No Triumph reg/recs available....
Discussion in 'UK Motorcycles' started by TOG@Toil, Jun 1, 2010.
  1. TOG@Toil
    TOG@Toil Guest
    Not until 11 June, anyway.
    Turns out Triumph has changed supplier of its reg/recs because the
    original supplier (presumably the firm that made the one that failed
    on my Street Triple) has been replaced by a company making ones "with
    greater longevity" (quoth Carl Rosner).
    First reaction: arse. Second reaction: well, can't ride it until
    weekend after next anyway. Third reaction: Triumph don't **** about if
    you mess up as a supplier, do they?
  2. TOG@Toil
    They fucked around for long enough with the shite sprags in the early
    90s.
    Krusty, Jun 1, 2010
  3. TOG@Toil
    I know I shouldn't do this but you were the first to take the piss
    when my reg/rec packed up so...
    The Yamaha dealer I dumped my bike with contacted the European
    distributor on a Tuesday morning and by the Thursday afternoon the
    bike had a new wiring harness and a new reg/rec. I'm not sure that
    having a big pile of parts to replace known problems is a good thing
    or not.
    Andy Bonwick, Jun 1, 2010
  4. TOG@Toil
    TOG@Toil Guest
    In fairness to Triumph, it was something that just didn't show up in
    testing and only came to light after a while when batteries got low
    and the engine 'kicked back'. Kawasaki's Z/GPz/GT650/750 series
    suffered from a similar problem.
    It's odd how faults completely escape product testing and only show up
    once the end user has got his/her mitts on the thing. I remember
    reading that the Peugeot 309 (I had one - horrible thing) suffered
    from a rash of tailgate window fall-outs and breakages and they
    couldn't figure out why, because some testing robot had successfully
    opened and closed the hatch a zillion times, or whatever.
    It turned out that they broke because people were parking the cars,
    opening the tailgate, slinging their stuff into the back, and then
    closing the hatch with one hand (on the side of the tailgate) as they
    walked back to the driver's door. This caused a slight twist in the
    structure and was enough to cause the glass to pop out from time to
    time.
    Basically, the consumer will always find a way of breaking something
    that the factory hasn't thought of.
    TOG@Toil, Jun 2, 2010
  5. TOG@Toil
    Just the opposite according to an old family friend who was a Triumph
    test rider in the early 90s. They knew the sprags were borderline very
    early on, & put one of their own engineers in the supplier's factory to
    do QC. But the only real solution was a bigger sprag, & there wasn't
    enough clearance to fit one, so had to redesign the cases. The interim
    solution for bikes that failed was for the dealer to take a die grinder
    to the cases to make room for the bigger sprag. Mine had this done[1] &
    has been fine ever since.
    [1] At Triumph's expense, after much letter writing on my part. This
    was in the late 90s & they still refused to accept it was a common
    problem.
    Krusty, Jun 2, 2010
  6. TOG@Toil
    TOG@Toil Guest
    Ah, that's interesting. Never heard that before.
