[QUOTE="TD"] Let's call it copying vs streaming, otherwise I get confused, as both work on the network. I don't see that copying is better in any way, unless your network is flaky.[/QUOTE] Ah. I just meant navigating to the folder and double clicking, so I suppose it'd be streaming. To my mind, streaming implies some odd special player software. Which it looks like may be the easiest option. [QUOTE] Did you read the link with all the different options for Windows frontends?[/QUOTE] I got as far as the bit where it said "It doesn't really work". If someone's admitting that on the documentation for an open source project then what they actually mean is "You have no chance of making this work, even if you ring up every programmer you know and quiz them for hours". I've now read it again, and it looks doable. Not really a windows frontend, more of a special media player for windows. [QUOTE] What files in particular? Myth is not really designed for its recordings to be shared at file system level. I don't think it saves recordings with human-readable names. And do you /really/ want to set up Samba? Hence the varied methods of viewing, in the link above. Also, check out the excellent Mythweb. [URL]http://www.mythtv.org/wiki/index.php/Mythweb[/URL] and [URL]http://www.mythtv.org/wiki/index.php/Play_Recordings_On_Windows_From_MythWeb[/URL].[/QUOTE] Music mainly. I can watch video on the telly. But I'd want all my music on the mythbox too. I will read. Once I've done the brakes.
