nighthawk 550 electrical problem
Discussion in 'Motorcycle Technical Discussion' started by jlpridge, Sep 23, 2005.
  1. jlpridge
    jlpridge Guest
    The battery is brand new as of monday, so now I am going to star
    testing stuff. I will get a multimeter today to start on it
  2. While the possibility is quite remote, the new battery could be bad. As
    long as you hve the time, you mght as do the test just to be sure.
    You could hook up a tail light bulb in between the disconneted battery
    terminal and the battery lead. If it glows, then something is drawing
    current. Then you can start unplugging things to isolate the fault.
    pierce
    R. Pierce Butler, Sep 23, 2005
