Non existent front brake
Discussion in 'Australian Motorcycles' started by Fraser Johnston, Oct 8, 2008.
  1. Fraser Johnston
    Marty H Guest
    When I bleed the VFR (I should have shot it) the manual said to use a
    power/vacuum bleeder.. I didnt
    after 4 days of trying to bleed the system throu its 7 nipples and
    gave up and bought a 60ml syringe from a chemist and with a piece of
    3mm hose and I sucked the fuild through, worked like a charm..
    Fraser, time to buy a syringe! (try a vet)
    mh
    Marty H, Oct 9, 2008
  2. Fraser Johnston
    GB Guest
    It's hardly a complex system, but I had to do just that to get
    the fronts on my yzf1000r bled.
    GB
    GB, Oct 9, 2008
  3. Fraser Johnston
    sharkey Guest
    I've done this myself, and it does seem to work, but I have to admit the
    whole idea is so preposterous that I didn't see fit to talk about it in
    public.
    PS: You can buy replacement banjo bolts with bleed nipples in them, if
    you're feeling less preposterous. No idea if they work. The XLV brake
    system is simple enough that you really can hang the caliper from the
    ceiling and pump the bubbles up, and it doesn't work worth shit anyway.
    -----sharks
    sharkey, Oct 9, 2008
  4. Fraser Johnston
    F Murtz Guest
    Had the same symptoms on bmw I found minuscule hole blocked [bottom of
    reservoir in side of master cylinder] [bypass or equalizer or some such
    thing]
    F Murtz, Oct 9, 2008
  5. The gixxer does have a master cylinder bleed screw. I got a power
    bleeder yesterday so it looks like I will give it a really good bleed
    today and replace all the fluid. I'll post my results.
    Fraser
    Fraser Johnston, Oct 10, 2008
  6. Looks like a warped rotor. I can bleed the brakes and get a hard lever
    but the second I move the bike it looks like it is compressing the
    piston back into the caliper. So it is all coming apart tomorrow and
    going on a run out gauge on Monday.
    Fraser
    Fraser Johnston, Oct 11, 2008
  7. Fraser Johnston
    Boxer Guest
    I win.
    Boxer
    Boxer, Oct 11, 2008
  8. Fraser Johnston
    Biggus :)~ Guest
    . So it is all coming apart tomorrow and going on a run out gauge on Monday.
    take calipers off, put straight edge against forkleg to disk then spin
    rim..
    also do the rim, as it maybe fawkt too since isnt this 1 bike from 20
    broken ones?
    Biggus :)~, Oct 11, 2008
  9. Good call. I'll give it a crack. Bike is all one piece with a few bits
    like the radiator and fairings replaced. I can see damage on the edge
    of the rotor so I'll be replacing it anyway. Don't want the front brake
    grenading on the main straight at Wanneroo.
    Fraser
    Fraser Johnston, Oct 12, 2008
  10. Fraser Johnston
    atec77 Guest
    The most likely place for it happen is 6 metres off a bumper under full
    breaking when you really need a stop
    atec77, Oct 12, 2008
