Now that I've sorted the record deck to computer interface sorted ...
Discussion in 'UK Motorcycles' started by raden, Nov 27, 2005.
  1. raden
    raden Guest
    In order to back up my vinyl collection on MP3
    I have the record deck going into an RIAA preamp and into an Audigy2 ZS
    Does anyone have any recommendations as to what software would be best
    to use which might be better than the Creative recording s/w that comes
    with the sound card ?
    raden, Nov 27, 2005
  2. raden
    raden Guest
    Sorry, I missed out the crucial word "free"
    raden, Nov 27, 2005
  3. raden
    sweller, Nov 27, 2005
  4. raden
    Richard A Guest
    Try Audacity. I've no idea if it's the best but I've used it to
    produce MP3s from CD. The writeup says you can use it to convert
    records (which I'll be trying in the future). Oh, and it's free.
    http://audacity.sourceforge.net/about/
    Richard A, Nov 27, 2005
  5. raden
    MattG Guest
    I've used Goldwave (http://www.goldwave.com/) for just this task. Very
    good, also free.
    MattG, Nov 27, 2005
  6. raden
    raden Guest
    raden, Nov 27, 2005
  7. raden
    raden Guest
    Also looks good
    With around 1000 albums to copy, I suppose it's worth investing in s/w
    which will make life easier
    raden, Nov 27, 2005
  8. raden
    raden Guest
    I'm getting spoilt for choice here
    raden, Nov 27, 2005
  9. raden
    gomez Guest
    Or just takes a month's sabbatical and a load of uppers and listen one
    more time to the whole lot back to back to back.
    gomez, Nov 29, 2005
  10. raden
    raden Guest
    Nice idea, but I don't have the luxury of being to take time off work,
    especially at this time of year
    raden, Nov 29, 2005
  11. raden
    raden Guest
    Ho ho ho
    Yes if your boiler pcb breaks down
    raden, Nov 29, 2005
  12. raden
    wsotw Guest
    Audio grabber, requires a plug in for click/hiss filter but free and
    works well.
    wsotw, Nov 29, 2005
  13. raden
    raden Guest
    Ta
    raden, Nov 29, 2005
  14. raden
    raden Guest
    Where do I find the filter ?
    I can't see it on the main website
    raden, Nov 29, 2005
  15. raden
    wsotw Guest
    I've not used it so not sure. In the actual program when in line sample
    mode, click the settings button next to "reduce noise on incoming sound"
    and you will be informed that you need the plug in from Algorithmix. I
    believe the url is http://www.algorithmix.com - but I'm not sure which
    one it is.
    You could always contact the developer (via the audiograbber site) and
    ask them.
    wsotw, Nov 30, 2005
  16. raden
    wsotw Guest
    ah. found it...
    In the actual program when in line sample mode, click the settings
    button next to "reduce noise on incoming sound" and you will be informed
    that you need the plug in from Algorithmix. Now click on the help button
    and it tells you all the details you need to know.
    wsotw, Nov 30, 2005
  17. raden
    raden Guest
    Cheers
    raden, Nov 30, 2005
