  2. Paul Carmichael
    Does this mean he's posted something right?
    platypus, Jan 20, 2010
    #42
  3. Paul Carmichael
    "correctly executed"
    Hmm.
    #43
  4. Paul Carmichael
    crn Guest
    Correct clutchless upchanges are a skill requiring mechanical sympathy.
    Done with typical clumsiness they are going to cause damage, done by
    experts they may be relatively harmless.
    Interestingly, the Jawa 350 had a clever mechanism linking the gearchange
    to the clutch so "clutchless" changes activated the clutch.
    crn, Jan 20, 2010
    #44
  5. Ukrm can form an orderly queue behind me.
    The Older Gentleman, Jan 20, 2010
    #45
  6. Paul Carmichael
    I remember that. Didn't the CZ 125/175 singles have something the same?
    #46
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    Ahem. ITYF I was first.
    Wicked Uncle Nigel, Jan 20, 2010
    #47
  8. So did some horrible old Triumphs. At least they didn't also use the
    gear lever as the kickstarter, as Jawa did.
    #48
  9. They sure did. With practice you could pull away while scratching your
    arse with your left hand.
    #49
  10. Paul Carmichael
    You could also inadvertently start them in reverse. DAMHIK,IJK,OK?
    #50
  11. Paul Carmichael
    Ben Guest
    You've obviously never ridden a modern Suzuki gearbox. Clutch or
    clutchless, hamfisted or not, they've perfectly smooth.
    Ben, Jan 20, 2010
    #51
  12. Paul Carmichael
    Point of order WUN; you only wanted the toolchests, you made no mention
    of the contents.
    Lozzo, Jan 20, 2010
    #52
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Bugger!
    Oh well, that'll have to do.
    (fine print: obviously, I hope you live for ever, and have a long happy
    and productive life. I would never wish to profit from another's
    misfortune, in any way... {cont. P. 94})
    #53
  14. <smirks, rub hands, and does Google search for contract killers>
    The Older Gentleman, Jan 21, 2010
    #54
  15. Paul Carmichael
    IM(admittedly fairly limited)E, this isn't restricted to modern Suzuki
    gearboxes: Suzuki have always made the slickest boxes.
    So slick that they tempt HAG types that are accustomed to inferior
    products to try clutchless downchanges - they aren't so fucking slick
    after that sort of abuse, I can tell you.
    Pip, Jan 21, 2010
    #55
  16. Paul Carmichael
    'Hog Guest
    'Hog, Jan 21, 2010
    #56
  17. Who does it right all the time?
    It doesn't take many fuffed changes to do the damage and I'm firmly of
    the opinion that lots of 'correctly executed' changes will do similar
    damage.
    Grimly Curmudgeon, Jan 21, 2010
    #57
  18. Prescience and foresight being the order of the day in Czechoslovakia,
    the designers knew many of those bikes would be spending a lot of their
    time off the road.
    #58
  19. Paul Carmichael
    'Hog Guest
    Hmmm I almost always change up from 3rd gear on without the clutch and
    always have. I've never actually had a selector fork failure or problem.
    With SOBoxers it's the smoothest way to go up through the box.
    'Hog, Jan 21, 2010
    #59
  20. <Looks at sig and mutters darkly>
    #60
