New speed traps
Discussion in 'Classic Motorcycles' started by RG, Dec 3, 2003.
  1. RG
    RG Guest
    The following was mailed to the staff of a large group of solicitors near
    Manchester yesterday and I thought it might be worth a post.
    PLEASE ADVISE ALL STAFF.
    The new electronic signs on the M6 were switched on
    this Tuesday. The bad news is that they are rigged with the SPECS speed
    cameras. This probably applies to all the new signs being installed on the
    M62, M60 and M56.
    SPECS is a computer-camera based system. As you go past the sign a digital
    camera reads your number plate. When you go past the next sign your number
    plate is read again. The computer 'knows' how far apart the signs are so it
    can work out your average speed between the two, or three or four. The
    system is fully automatic and will issue a ticket without any form of human
    intervention. It does this for every single vehicle that passes. You will
    not know you have been caught as the cameras don't flash. They work 24/7,
    365 days a year, and theoretically, there's absolutely no limit on the
    number of tickets that the system can issue. The whole section of the M6
    between Knutsford and Preston is wired, both ways. The system is set to
    trigger a ticket at 78MPH. (Don't take this as a guarantee) Radar detectors
    will be of no use as SPECS is entirely passive, there is no laser beam to
    detect. Be warned and spread the news!
    Roger
    RG, Dec 3, 2003
  2. RG
    Klaatu Guest
    FFS - Not Again !
    Klaatu, Dec 3, 2003
  3. RG
    YTC#1 Guest
    Its bollocks and people with more sense should know it is, we had this at
    work and I had to point out all the old rumours from down south, and of
    course the fact the signs have been on for ages anyway.
    YTC#1, Dec 3, 2003
  4. RG
    Steve Parry Guest
    In
    anyway.
    Perhaps its all a conspiracy :eek:) .....
    Maybe plod are sending out the fake emails so that when they do
    fit the specs camereas no one will believe the warnings ! ;o)
    Tons of income for the "cost" of a fake email ... result ..
    Steve Parry
    http://www.gwynfryn.co.uk
    http://wrexhamseals.tripod.com
    Steve Parry, Dec 3, 2003
  5. RG
    What depresses me is that it will most likely become fact. Why are we
    drifting towards this fucked up nanny state?
    Hog, Dec 3, 2003
  6. RG
    RG Guest
    I had a trip over that way a few of days ago, before the email surfaced, and
    clocked all the new, partially constructed gantry signs - and I have to
    admit they appeared to be slotting cameras in/on them. They looked like the
    type I'd seen previously around Northampton.
    Roger
    RG, Dec 3, 2003
  7. RG
    YTC#1 Guest
    Someone else in the office said something similar, but I will have a good
    gander next time I pass
    YTC#1, Dec 3, 2003
  8. RG
    Steve Parry Guest
    In
    Cos its another way to pull money out of the public :eek:(
    Steve Parry
  9. RG
    YTC#1 Guest
    Sounds reasonable.
    YTC#1, Dec 3, 2003
  10. RG
    Guest Guest
    SPECs ones have three boxes:
    - a smallish rectangular one in the centre containing the camera
    - two even smaller ones either side horizontally, containing IR
    lamps so that the system can work at night. These lamps are also
    sometimes spherical (see
    http://www.ukspeedcameras.co.uk/cameras_main.gif).
    The _real_ ones on the M4 on the approach to the new Severn bridge are
    on the end of a gantry for the opposite carriageway, looking diagonally
    across and down at the outer two carriageways.
    I've also seen them on the M6 at roadworks, both on their own gantries
    and fitted to overhead signage (latticework gantry type). Both sets were
    fitted with fluorescent yellow identification - the camera gantries were
    painted, and the ones on signs had cloth 'flags' behind them. The ones
    on the M4 are _not_ painted specially - or at least weren't when I last
    passed them (they operate going East).
    A good picture of the own-gantry SPECS type is here:
    http://speedlimit.dreamwater.org/images/stocksbridge2.jpg
    These are the same design as the M6 ones I've seen.
    See also http://www.speedcam.co.uk/index2.htm
    (the Gatso section includes pages on other types of speed cameras with
    photographs.
    The same technology is used by Trafficmaster (they are dark blue) and
    Dept. of Transport or the Road Fund people (may even be security
    services). There's a bridge across the M6 in south Cumbria with SPECS
    type cameras mounted monitoring all three Northbound lanes, but no
    corresponding set further on. I suspect it's collecting registration
    numbers for the security services, but am probably wrong (they shouldn't
    need separate cameras!).
    In all cases the actual cameras appear to be identical models to the
    proper SPECS ones, complete with infra-red 'outriggers' on motorway
    installations.
    The Trafficmaster ones we have on the main roads around here are rather
    different - lamp post-style mounting 0- and presently they aren't used
    by the 'safety' camera partnerships. Isn't 'partnership' such a nice,
    non-threatening word?
    Ride safely...
    Regards,
    Simonm.
