No Muffler = Power? ACK!
Discussion in 'Motorcycle Technical Discussion' started by Tmckean, Jul 19, 2005.
  1. Tmckean
    Tmckean Guest
    Okay, so maybe
    It IS only a tiny 49cc, two cycle scooter, but I am not sure how to fix
    this problem?
    There was a problem with the muffler and when it was off of the bike,
    the thing REALLY cruised. That 49cc was FAST and it could not only go
    up the hills, but accelerate while it was doing it!
    I put the muffler back on, and now it is pretty poor in the power
    department. Doesn't go near as fast and barely makes it up the hills.
    So my obvious question is, how can I keep the muffler on it AND have
    the power at the same time? *Blink*
    Thomas
    www.thomasamckean.com
  2. Do you know what an expansion chamber is? It's an exhaust pipe that's
    shaped like a wasp's abdomen. It usually has a very small stinger
    coming out the end of the wasp's belly and makes an awful loud noise
    when it runs. Expansion chambers work by trapping hot exhaust gasses
    inside and letting them out at a slower rate than the exhaust goes into
    the pipe...
    You could have 50% more power with an expansion chamber and all your
    neighbors would hate you when you annoyed them with the awful racket on
    Sunday morning when they were trying to sleep off a hangover...
    But you can build a quiet expansion chamber with an inverted stinger so
    you can feed the exhaust into a rather larger muffler can. The inverted
    stinger takes the exhaust out of the center of the chamber instead of
    the end of the wasp's abdomen, and that really quiets it down compared
    to the noisy expansion chambers we used to have on our dirt bikes.
    There is a classic book called "Two-Stroke Tuner's Handbook" by Gordon
    Jennings. He told all about how to modify 2-stroke engines to produce
    more power and he told about how to build expansion chambers.
    Try googling for "expansion chamber" and how to design one...
    krusty kritter, Jul 19, 2005
  3. Tmckean
    Iraxl Enb Guest
    okay, mr. krusty kritter, i demand to know how you know
    so much :)
    irax.
    2002 CBR 600F4i
    Iraxl Enb, Jul 19, 2005
  4. Tmckean
    Sparkle Guest
    The Encrusted One usually hits, sometimes he misses.
    "Expansion chambers work by trapping hot exhaust gasses
    the pipe..."
    His discussion of airbox snorkels and resonance was good, probably
    should have used the same thinking here.
    Sparkle, Jul 20, 2005
  5. Tmckean
    Sparkle Guest
    Cool? I suppose so.
    But what do you think happens to the gas pressure when it expands?
    I'd bet the exhaust gasses exit the pipe at the same rate they enter it!
    The unmentioned idea is that a reflected pressure wave pushes intake
    charge back into the cylinder.
    Yes, thanks crusty, I have learned several things from you. But *nobody*
    is spot on all the time.
  6. Muffler, or the whole exhaust system?
    ______________
    / \ _______
    ____/ \___| |_
    ____ ___ _
    \ / |_______|
    \______________/ Muffler/
    Expansion Chamber Silencer
    Check that the silencer is not blocked -- I've known wasps to
    build their nests in there! The silencer also tends to block up with
    unburnt oil. If there's a removable baffle you can clean it off by
    burning it with a blowtorch, or just throwing it in a campfire. If
    there's no removeable baffle, you might be able to burn it off by
    starting the oil burning with an oxy-torch, then flowing oxygen-rich gas
    down the pipe (or maybe even just compressed air) -- make sure all
    rubber, etc., seals are removed before trying this!
    GSX600F, RG250WD, DT175MX "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, Jul 20, 2005
  7. Which matters more? Whether everybody keeps "score", or if newbies get
    their motors runnin' and get out on the highway?
    Did you ever read Gordon Jennings' book, "Two-Stroke Tuner's Handbook?"
    Back in the 1960's, a pair of Japanese engineers (Naito and Nomura)
    investigated the expansion chamber that had already been invented by
    the German Walter Kaaden who designed GP racers for MZ. In the late
    1950's, the Japanese factories bought rights to a bunch of patents for
    pre-war German
    2-strokes, so that's why the architecture of all the 1970's Japanese
    2-strokes is so similar.
    I still have copies of the scientific papers that Naito and Nomura
    wrote.
    But Gordon Jennings' literary style is much superior to such dry
    academic works. Jennings picked up on that work and wrote the classic
    TSTH that occupies an honored position in my library of reference
    works.
    If you buy TSTH, you can use it to answer a lot of newbie questions
    about
    airboxes, expansion chambers, carburetors, compression ratios, and
    ignition systems, and spark plugs, and combustion phenomena, and that
    little red-and-white paperback treasure house of information is only
    156 pages long!
