not so much a willy willy....
Discussion in 'Australian Motorcycles' started by bikerbetty, Jan 19, 2009.
  1. bikerbetty
    Andrew Price Guest
    Zebee wrote -
    This thread reminds me of some unfinished business with most bike
    manufacturers.
    Our species arrives in various configurations which requires manufacturers
    of things that have to fit humans to either make a variety of sizes or make
    the item adjustable in key dimensions.
    Best example is road (push) bikes - with some fiddling, pretty much any size
    human can be accommodated in the most efficient peddling position (leaving
    aside the many theories of where that is exactly).
    They seem to have got this pretty much nailed in cars.
    But if your at the other end of the spectrum to Betty (a way tall boofy
    bloke) forget a Ducati monster or most of the smaller sports bikes because
    the cramping means someone like me will never fit (and I did like the
    monster).
    I appreciate some of the smarter manufacturers (bmw for one) do have
    variable seats and lowering / raising bits.
    But, imho, most manufacturers could do a hell of a lot better - apart from
    it being safer for the operator, they might sell more units.
    Andrew Price, Jan 25, 2009
  2. In aus.motorcycles on Mon, 26 Jan 2009 08:29:02 +1100
    Umm... how many frame sizes are there again?
    (And I note that in the 1980s I had one hell of a time finding a
    pushbike to fit, as apparently only people under 10 or over 5'8" rode
    bicycles...)
    NOt many variables need to change and those that do aren't part of the
    main configuration of the vehicle.
    However... most car seatbelt configs range from uncomfortable to
    dangerous for me. I've met plenty of cars where it's hard for me to
    have the pedals close enough without the steering wheel hitting me in
    the face, and where my vision isn't as good as it could be as I'm too
    low in the seat.
    Most of it's in the main config of the bike.
    In the same way road style bicycles have really high bottom brackets
    so that if you have the pedal/seat distance correct you have to lean
    the bike well over or get off the seat when you stop (If you want
    your foot flat that is) modern motorcycles tend to have engine and
    pegs high for ground clearance. This makes the seat high too.
    My beloved and much missed 850T Guzzi was one of the lowest bikes
    I've ever ridden. The engine and frame design was lovely but had
    drawbacks such as a much longer wheelbase than is currently desired.
    HOw do you suggest they do that?
    What sells bikes and who to?
    I am not sure... according to the adverts the manufacturers believe
    that what sells bikes is fantasy - racing or outlaw. And they sell to
    men. If they are right, then they don't really need to make a bike
    that fits small people, they need to spend more effort on one that
    fits taller ones as the average male height is increasing.
    Read the magazine reviews. Over the years I (being short) have
    noticed that the main complaint magazine testers have is the bike's
    too *cramped*. For some reason they are tall and so complain about
    that. The only time they ever have a shorter person test is when they
    do one of those condescending "woman's view" things. (Hven't done for
    some time that I've seen, guess they finally got the message it's
    condescending, but not the corrolary of "so have female testers for
    things that aren't fscking scooters")
    Car manufacturers can have adjustments because the driver position
    changes are minor in the scheme of how the car is made. Bike position
    changes are much bigger (and I suspect more expensive).
    You can muck about at the edges some if you have a fairly standard shaped
    bike - can do a little with seat height (but not much because of frame
    requirements), a little with peg location on eccentric adjusters on
    pegs and levers (but not that much ), a little with adjustable bars
    (and I'd like to see this on more bikes although the BMW version I've
    seen is truly ugly) but must be careful with fairings and cables/hoses.
    Given the complexity of bike adjustment (you'll note the cost of the
    bikes these are available on) I'd bet that you won't see them on
    anything but top end tourers.
    Zebee
    - whose Norge has adjustable pegs and foot and hand controls but
    *really* needs adjustable bars.
    Zebee Johnstone, Jan 25, 2009
  3. There are situations (rare) where I've been concerned about gusting
    wind. And that's when the gusts are changing direction and strong. I
    can flatfoot both feet so can certainly understand where a shortarse
    is going to have that situation more often.
    Kevin Gleeson, Jan 25, 2009
  4. bikerbetty
    Nev.. Guest
    GSX-R1000 comes with 3 position adjustable pegs/levers.
    Nev..
    '07 XB12X
    '08 DL1000K8
    Nev.., Jan 25, 2009
  5. Nah - that's just for the wank factor. "Man, I have to have the pegs
    up so high as I keep getting my knee sliders down on the road just
    going to the shopping centre".
    I recall following a guy on a GSXR750 kitted out in full Dainese
    coloured leathers who I could tell was starting to get pissed off with
    me following him on a VTX1800 which I hadn't ridden before and had
    borrowed off a mate. First time I had ridden a bike that had feet
    forward rather than back. I knew I had got to cornering limits when my
    boots hit the road rather than the pegs. A mate of mine made the
    comment that the only time your feet should be forward is just before
    you crash . . .
    But it was quite interesting to have your feet hit the ground at
    fairly low speed compared to the Busa.
  6. bikerbetty
    Peter Wyzl Guest
    That's happened to me twice on the '01 FZ1 (220kg +) and both times it was
    when encountereing unexpected slipperiness mid corner and having a mild
    front wheel skid, fortunately at very low speed both times and probably a
    lot of luck and a bit of instinct saved a low side. Certainly didn't
    conciously realise what had happened until after the event, but the boot
    hitting the ground was quite disconcerting. A totally different sensation
    to the peg scraping which I managed on the same bike during an advanced
    skills course riding around Hidden Valley Raceway. I doubt I could
    (certainly wouldn't want to) achieve that on an ordinary road.
    P
    Peter Wyzl, Jan 25, 2009
  7. bikerbetty
    Nev.. Guest
    Is that opinion based on some personal experience with current model
    GSXR1000s or something else? I only know about the adjustable
    pegs/levers because a mate who owns one reckons the option to drop the
    pegs to improve ergonomics was great. I'm slightly more inclined to
    listen to the opinion of someone who owns one, than someone who doesn't
    own any bikes.
    Nev..
    '07 XB12X
    '08 DL1000K8
    Nev.., Jan 26, 2009
  8. It was me being somewhat facetious actually.
    Kevin Gleeson, Jan 26, 2009
  9. In aus.motorcycles on Mon, 2 Feb 2009 05:20:15 +1100
    Depends.
    Oddly enough, mostly I balance the bike between both feet. If I need
    to slide down to put one foot down more I do, but get right back up to
    balancing on both.
    THis is because I've had too many bikes lean one way then the
    other....
    Zebee
    Zebee Johnstone, Feb 10, 2009
  10. bikerbetty
    jl Guest
    Yup and the process of sliding across the seat to get the other foot
    down can mean the bike is a long way over before you have footing (read
    as "oops damn glad i bought those oggy knobs")
    JL
    jl, Feb 10, 2009