    Guest, Dec 3, 2003
  11. RG
    Statto Guest
    Eastbound or Westbound? I commute along there and have seen no cameras
    at all. There are signs warning that the section from the M4/M48
    junction to the Brynglas tunnels is covered by cameras, however the
    only "safety" cameras I've seen in operation were at the Magor
    junction.
    A quick check of the South Wales plod combined camera site
    www.checkyourspeed.org reveals the only fixed camera in Monmouthshire
    is on the A48 at Caerwent. Similarly, Avon and Somerset's site shows
    no motorway camera sites. I believe both police areas partcipate in
    the hypothecation scheme, so have to publish camera sites.
    Statto, Dec 3, 2003
  12. RG
    YTC#1 Guest
    This is nearly as bad as preaching OSes at me, I didn't ask for an
    explanation of camera types, I am pretty much well up on them. I was
    letting him know I was going to have a closer look at the info signs
    YTC#1, Dec 3, 2003
  13. RG
    Guest Guest
    The _one_ I know of for certain is fixed to the end of a gantry over the
    westbound carriageway. It's looking at the eastbound middle or outer
    lane. I noticed the camera first and wondered about it, the next week it
    was publicised on Points West and in the Evening Post (but no exact
    locations given, only that the system operated on the approach to the
    Severn Bridge). I think it's the only SPECS setup that Avon + Somerset
    has on the motorways. All the others I've seen have been conventional
    Gatsos, although they were rumoured to be using a video system at road
    works near Taunton Deane a few years ago (passed it lots then and saw
    traffic management but not speed cameras).
    The current ones: going East, the gantry is the first one after the fork
    where the stretch of new motorway rejoins the line of the old M4, on the
    Gloucestershire side. I haven't located any more going East, and I don't
    go over the new bridge very often (mainly nip over to see friends in
    Chepstow).
    Next time I go over, I'll come back by the new bridge and look carefully
    to see where the other end of the system is.
    Regards,
    Simonm.
    Guest, Dec 4, 2003
  14. RG
    Guest Guest
    I posted the original version of the message (about M4 cameras) some
    months back. It was done in good faith, but I was wrong and had to
    backtrack. I thought in this case it might be worth looking for pictures
    (for my own benefit), and having found some thought the URLs might be
    helpful generally.
    I didn't think there was a word of criticism in anything I wrote -
    certainly none intended.
    Regards,
    Simonm.
    Guest, Dec 4, 2003
  15. RG
    Statto Guest
    Firstly, for SPECs to work, a minimum of 2 cameras are required, as
    the system works by averaging speed between the cameras. Nextly, if
    the cameras are managed by Avon and Zummerset, then the cameras should
    be mounted on a reflective yellow background, as per all the other
    cameras in the area. I believe the same to be true at least of the
    South Wales camera partnership.
    Nextly2, the only cameras I saw on the commute on the M4, via the new
    crossing, from Sadley Broke to Cwmbran this morning were of the
    traffic monitoring variety. I suppose I could check the M48 on Monday,
    just for completeness.
    Lastly, I didn't see any warning signs to indicate the motorway is a
    speed trap area, so I would take a very sceptical view that there are
    any cameras there, especially given the Evil Post has reported on it.
    Again, I think this is a traffic management camera. I'll look more
    carefully on Monday.
    Don't worry - I'll have commuted over both bridges by then.
    Statto, Dec 4, 2003
  16. RG
    Guest Guest
    Why do you think I underlined "the _one_ camera"? I don't know where the
    other end is (yet). Yes it IS a SPECS-type camera, not a traffic
    monitoring camera.
    Possibly. When I last saw it, a couple of months ago, it was not painted
    yellow. It may be so now.
    Have a look for the other end on the way back - I suspect it's on the
    bridge itself, or very close to it. It's not on the M48, and I don't
    think there's another one further East before the M32 - but I don't
    normally go that way (usually take the M49 to Avonmouth as I live in
    West Bristol).
    Also Points West - t'other half saw the item.
    Regards,
    Simonm.
    Guest, Dec 4, 2003
  17. RG
    YTC#1 Guest
    You are worse than me for not reading stuff. I never said owt about
    critisism, more being preached at. Don't give advice when it is not asked
    for. I ,for one, hate it.
    YTC#1, Dec 4, 2003
  18. RG
    Guest Guest
    <plonk>
    Regards,
    Simonm.
    Guest, Dec 4, 2003
  19. RG
    Statto Guest
    I queried the statement that only one camera is in existence - if the
    second one has been installed, then I would have expected an
    indication of the location of the second. As it is, I didn't see any
    signs of a second SPECS camera.
    I'll try and remember to look at the gantry around the M4/M48
    junction.
    Having ploughed through the web site, the only cameras that appear to
    have a requirement for visible yellow paint are the fixed, roadside
    ones. I also seem to remember that, due to some pressure group, new
    cameras do not have to be visible. ICBATG.
    I'll keep an wary eye out for it, but as it will be dark by the time I
    leave the office, I'll be pleasantly surprised if I see anything.
    Statto, Dec 4, 2003
  20. RG
    YTC#1 Guest
    Its
    *plonk*
    YTC !
    YTC#1, Dec 4, 2003
