need input on swingarm mods
Discussion in 'Motorcycle Technical Discussion' started by messenger1, May 4, 2004.
  1. messenger1
    messenger1 Guest
    greetings all, as I've received great advice here in the past I have yet
    another question. I am fitting a 1987 ZX swingarm into my 1984 KZ frame. The
    replacement swingarm is approx 1/4" too wide overall. My original idea was
    to run it into a machine shop and have it milled down 1/8" on either end of
    the pivot bolt shaft and then replace the dust caps with simple nylon
    washers. Is this necessary or can I make do by simply grinding off the 1/8"
    with a die or hand grinder? Just wondering how specific these tolerances
    need to be as doing it by hand will probably result in a less than perfectly
    square cut where the arm press's against the inside of the frame at both
    sides. Am I over thinking this and is it really not a critical tolerance?
    Tom B
  2. messenger1
    Mark Olson Guest
    I narrowed the width of the pivot area on my '77 KZ650B1 swingarm when
    I converted it from a bushing to needle bearings as were used on the
    '81 KZ750E2. I happened to use a surface grinder, so the sides were
    very flat and parallel, but if you are careful, there is no reason why
    you cannot acheive a good result. As I remember it, the frame normally
    had to be sprung outward slightly to fit the swingarm, so it was always
    under a little tension, which made sure there was no side play.
    I would advise using power tools only with great care, do the final
    removal of metal with a fine file using light strokes.
    Why don't you want to use dust caps? I would advise keeping them,
    to keep water out.
    Mark Olson, May 4, 2004
  3. messenger1
    messenger1 Guest
    thanks for the reply Mark. The caps fit inside the swingarm, the area I
    remove will be approx the entire recessed portion on each side that the
    caps fit into.
    Tom B
    84 KZ 750/1105/ZX7 project
    89 ZX6R
    83 GPz550
