MythTV VS TopupTV
Discussion in 'UK Motorcycles' started by Doki, Jun 11, 2008.
  1. Doki
    Doki Guest
    I've spotted a TopupTV PVR thing in the supermarket at £80, which is made by
    Thomson. I've also got a Compaq PC which I was planning to make into a
    MythTV box (IIRC it's a P4 1.7 with 512 megs of RAM). By my reckoning, it's
    going to cost around £80-100 to get that working as a MythTV machine, as
    I'll need a Hauppage 350 and a videocard with S-video out, unless I can
    scrounge one, along with a linux compatable Wifi card for it.
    Now, am I going to be better off with the ready built TopupTV machine or
    the MythTV? I know I'll be able to watch / listen to all the stuff I've
    downloaded with MythTV, but I'm not sure how much aggro and hassle it'll be
    to setup - I've currently got Ubuntu working on the machine so I know it
    works OK with Linux, but I've never played with MythTV. Does it work solidly
    and reliably or is it like so many other open source good ideas which only
    work some of the time?
    Doki, Jun 11, 2008
  2. Doki
    cat Guest
    Doki wrote:
    <snip>
    settopbox for girls who want to watch hollyoaks.
    myth for boys who like to tinker with things all the FUCKING TIME.
    My mythbox has dual tuners and a feck off hard disk, it does all my
    torrenting and stuff too. It's fantastic at what it does and since I
    spent a full year tweaking it to perfection, I now don't watch TV at all.
    Ymmv. (my point is that you'll probably never be content with the mythtv
    setup and it's SO configurable that you'd be better off viewing it as a
    hobby rather than an appliance)
    cat, Jun 11, 2008
  3. Doki
    TD Guest
    No. You don't need a 350 - any DVB-R PCI card that works with Linux will do.
    Why do you need s-video out - what display device will you be using on the
    frontend? Also, why the WiFi? How are you going to set up the network?
    Once setup, solid and reliable. 0.22 is a classy release - I never worry
    about a thing. If you've done the "hard bit" i.e. installing Linux, you'd be
    crazy not to give it a go. The documentation wiki[1] and mailing list / IRC
    support are both excellent.
    [1] Read it before you dive in to avoid pain later.
    TD
    1991 VFR400R NC30 (black and red)
    2001 ZX-9R (red and black)
    1999 M5 (neither black nor red)
    Missing: SOB, Unreliable Italian exotica, Lardy tourer
    TD, Jun 11, 2008
  4. Doki
    Doki Guest
    Is the 350 not *the* twin tuner DVB card that works with linux? The TopupTV
    thing is twin tuner.
    Wifi so that I can access music and films over the network. Manually
    transferring everything to IDE hard drives is not really a practical option
    for me. Network would run through SAMBA would it not?
    IME installing linux is the easy bit, but I have done it a lot of times.
    It's making everything work right that's the problem.
    Doki, Jun 11, 2008
  5. Doki
    Doki Guest
    A telly. Not a plasma, not an LCD, just a telly.
    Doki, Jun 11, 2008
  6. Doki
    TD Guest
    No. It's an old POS. http://mythtv.org/wiki/index.php/Hauppauge_PVR-350
    Have a look at http://tinyurl.com/6fl79q. You can gauge compatibility via
    judicious searching of http://www.linuxtv.org/wiki/index.php/Main_Page and
    searching the web for the card model and Linux.
    I have a couple of these: http://tinyurl.com/5ujqhj. They work fine, see
    http://tinyurl.com/53thzc. I don't think they made dual-tuner PCI cards when
    I set my box up.
    If you want twin tuners on one card, you could try http://tinyurl.com/47gbqk,
    which is well supported (see http://tinyurl.com/2unn68).
    That's fair enough. You only need Samba if you want to access stuff directly
    from the filesystem, using Windows networking. Myth has its own networking
    infrastructure, assuming that (a) what you want to access is imported into (or
    recorded by) Myth, and (b) you have the Myth frontend installed on all client
    machines.
    Most important question - what OS will you be running on the frontend (client)
    machines? If Windows, see http://tinyurl.com/56bmzm.
    Piece of piss. ;)
    TD
    TD, Jun 12, 2008
  7. Doki
    TD Guest
    What size? You might want to consider a VGA->RGB Scart converter, if the TV
    is a reasonable size and you are bothered about picture quality, it might be
    worth it. http://tinyurl.com/5eu3vy looks interesting, cheaper ones don't
    appear to support 16:9 resolutions, but of course it doesn't matter if your TV
    is 4:3.
