never seen that before
Discussion in 'UK Motorcycles' started by Pip Luscher, Jun 4, 2006.
  1. Pip Luscher
    A recently-installed chain on the Tuono is whipping... sideways.
    How did I find out? Well it's /just/ clipping the edge of the tyre,
    fortunately just on the edge of the treads.There's a series of shallow
    nibbles all round the tyre. Normal chain run is quite close to the
    tyre, about 3-4mm, but I have to push the chain quite firmly across to
    make it contact the tyre.
    It ain't a bent back sprocket, for two reasons: the nibbles are all
    round the tyre, not just one area, and I've checked the sprocket by
    holding a pointer against the swing arm, that just brushes the
    sprocket: it's even all the way round.
    I haven't checked the front sprocket specifically for trueness but it
    would have to be seriously bent to have this effect, and looked fine
    when I installed it. It's a substantial machined item made by Renthal
    with a wide splined hub - I doubt the problem's there.
    I've double and triple checked the assembly against the Aprilia
    workshop manual (strictly the RSV Mille one): it's correct. It's
    impossible to get the left & right spacers wrong as they're identical.
    I've double-checked the wheel alignment, that seems to be pretty much
    spot on.
    If I look along the chain line and spin the rear wheel then the chain
    appears to snake slightly. At present the chain, a heavy-duty X-ring
    jobbie, a Japanese make I've never heard of before (and can't remember
    now), is the prime suspect.
    Apart from this issue and a minor niggle with the LH mirror folding
    back under hard acceleration above 70mph or so, the Tuono is huge,
    huge, HUGE fun to ride.
  2. Pip Luscher
    Eiron Guest
    My GSXR1100 is like that. It was close when new and rubs now.
    My guess is that a modern Dunlop 180/55 tyre is a bit wider than
    a 1990 Michelin 180/55. Perhaps I'll try a 170/60 next time.
    Or I could offset the sprockets by turning the front sprocket over
    and shimming the rear.
    Eiron, Jun 5, 2006
