No centre stand???
Discussion in 'Classic Motorcycles' started by Jim Scullion, Aug 9, 2003.
  1. Jim Scullion
    Jim Scullion Guest
    I've just bought a 1977 Kawasaki Z1000, which I'm absolutely delighted with.
    The centre stand is missing, I think to accommodate a Marshall 4:1 stainless
    exhaust.
    Does anyone know of an easy/cheap way of lifting the bike for maintenance?
    TIA
    Jim
  2. Jim Scullion
    Nigel Eaton Guest
    Using the patented Mavis Bacon "Hunt&Peck" Technique, Jim Scullion
    Sir needs a paddock stand. Available from your nearest purveyor of
    motorcycle requisites. Or one of the mail order chappies (Hein Gericke,
    M&P, etc, etc).
    Nigel
    WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20
    ZZR1100 and Enfield 500 Curry House Racer "The Basmati Rice Burner" (No , I'm
    not sure how that happened either).
    Nigel Eaton, Aug 9, 2003
  3. Jim Scullion
    Buy a paddock stand (£50?). I have successfully used a pair of car axle
    stands under the swinging arm in the past.
    I also have an old beer crate for balancing bikes on, just lift bike and
    swing it over and onto the crate. Or get an assistant to push crate
    under bike..
    sweller, Aug 9, 2003
  4. Jim Scullion
    SteveH Guest
    Trolley jack on the swing-arm pivot - stabilised by the sidestand.
    SteveH, Aug 9, 2003
  5. Jim Scullion
    I must confess to having never owned a paddock stand, it just seems to be
    the thing to have now for faired side-standed bikes.
    The Z1000 would probably do just as well with the heave onto a pint
    bottle beer crate method.
    Certainly a *lot* cheaper.
    sweller, Aug 11, 2003
  6. In my day, if a bike had only one stand, it was the centre stand and
    they omitted the sidestand. Now it's sidestand, and omit the centre
    stand.
    For the sake of 500g or so, is it worth it?
    The Older Gentleman, Aug 11, 2003
  7. Jim Scullion
    SteveH Guest
    It's for ground clearance, innit?
    But that's probably more down to shite stand design rather than anything
    else.
    SteveH, Aug 11, 2003
  8. Jim Scullion
    If you can lift a Zed Thou onto a beer crate, you've been working out.
    Those big old 70s fours are fucking *heavy*
    Champ, Aug 12, 2003
  9. Jim Scullion
    It's all about leverage. Push it over onto the side stand , balance
    precariously on it lifting the underside of the bike up, then gently
    push the beer crate underneath and release.
    And watch it slide completely off said crate, over the other side, and
    land on your knee.
    Ace, Aug 12, 2003
  10. Jim Scullion
    Ah, how heavy is a Z1000? (other than "fucking").
    I can lift a GS550 onto a crate solo. The CB750 needed the sidestand
    method.
    My Guzzi is pretty easy and I suspect a lot lighter than the Suzuki. But
    it's all *so* much easier with a FOAD 3t trolley jack and wood packing.
    You can even (with an assistant) move it round the lockup.
    sweller, Aug 13, 2003