    Gordo (that's what the other speed tuners called him, and everybody who
    mattered in motorcycling seemed to know each other in the late 1960's
    and early 1970's) was the kind of Dirty-Handed Da Vinci who was an
    engineer and a hotrodder and a moto-journalist all wrapped up into one.
    I think I was even an ASC, since I often notice his name on 1950's
    movie credits. I wish Kevin Cameron (who is a very knowledge
    technofreak) was as highly-educated as Gordo was. We lost a genius when
    Gordo died of cancer a few years ago.
    If you ever rode a two-stroke with an expansion chamber you may have
    noticed that it seemed to need to "pressurize" before it did anything
    for performance. It needed to get hot, too. The speed of sound in a gas
    depends upon the temperature of that gas, and the formula for flask
    resonance applies to an expansion chamber just as it does to an airbox
    or a 2-stroke crankcase that's pumping air.
    The expansion chamber as been described as "just a pressure bleed
    restrictor" by some motojournalists and I used a similar statement in
    describing how an expansion chamber works in the first thread in this
    post because the original poster may never come back and even read the
    short answer I gave him. That's the waste of NG's, a lot of questions
    get asked, a few get answered, but sometimes the newbie doesn't even
    remember all the places he posted to.
    Yet the echoes do coming roaring back, as people who just LOVE to argue
    find something to nit-pick on and argue about in order to re-affirm
    their own self worth.
    I won't go much deeper into what Gordo had to say about expansion
    chambers, other than the fact that the diameter and length of the
    stinger is critical for trapping pressure and heat in the pipe so it
    will resonate at the right frequency without melting the piston, and
    the angle of the reflector cone is important for controling whether the
    engine can be over-revved past the power peak (important in road racing
    where the rider often needs to stay in one gear all the way around a
    long corner with the engine screaming near redline) or whether the
    powerband will have a sharp cutoff at a certain RPM.
    Moto-X expansion chambers of the 1970's would have wide angled
    reflector cones for that purpose, but road racing expansion chambers
    would have narrow angle diffusers and reflectors to make it possible to
    over-rev the engine.
    krusty kritter, Jul 20, 2005
  8. Tmckean
    Sparkle Guest
    The "score" matters! As you note further down, the newbie often never
    returns to find his answer anyway.
    Meanwhile, you're quite a storyteller for the lurkers. And there's that
    aura around here of 'What krusty says is truth! We love krusty, and we
    want HIM to be right.'
    You sidestepped "So my obvious question is, how can I keep the muffler
    on it AND have the power at the same time?"
    Explaining how expansion chambers work is nice, but won't help him.
    Nope! I've read lots of his magazine articles over the years.
    And that's what I found lacking here. Your recent airbox/snorkle
    discussion was darn good! The expansion chamber explanation was not.
    Translation... you don't tolerate correction well.
    Neither do I! That's tough s**t for us both, wrong information ought to
    be corrected wherever and whenever.
    See? Now you've done better. Readers got more than "Expansion chambers
    work by trapping hot exhaust gasses inside and letting them out at a
    slower rate than the exhaust goes into the pipe..."
  9. Tmckean
    Sparkle Guest
    Expanding gas slows, increasing pressure.
    I know, I hate it too, I want expansion to result in a pressure drop :(
    Smaller section increases gas velocity, reducing pressure :(
    Krusty can explain diffusers and nozzles in turbine engines, because I
    may be lying to you.
  10. Maybe it will, if he ever returns. My take on the question was that the
    OP's motorbike had a muffler clamped onto a header pipe, so I figured
    he didn't have what most of us would call an "expansion chamber", even
    tough that's what a 2-stroke "muffler" usually is. I figured that the
    OP was just running a straigh pipe about 12" to 18" long...
    Dr. Ivan D. Reid's take seems to have been that the OP's motorbike had
    a more obvious-looking expansion chamber with a silencer on it. He
    apparently thought the OP was running without the silencer, which would
    make the expansion chamber flow exhaust more freely...
    The quietest and best performing expansion chamber possible would have
    an inverted stinger. As I recall, Hoyt McKagen was saying that the best
    inverted stinger wasn't just a straight pipe stuck inside the reflector
    cone, but should have a flare on that end. This means that an original
    equipment expansion chamber would need some more extensive surgery on
    it...
    Then the expansion chamber should have the largest possible silencer
    attached to the 1"~2" long stub end end of the stinger
    But you got your money's worth the first time, didn't you?
    I am preparing your new bill now. How would you like to pay this,
    Mr. Sparkle?
  11. Illustration, please.
    Michael Sierchio, Jul 20, 2005
  12. http://www.suzuki-rg500.com/exhaust.htm
    It look like this guy used inverted stingers on his top pipes that he
    made for his RG-500 Gamma. His top pipes are the lower ones in the
    photo.
