[QUOTE="krusty"] jlpridge wrote: - I tested the rectifier this morning according to electrex's chart and the rectifier passed. Then I checked the stator according to your instructions and the three tests of the three yellow wires reveale 0.0 ohms. According to this the stator is bad right?- If you are on the R X 1 scale and you read 0.0 ohms from any yellow lead to any other yellow lead, that definitely suggests that th stator windings are shorted out. You should get *some* reading through the windings, they shouldn't read NO resistance at all. The specifications for my Yamaha FZR1000's stator is 0.16 to 0.1 ohms. For an FZR600, the specification is 0.31 to 0.37 ohms. Those are very small resistances, but at least they show the stator isn't shorted if you read some low resistance. I actually measured the resistance on my GS-1100 once, thinking there might be a problem and got 3 ohms on any output lead to any other output lead. That might have included test lead resistance, I don't remember for sure. All the diodes were 15 ohms. My charging problem turned out to be bad electrical connections. That bad connectio inside the headlight shell really tricked me. Before I would plunk down 5 for another stator unit, I would wai to see what the repair manual you ordered says about the resistance. Be sure you're on the correct setting, R X 1 and zero out the lead resistance, if that's possible on your multimeter.[/QUOTE] Krusty, I just checked the resistance on the three yellow leads fro the stator again and this time put the setting on the lowest setting Once I did this the resistance measured .5 on all three leads. Maybe i is a bad connection. But where? The symptoms are strange in that th bike is erratic. Once it warms up it will run good and allow you to re the engine above 2000 rpm. Before it is warmed you cannot exceed 200 rpms. The funny thing is that after riding it for a few minutes it goe back to the way it runs when cold. I am stumped. I have checked ever ground and they all seem well connected and clean
