not so much a willy willy....
Discussion in 'Australian Motorcycles' started by bikerbetty, Jan 19, 2009.
  1. bikerbetty
    Diogenes Guest
    When you do, can you whack a copy up om YouTube for us?
    Jack's back...
    Onya bike
    Gerry
    Diogenes, Jan 25, 2009
  2. In aus.motorcycles on Sun, 25 Jan 2009 14:07:54 +1100
    This is theory.
    And sometimes it works.
    But by no means always. In a gusty direction changing wind you need
    both feet on the ground, and it's not always possible to tell that the
    wind won't gust.
    Zebee
    Zebee Johnstone, Jan 25, 2009
  3. If I'm reading you correctly, if the wind is coming from the right,
    you should have your right foot down? is that so your bike is leaning
    into the wind?
    I must admit I haven't previously considered it, but now that I have I
    would of thought you would need to have the grounded/ supporting foot
    on the opposite side of the bike the wind is coming? Why is the other
    way better?
    __
    Cheers
    The Happy Drunk
    K100RT
    The Happy Drunk, Jan 25, 2009
  4. In aus.motorcycles on Sun, 25 Jan 2009 17:20:09 +1030
    Depends a lot. If you haven't got the bike all that much leaned over,
    then perhaps not, although I've definitely had it move the other way
    which was frightening.
    But on the Norge, even with bum a bit off the seat, there' snot such
    thing as "firmly" and "weight on that leg". To do that, the bike has
    to tip too far over.
    Put it this way Johnno me old son.. the only bloke who I consider
    might know what he's talking about in this conversation is JL.
    I'll only believe the rest of you when I see you performing these
    stunts on a Quota.
    Zebee
  5. bikerbetty
    Diogenes Guest
    Well said !!!
    Onya bike
    Gerry
  6. bikerbetty
    Diogenes Guest
    BTW, I'm pretty sure I'd be dropping a Quota on a daily basis. They
    scare me, they do.... and I'm 5'11" (do your own metric conversion.)
    Onya bike
    Gerry
  7. bikerbetty
    Boxer Guest
    I find my BMW R1200GSA to be a bit of a handfull in these situaions too. It
    makes a Quota look like a pushbike.
    Boxer
    Boxer, Jan 25, 2009
  8. bikerbetty
    Nev.. Guest
    Pfft... you should have chosen a bike with a high seat...
    Nev..
    '07 XB12X
    '08 DL1000K8
    Nev.., Jan 25, 2009
  9. bikerbetty
    Nev.. Guest
    Good pickup. Right should be left.
    Nev..
    '07 XB12X
    '08 DL1000K8
    Nev.., Jan 25, 2009
  10. Fair enough :)
    __
    Cheers
    The Happy Drunk
    K100RT
  11. bikerbetty
    jl Guest
    I think her point is about being short of leg while dealing with the
    problem (ie not having two feet firmly planted on the ground) which the
    majority of blokes on here can do on the vast majority of bikes.
    It's not about riding experience it's a comment about short-arse riding
    experience.
    The quota being a bike that only professional basketballers and those of
    similar height are going to flat foot
    JL
    jl, Jan 25, 2009
  12. bikerbetty
    jl Guest
    Well, OK, but that's not apples to apples - a four with a massive crank
    is going to have a similar weight to the guzzi at the same height give
    or take
    jl, Jan 25, 2009
  13. bikerbetty
    jl Guest
    Fair enough - but I didn't think the SV had a lay down front cylinder
    parallel to the dirt (in fact do even Ducati still do that config ? it
    forces the engine a long way back in the frame)
    You might not be too, I hadn't thought of that but I don't think the SV
    is laid out thatway
    JL
    jl, Jan 25, 2009
  14. In aus.motorcycles on Sun, 25 Jan 2009 20:44:07 +1030
    Nope. Just needs to be ridden in the way that works for shortarses.
    Rather than one that works for someone taller.
    See above. Read for comprehension.
    Zebee
  15. bikerbetty
    Psst Johno; look up.. err DOWN.. I think you missed the point!
    Knobdoodle, Jan 25, 2009
  16. bikerbetty
    No I don't think so either but the narrow Vs can sit much lower in the frame
    than the much wider fours (for the same cornering ground-clearance).
    I dunno the specifics of the SV650 vs. the CBR600RR but I'd reckon that'd
    normally be a factor.
  17. bikerbetty
    jl Guest
    Nope. Not unless you're trying to say that motorcycles should have a
    minimum height requirement so you can standardise the way you achieve an
    outcome.
    <shrug> When you can only get balls of feet down (or worst case one
    tippy toe) you behave differently to if you can put feet down flat.
    Doesn't mean you can't ride the thing, it can mean for some people
    getting testy about well meaning advice that is errm, unhelpful.
    JL
    (which doesn't mean your advice was unhelpful - I don't know either way
    - I only skim read the thread and stopped at the bit where my name was
    taken in vain...)
    jl, Jan 25, 2009
  18. bikerbetty
    jl Guest
    <shrug> If I visualise the Raptor (90deg V twin) I can't see how it's a
    lower CoG than an equivalent 4. Certainly doesn't feel it; but without
    appropriate measurements I don't know how it can be resolved
    JL
    jl, Jan 25, 2009
  19. bikerbetty
    jl Guest
    Ahhh OK, that's a thought.
    JL
    jl, Jan 25, 2009
  20. In aus.motorcycles on Mon, 26 Jan 2009 00:54:06 +1100
    I wonder what that means for the Guzzi CoG. Anyone got a decent
    physics simulator?
    Zebee
