Newbie: Can't inflate tyre
Discussion in 'UK Motorcycles' started by patrickmang, Jul 24, 2006.
  1. patrickmang
    BGN Guest
    I'll have a look for a URL later on for one.
    BGN, Jul 26, 2006
    #41
  2. patrickmang
    He doesn't need one - he just said that all he had to do was move his
    hands. He missed the smiley off, the gurt tall tinker.
    I don't like the adapters. I have one, but don't use it. Anything
    that adds extra complication is to be avoided, imho. I'd rather
    wiggle the inflater in, bending the valve stem a bit if I have to. A
    bit of wiggling is easier overall than the chances of leaving the
    adaptor on, which leads to complications (or having it fly off and
    cause more) or having it release some of the carefully-inserted air
    when removing the bastard.
    Pip, Jul 26, 2006
    #42
  3. patrickmang
    Sir simply carries an angled tyre inflator in Sir's comprehensive
    toolkit which should accompany the fine steed on any journey of more
    that 53 feet from the doorstep.
    Hog, Jul 26, 2006
    #43
  4. patrickmang
    Sir has one, in Sir's toolkit which lives under the seat. Sir won't
    use the smegging thing, but Sir carries it for the use of colleagues
    in difficulties.
    'S funny, I check the pressures every month or so, but have only had
    to put air in the Bandit twice - once immediately after purchase, once
    last week. I don't see having a wiggle with an inflater twice a year
    as an issue.
    Pip, Jul 26, 2006
    #44
  5. patrickmang
    Naturally such a gentleman's steed would not be easily winded.
    Hog, Jul 26, 2006
    #45
  6. patrickmang
    dwb Guest
    But you're about 9ft tall.
    dwb, Jul 26, 2006
    #46
  7. patrickmang
    Eh? He's only a normal height - not even as tall as me, IIRC.[1]
    [1] ICBW, but certainly no giant.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jul 26, 2006
    #47
  8. patrickmang
    ChrisDC Guest
    You remember correctly. I'm 6ft tall with a 42 chest and 38 waist.
    So, not a lanky bugger like you.
    ChrisDC, Jul 26, 2006
    #48
  9. patrickmang
    SD Guest
    Sir needs a motorcycle upon which such devices are a standard OEM fit.
    | ___ Salad Dodger
    |_\_____/_| ..80797../..22044.../..31893.
    '^' RBR Clues: 9 Pts: 205 Miles: 797
    SD, Jul 26, 2006
    #49
  10. patrickmang
    They are hardly going to knock an ingot like the GW wheel out of balance
    Hog, Jul 26, 2006
    #50
  11. patrickmang
    I believe the term to be ... errr ... pig, actually.
    Pip, Jul 27, 2006
    #51
  12. Bend it?
    Curiously, quite a few of the petrol stations I go to appear to have
    the metal pipework 'pre-bent' the second time I go...
    Chris D
    Chris N Deuchar, Jul 27, 2006
    #52
  13. patrickmang
    Beav Guest
    A sensible solution at last.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 27, 2006
    #53
  14. patrickmang
    GaZ Guest
  15. patrickmang
    BGN Guest
    BGN, Jul 28, 2006
    #55
  16. patrickmang
    GaZ Guest
    You then use the other side of the inflator, as a truck tyre would
    GaZ, Jul 28, 2006
    #56
  17. patrickmang
    BGN Guest
    Hmm.
    BGN, Jul 28, 2006
    #57
