Newbie Question about performance
Discussion in 'UK Motorcycles' started by Vicky, Sep 27, 2007.
  1. Vicky
    Vicky Guest
    Quick question for anyone who knows anything about motorcycle
    mechanics.
    Can replacing a carburetor with one from a bigger engine increase the
    performance of the bike? A friend suggested it to me, but I'm not
    quite sure if I believe him, so a more reliable opinion would be
    nice.
    Cheers
    Vicky
    Vicky, Sep 27, 2007
  2. Vicky
    YTC#1 Guest
    Yes, get the carb off the biggest bike you can find, ones from twins go
    particularly well on fours (you just need to prise them off 2 bikes).
    At the same time go and ask your local bike dealer for a set of race jets,
    these are extra slippy and allow more fuel across them.
    YTC#1, Sep 27, 2007
  3. Vicky
    Colin Irvine Guest
    IMHO it's not something to be attempted lightly. Assuming it bolts
    straight on it'll still have to be professionally rejetted. You may
    get more top-end power, but at the expense of torque at lower revs.
    Plus you'll need to declare it to your ins. co. which may put up the
    premium.
    Colin Irvine, Sep 27, 2007
  4. Vicky
    Pete Fisher Guest
    Yes, but it depends on the bike. The simplest way to increase power on a
    Nordwest is to replace the OEM twin choke (one slide , one CV) Teikei
    carb with two Keihin CR smooth bores. They need setting up though.
    On little 50cc auto MX bikes a bigger carb it is a quick tune up route
    too as they are often very small in novice trim.
    Generally though, as others have said, I wouldn't recommend it to a
    newbie.
    | Pete Fisher at Home: |
    Pete Fisher, Sep 27, 2007
  5. Vicky
    If you're talking about a bike with one carburetor, then you're dealing with
    kit at the very bottom of the performance food chain, and, honestly, wasting
    your time. You don't say what your bike is, or whether you've got a full
    licence. If you're a learner, the quickest and most sensible route to more
    performance is to pass your test and get a bigger bike. If you've passed
    your test, you're probably limited to 33bhp anyway. If you're legal for
    full-power bikes, and you're still chuntering around on a single, you need a
    Gixxer thou. The more information we have about you, the better we can help
    you. For instance, do you take it up the arse?
    platypus, Sep 27, 2007
  6. Vicky
    Eiron Guest
    It can do.
    There was a time when a GSXR750 had bigger carbs than the GSXR1100
    so putting 1100 carbs on a 750 would make it much more rideable.
    Fitting the right size carbs is a good idea, as is using carbs that
    flow properly, eg Dellorto or Mikuni Flatslides, rather than the nasty
    CV carbs that most manufacturers use.
    You need to consider the whole engine - valve sizes, compression ratio,
    port profiles, exhaust diameter and tuning, cam timing and airbox
    as well as the carbs.
    Try a good tuning book such as
    http://www.amazon.co.uk/Four-stroke-Performance-Tuning-Practical-Guide/dp/1844253147
    What's the bike?
    And as you're a newbie, are there any pictures of you naked on the internet?
    Eiron, Sep 27, 2007
  7. Vicky
    "Speed's just a question of money. How fast can you go?"
    sweller, Sep 27, 2007
  8. Yes, but usually only as part of an overall tuning exercise.
    (for example - more fuel/air in needs a way of getting more exhaust out,
    so bigger exhaust, and you need to be able to flow the gases in and out
    faster, so bigger valves, lifted open further and longer by a different
    camshaft... you get the picture?)
    Some bikes are under-carbed, though.
    The Older Gentleman, Sep 27, 2007
  9. Vicky
    YTC#1 Guest
    Typo corrected
    YTC#1, Sep 27, 2007
  10. Vicky
    <bows>
  11. If you're talking about general-use commuter type things, yes.
    But...
    Only if the engine left the factory in a strangled state of tune.
    Fing is - most bike engines are a work of engineering art and it's
    cheaper for a factory to build many models based on the same engine but
    with a variety of power outputs than it is to make every model's engine
    different.
    In some cases you will find the bike was sold with a smaller carb than
    it was originally optimised for - perhaps to comply with power
    regulations in certain markets, or simply because it was a cooking
    version of a sportier model.
    In those instances, yes, there might be a simple power increase to be
    had by fitting bigger carbs (suitably jetted), but often you may have to
    fit different cams too. And other stuff.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Sep 27, 2007
  12. Vicky
    Vicky Guest
    LOL! There is a very fine line between information that is useful and
    relevant, and information that isn't. I think somewhere in that
    sentence, the line was driven over in a large 4x4, then reversed over
    just to make sure. Then possibly trampled over for the heck of it! :-D
    Back to the subject - thanks for all your replies. In answer to the
    more serious questions - The one I've got at the moment is mainly for
    passing my test (next month I hope!) and the insurance is cheap on it.
    Friend mentioned it as he did it to his trial bike and suggested I do
    the same. So the gist of it is that it's only really worth it with a
    twin carb then?
    Money is the real issue though - if I had enough of it I'd already
    have bought my (other) friend's bandit 600 he's selling, and it would
    be sitting in a garage waiting for me to pass my test. Alas!
    Thanks again
    Vicky
    Vicky, Sep 27, 2007
  13. Vicky
    "There is much pleasure to be gained from useless knowledge"
    - Bertrand Russell, philosopher (1872-1970)
    It's only worth doing as part as a considered tuning program. Unless you
    know what you're doing, you'll probably make things worse. Also, it's not
    worth spending time and money trying to squeeze more go out of a learner
    bike. Dick Dastardly of this parish once tuned a CG125 up to 25bhp and got
    the dyno ticket to prove it, but it blew up the next week. Concentrate on
    passing your test, then buy something more powerful.
    So it goes.
  14. Vicky
    prawn Guest
    Yes, thank you Kurt. I was expecting a contribution from ginge. Has he,
    you know, *met* someone or something?
    prawn, Sep 28, 2007
  15. Vicky
    Rich B Guest
    Wot everyone else said. If you do something as simple as putting a
    different carb on, there is a 1% chance that you will get a slight
    improvement, and a 99% chance that you will bugger everything up and
    it won't run properly until you put the original back on. Plus,
    standard bikes are almost always worth more than anything home-
    modified. From what you say, you sound as if you might be wanting to
    trade it for something bigger in the next couple of years, so keeping
    it standard is probably your best option. The difference in
    performance (assuming you improve it rather than wreck it) will be
    tiny in any case.
    Rich B, Sep 28, 2007
  16. Vicky
    Cane Guest
    Cane, Sep 29, 2007
  17. Vicky
    MikeH Guest
    MikeH, Sep 29, 2007
