No grunt..
Discussion in 'UK Motorcycles' started by Don, Nov 8, 2005.
  1. Don
    Don Guest
    OK, step son has inherited a ratty but not *too* shabby gpz750. Now, after
    charging the battery and a quick squirt of easy start, the thing runs... it
    ticks over and revs OK (ish!), but when the engine is actually put under
    load, it has absolutely *no* bollocks to it, coughs and splutters and
    threatens to stall.. You can actually get it to move, but at no great
    pace...and it just wont rev out...
    First port of call will be a strip down of the carbs, but any other
    sugestions as to where to look?... are there any particular bits on these
    that tend to fry themselves or otherwise cause the above problems?
    Any prompts gratefully received...
    Don, Nov 8, 2005
  2. Don
    JB Guest
    Fuel starvation due to shit in the jets or blocked strainer in the tank/fuel
    tap. Also check inlet rubbers for leaks.
    I'd also check the plug caps/leads, and coils for 'tracking'. Easier in the
    dark to see this. The plugs themselves may need replacement too.
    JB
    JB, Nov 8, 2005
  3. I'd suspect ripped diaphragms.
    Bikes with damaged diaphragms will run, often quite sweetly low down,
    but lack all power.
    The Older Gentleman, Nov 8, 2005
  4. Don
    Don emerged from their own little world to say
    Animal nest in airbox?
    wessie, Nov 8, 2005
  5. Don
    zymurgy Guest
    Same on one of the wet dreams. No diaphragms, just 2 dashpots and the
    carbs and jets have been thoroughly submerged in thinners over a few
    days to clear the glaze out.
    I'm going to swap a carb set off a "good" one to eliminate from my
    enquiries ..
    P.
    zymurgy, Nov 8, 2005
  6. Don
    Incidentally the same symptoms afflict carburetted Saab 900s with split
    diaphragms.
    It was a nerve racking few weeks.
    sweller, Nov 8, 2005
  7. Don
    Shit in the carbs.
    darsy, Nov 8, 2005
  8. Don
    usenet Guest
    How will that help?
    usenet, Nov 8, 2005
  9. Don
    I think what he's suggesting is confused by the use of the phrase "fuel
    starvation".
    If the main jets are blocked it would give exactly those symptoms
    described. I agree with what you're saying in respect of fuel supply
    from the tank to the carbs themselves
  10. Don
    Dave Guest
    Piss in the tank.
    Dave, Nov 8, 2005
  11. Don
    tallbloke Guest
    Prime poetry opportunity wasted there.
    tallbloke, Nov 10, 2005
Similar Threads
Loading...
