Nordkapp latest
Discussion in 'UK Motorcycles' started by ogden, Feb 9, 2011.
  1. It is remarkably simple. The whole world works in C whereas the merkins
    don't. I was brought up with F but had to convert later in life and these
    days have no problems when thinking down to their level.
    steve auvache, Feb 13, 2011
  2. ogden
    Thomas Guest
    Need I remind you again about the lazy part (vs ignorance?)
    Converting temperature exactly is so seldom required, as opposed to
    distance or volume, that a vague wave of the hand usually suffices. We
    can tell the difference between comfortable, bloody freezing, warm,
    and unbearably hot, but a few degrees one way or the other is
    irrelevant. My conversion factors are 0=32, 100=212, and ambient air
    is 20ish=high 60's. If someone says it's 40C outside, I know it's hot,
    but I don't need to know the exact F.
    Thomas, Feb 13, 2011
  3. ogden
    R C Nesbit Guest
    SIRPip spoke:
    But aren't Poles used to cold temperatures?
    Rob_P
    UKRM(at)indqualtec.co.uk
    uppercase(d) BBIWYMC#1 BOG#11? MRO#31 IBCDBBB#1(kotl)
    FJ1200, CCM130 Benelli Cabriolet (gone)
    Looks like Rab C Nesbit.
    R C Nesbit, Feb 13, 2011
  4. ogden
    Did anyone take the chemical heat pads that Donald and I used in
    Germany? They were ace, 8 gets you warm fingers and toes for a full
    day. That was in case my heated gloves failed.
    Hog, Feb 13, 2011
  5. ogden
    I remember you showing me the heated visor made with resistance wire,
    why didn't you use it?
    Hog, Feb 13, 2011
  6. ogden
    All these stories have made me think again about a Sidecar raid. How do
    you think outfits would fare on thiose roads, assuming studs/chains on
    all 3 tyres
    Hog, Feb 13, 2011
  7. ogden
    Andy Guest
    I think you should try it. I wouldn't want to be in the chair if you
    broke down or had to pull over for any reason because the breaking
    distance for fully loaded trucks on ice isn't very good and they're
    not all running studded tyres and I don't think I've seen anything
    fitted with chains.
    You'd also find that unless you spend a lot of money on the outfit
    it'd be in bits before you reached the arctic circle. The roads are
    very bumpy and would shake most outfits apart in a very short time.
    Andy, Feb 13, 2011
  8. ogden
    Stephen Guest
    You would want a good steering damper for when the ridges in the road
    shake the steering and points the bike in the wrong direction.
    Plus with your circulation issues probably a total loss heating system
    driven by a spare battery. It gets really fucking cold. And then add
    windchill. Some areas looked like a freezer with freezing mist to go
    with it. Three of us have something close to frostbite.
    I really would not do chains, they would shake you more than you
    need. Studs are the way to go. Lots of them.
    Stephen, Feb 14, 2011
  9. ogden
    davethedave Guest
    When it's 40C the exact "F" is normally followed by a "uck me"
    If it hits 50C further "F"s can be added as required.
    davethedave, Feb 14, 2011
  10. ogden
    You do appear to have rather more natural insulation than the rest
    though, & that makes a *big* difference. There's a good reason seals &
    penguins aren't built like Andy.
    Krusty, Feb 14, 2011
  11. Just thought of this from "The King's Speech"
    Lionel Logue: Do you know the "f" word?
    King George VI: Ffff... fornication?
    Mick Whittingham, Feb 14, 2011
  12. ogden
    davethedave Guest
    Also the tale of the swearing kitten and the rotweiler.
    A little girl was at school one day. They were learning about animals.
    The teacher asks "What do dogs say?" Hands are raised and the the
    correct answer of "woof" was given. The teacher moves on to the next
    question "What do kittens say?" a little girl raises her hand. The
    teacher says yes Mandy. Mandy says "****! miss. They say ****." The
    teacher in a state of shock immediately drags Mandy from the room
    to the headmasters office and demands that she explain herself.
    The headmaster well used to such incidents by now,after his time in an
    inner London creche, asks Mandy why she thought that kittens say ****.
    Mandy replies.
    Well I was playing in the garden at home with my kitten one day when the
    neighbours rotweiler escaped and jumped over the garden fence. My kitten
    say the rotweiler and started to go F F F Ffff ffff. He was going to say
    **** but the rotweiler killed him before he could finish.
  13. ogden
    Stephen Guest
    But not so many studs that they puncture the front tube because that
    is not fun.
  14. ogden
    Quite the learning experience, this.
    By the time you get back you'll be fully prepared for the trip you
    started a week and a half ago!
    ogden, Feb 14, 2011
  15. ogden
    Paul-xxx Guest
    Heh, maybe next year the Sahara, a whole different kettle of a ball
    game.
    Paul-xxx, Feb 14, 2011
  16. ogden
    72degrees Guest
    Shackleton's birthday today should be inspiration to them.
    72degrees, Feb 15, 2011