    TD
    TD, Jun 12, 2008
  8. Doki
    Ben Guest
    802.11n wifi is what you want. I've got a complete network now and
    it's rock solid for streaming everything including full dvd and hd.
    Ben, Jun 12, 2008
  9. Doki
    Doki Guest
    TBH the idea was not to stream stuff but to copy stuff over via the network.
    Perhaps stream music.
    Doki, Jun 13, 2008
  10. Doki
    Doki Guest
    Thinking of a combined front and back box under the telly. All the other
    machines in the house will be windows, hence samba.
    Doki, Jun 13, 2008
  11. Doki
    Doki Guest
    I want something that I can set up and have just working. It needn't be
    simple as simple to set up, but it needs to work solidly and be usable by my
    Girlfriend. The only reason I ever use Linux is when I want something that I
    can just set up and leave (ie, PC for parents etc.) whereas a Windows box
    will start screaming for some attention sooner or later. Day to day I'd
    rather use Windows, but it needs a lot of TLC to keep it running sweetly.
    Doki, Jun 13, 2008
  12. Doki
    TD Guest
    Was that a conscious decision or did you just not realise that Myth gives you
    "streamability"? Of course it's down to you, but streaming is usually
    preferable, the data is more managable and efficient when it's in one place.
    TD
    TD, Jun 13, 2008
  13. Doki
    TD Guest
    So check out the link.
    Also, if you want to share music over the network without going to filesystem
    level, you might want to investigate the daap protocol. I know enough about
    it to know that it lets me listen to music from anywhere on my network using
    Rhythmbox. I believe that on Windows, iTunes supports daap, and I'm sure
    there are other players as well. On the server you would need to install
    mt-daapd.
    I personally don't have all my music in Myth, but that's more for legacy
    reasons than a conscious decision.
    TD
    TD, Jun 13, 2008
  14. Doki
    Doki Guest
    I don't want to have to have 2 PCs on just to listen to music in the living
    room. The way I see it is that the MythTV box will need to be on all the
    time, whereas my other PCs don't. It makes sense to put the stuff that
    you'll want to access from all the PCs on the one that's on all the time.
    Networking seems like the easiest option TBH.
    Doki, Jun 13, 2008
  15. Doki
    TD Guest
    Are we talking at cross-purposes? I never said don't use a network. I agree
    with what you say above.
    TD
    TD, Jun 13, 2008
  16. Doki
    Doki Guest
    Networking VS streaming. I got the gist that streaming requires a MythTV
    frontend on the receiving machine, whereas a SAMBA network would just be a
    simple list of files to go through.
    Doki, Jun 13, 2008
  17. Doki
    TD Guest
    Let's call it copying vs streaming, otherwise I get confused, as both work on
    the network. I don't see that copying is better in any way, unless your
    network is flaky.
    Did you read the link with all the different options for Windows frontends?
    What files in particular? Myth is not really designed for its recordings to
    be shared at file system level. I don't think it saves recordings with
    human-readable names. And do you /really/ want to set up Samba? Hence the
    varied methods of viewing, in the link above. Also, check out the excellent
    Mythweb. http://www.mythtv.org/wiki/index.php/Mythweb and
    http://www.mythtv.org/wiki/index.php/Play_Recordings_On_Windows_From_MythWeb.
    TD
    TD, Jun 13, 2008
  18. Doki
    TD Guest
    You get out what you put in - mythweb is generally a Good Thing - I wouldn't
    want to have a Myth box without it.
    TD
    TD, Jun 13, 2008
  19. Doki
    Jimac Guest
    I've got the TopupTV/Thomson box. If all you want is a plug-and-play box
    with twin tuners, EPG, series link, etc. then it'll do what you want. It
    works fine and is very convenient.
    Jimac, Jun 13, 2008
  20. Doki
    Doki Guest
    I meant "streaming" in the sense that you're not doing the following
    steps
    1. Copy file to local hard drive
    2. Wait about 10 minutes for this to complete because TV is about 1GB
    per hour
    4. Watch show[/QUOTE]
    No, not that.
    Yes, that.
    Doki, Jun 14, 2008
Similar Threads
Loading...
