New Rider
Discussion in 'UK Motorcycles' started by Big Dov, Jan 14, 2006.
  1. Big Dov
    Big Dov Guest
    Hello
    Hi I have just passed my cbt. Although not a youngster anymore, I'm
    struggling with slowing down approaching corners.
    The problem is, as I approach I start to slow down and change down the
    gears. There's where the problem starts, what gear am I in, if the junction
    is clear and I don't have to stop. I would like to be in second and continue
    around the bend. Usually I find myself in first and the bike slows to much.
    Apart from counting gears which I didn't think was a good idea, what is the
    proper way to do this?
    I'm sure all you experienced bikers out there, will have a wealth of
    information you can pass on to me, just be nice please.
    Thank you
  2. Big Dov
    BGN Guest
    Over time you'll understand what gear you're in just by listening to
    the sound of the engine. As long as the engine is in its power range
    you'll be fine.
    I think what you're doing is approaching the corner in 4th gear or
    suchlike, pulling in the clutch and kicking down a few gears and then
    releasing the clutch. Instead of doing that try this:
    Upon approaching a corner pull in the clutch, change down a gear,
    release the clutch. As you slow down a bit more, change down to the
    next gear, release clutch. Slow down a bit more, change down, release
    clutch... It might feel a bit odd at first but it's a good way to
    change down as you're always going to be in a gear with some oomph and
    if the junction is clear then you can just zoom off. The same is good
    when approaching roundabouts and in many other situations.
    After you've got used to doing that you could try opening the throttle
    a little bit as you release the clutch which will make the bite
    smoother.
    DFC.
    BGN, Jan 14, 2006
  3. Big Dov
    Are you letting out the clutch between each down change? This would
    help you get a feel for which gear you were in and stop you from being
    in the wrong gear as often. You shouldn't worry about whether you're
    in 1st, 2nd or 3rd as long as the bike feels right and you're neither
    revving **** out of it or letting it bog down due to not enough revs.
    Things will be easier when the roads aren't as greasy and it isn't as
    cold and miserable.
    Andy Bonwick, Jan 14, 2006
  4. Big Dov
    Big Dov Guest
    Hello
    Thanks you guys, for your help, I must admit I'm not letting the clutch out
    through dropping down the gears. The corner seems to come up so fast and
    there seems so much else to do at the same time. I've been driving cars and
    vans for years, but this is so much different. I think I'll try slowing well
    before the junction, but on the same hand I don't want to hold people up.
    Thanks again
  5. Big Dov
    BGN Guest
    I suppose you're just approaching junctions in a speedy fashion. This
    isn't always a bad thing, but do try to slow it down a bit at first,
    especially as you're a bit new to it. Start to pull in the front
    brake and gradually increase the pressure as you slow down, do
    something similar with the rear brake to in a way that feels
    comfortable.
    Also: Who cares if you delay the journey of a car behind by five
    seconds? You're new to this bike lark - you've got L-Plates - ****
    the cars behind for now. While you're getting worried about those
    behind at junctions you're being distracted from pushing pulling
    twisting and turning controls on the bike. I'm sure they'll overtake
    you if they're in that much of a hurry. Just remember to Defend Your
    Space.
    BGN, Jan 14, 2006
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Big Dov
    Heh, it is that. You definitely want to be changing down only one gear
    at a time, using the engine braking to help the bike slow down. Aim to
    be entering the corner with the revs about halfway though their usable
    range (not bogging down, not screaming the nuts off it).
    I *guess* that your cornering speeds are probably too low at this stage.
    Believe it or not, that makes it harder. Cornering speeds being to high
    makes it hurtier. Decisions, decisions...
    Whereabouts are you? Maybe someone from here can ride a few miles with
    you to offer advice.
    Wicked Uncle Nigel, Jan 14, 2006
  7. Big Dov
    Big Dov emerged from their own little world to say
    I found this a pain too when learning on a riding school 2 stroke NS125R
    many years ago.
    I decided I needed more practice before my 2nd attempt at the test. I
    bought a nice 4 stroke Suzuki GS125ES which had a nice LCD display to tell
    you what gear you were in. I'm sure this hastened my learning.
    wessie, Jan 14, 2006
  8. Big Dov
    BGN Guest
    UKRM Grooming Service?
    BGN, Jan 14, 2006
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, BGN
    I suspect he's more your type, ducky.
  10. Big Dov
    muddy Guest
    [snip sensible answers]
    WTF is wrong with you lot today? Where's the piss takes? Where's the the
    get your knee down you fucking poof answers?
    Cunts, you've all gone soft.
    muddy, Jan 14, 2006
  11. Big Dov
    Big Dov Guest
    Hello
    Thanks again guys. I'm in Scotland, no jokes please. I'm going on Monday to
    sit my Das all day Monday on a 125cc. Then Tuesday on 500cc, anyone I've
    spoken to seems to think that the 500's are so much easier to control. I'm
    going to slow it down on approach to junctions, corners. I just seem to get
    into a bit of a panic. I think I'll take yoga before Monday to try and
    relax, he he.
    Thanks for all your advice
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, muddy
    <stares at feet>
    Yes Mr Muddy, sir. S*rry Mr Muddy, sir.
    <thinks>
    **** you, you Septic ****! Who the **** do you think you are? Barging in
    here with your M16, shouting "Hut, hut, hut!"? You probably hit the
    wrong newsfroup anyway!
    FYYFFFFFFF.
    Note to OP:
    Apparently you're a fucking poof, piss off until you can get your knee
    down.
    HTH.
  13. Big Dov
    BGN emerged from their own little world to say
    He's doing DAS & in Scotland. Over 21 then. Butter him up for your JOGLE
    trip just in case the other one doesn't pass his test....
  14. Big Dov
    BGN Guest
    Unless you're 3'6" tall.
    Ooh, drama.
    Replace "yoga" with "chain smoking"
    BGN, Jan 14, 2006
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Big Dov
    Being in Scotland is never a joke.
  16. Big Dov
    muddy Guest
    More tut, tut than hut, hut okay? While I hold a merkan passport, Sir
    Walter claimed my bit of CA for the Queen and she's not given it back as
    far as I know. So, ya boo sucks and all that.
    You can get a ball cap with that embroidered on it you know.
    Too right dammit! Get a ZX10-R too.
    muddy, Jan 14, 2006
  17. Big Dov
    Catman Guest
    Personally, though I have a pretty good feel of what gear I'm in, I still
    tend to count down the box.
    You might want to read the FAQ as well, particularly the parts about posting
    style.
    Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 OMF#22
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Jan 14, 2006
  18. Big Dov
    Catman Guest
    Wot he said, with bells on
  19. Big Dov
    Catman Guest
    IME they *are*
    It'll pass, don't worry. I'm no riding god, and I still sometimes worry.
    NAHAY?
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Catman
    I disagree. The OP clearly recognises that he has a problem. He should
    practice away from traffic until the problem is resolved.
    I mean, if the **** was fannying around in front of me, I'd probably get
    quite shouty.