    Back in the 1950's, when MZ was racing 2-stroke GP bikes, they decided
    to run the exhaust pipes out of the rear of the cylinders because a
    forward turning crankshaft puts a side thrust on the rear of the
    pistons. This would offer an exhaust port sealing advantage. The
    expansion chambers were probably too long, and that's how inverted
    stingers were *probably* invented, though I don't have any pictures of
    such exhaust systems.
    Then along came Gordon Jennings in the late 1960's and he knew a lot of
    good stuff about the pioneering work of Walter Kaaden, et al.
    This was back In The Day when American roadracing pioneers couldn't buy
    a really fast, race-winning motorcycle, they had to build everything
    themselves, inspired by what they were reading about European GP
    racing.
    Jennings had a rider named Tony Murphy who is probably
    little-remembered. Murphy's most enduring statement was, "Everybody
    wants to be a racer, but nobody wants to go fast." This was before the
    invention of real brakes and real tires, so I can't fault Murphy for
    wanting to win races at the slowest pace possible on a motorcycle that
    didn't turn or stop well, races were won by dragracing the other rider
    on the straights.
    Jennings had a Bridgestone GTR-350 air-cooled twin with rotary valves,
    and he was going to make it into "Son of Secret Weapon" (Secret Weapon
    had been a roadracing flathead Harley Davidson, as I recall).
    First step on Jennings plan was to turn the cylinders around backwards
    by put the right cylinder where the left belonged and vice versa, to
    get the exhaust ports on the backside and take advantage of the
    crankshaft thrust sealing the exhaust port.
    I don't know if Bridgestone was tricky enough to do what Yamaha and
    Suzuki knew to do. Those companies were simply offsetting the wristpin
    one millimeter toward the rear of each piston to get improved exhaust
    port sealing without turning the cylinders around backwards.
    In order to turn the cylinders around, Jennings had to do a bunch of
    welding and machining on the lower end of the transfer ports, the part
    that was in the upper crankcase half.
    (I walked into my local Kawasaki dealer once, trying to talk him into
    letting me race his Norton Manx, and he showed me the upper crankcase
    half of his 250cc A-1R road racer. He was trying to emulate what
    Jennings had done with Son of Secret Weapon.)
    Anyway, Jennings got his cylinders mounted backwards on the engine, and
    fabricated his expansion chambers, but the problem was that they were
    too
    friggin' LONG! The stingers stuck backwards part the rear wheel, and
    the AMA rulebook said that the exhaust system could NOT protrude that
    far back...
    So Jennings just slid the stingers INSIDE the convergent or "baffle"
    cone.
    And Son of Secret Weapon was very fast and Jennings was surprised how
    QUIET the expansion chambers were. He didn't know why the Bridgestone
    was fast, it just was.
    Later, he got the chance to do some dyno work with adjustable sliding
    internal stingers. In Two-Stroke Tuner's Handbook, he said that there
    was, surprisingly, NO DIFFERENCE in power with the internal stinger
    pushed all the way into the chamber to a point about 1' ahead of the
    beginning of the baffle cone (the exhaust sound was a lot quieter
    though)and there was NO DIFFERENCE in power with the internal stinger
    pulled all the way out to the normal position, but there was a
    noticeable drop in power when the stinger was pushed in to the halfway
    point of the convergent cone.
    This halfway point is the same as the "mean point of reflection" of a
    *complete* baffle cone with a pointed end. The "mean point of
    reflection" is the end of the expansion chamber's tuned length. If the
    stinger takes pressure from that point, it steals heat and pressure
    energy that's needed to make the expansion chamber "tune" at the
    required frequency to be in "synch" with the exhaust port opening and
    closing.
    On his RG500 Gamma webpage, Rob Koopman mentioned the possibility of
    building an expansion chamber with the baffle cone coming to a point
    (like the wasp abdomen I mentioned earlier) and recovering ALL of the
    heat and energy in the exhaust gasses, and then just bleeding a small
    amount of exhaust out of a stinger that came off the fat belly of the
    expansion chamber.
    The whole concept of a side bleed stinger makes me wonder if the
    motojournalist's description of an expansion chamber as a "pressure
    bleed restrictor" isn't actually TRUE.
    And it makes me wonder if expansion chambers couldn't just be big fat
    UGLY cylinders with flat ends like SAAB's mufflers for their 2-stroke
    triple automobiles of the 1960's. It would be simple, but it wouldn't
    be as pretty as those sinuously-flowing stamped sheet metal production
    expansion chambers we've been seeing for the last 30 years.
    krusty kritter, Jul 21, 2005
  13. Tmckean
    Sparkle Guest
    Yes. We all get our money's worth here!
    My RT2 is your's after I die.
    Sparkle, Jul 21, 2005
