O.T. Bloody Strimmers
Discussion in 'UK Motorcycles' started by Gavsta, Sep 1, 2004.
  1. Gavsta
    Gavsta Guest
    In
    Have you tried bump starting it?
    On the othjer hand, have you ever gone through dog shit with one, with no
    googles or owt?
    I have.
    Gavsta, Sep 1, 2004
  2. Gavsta
    Steph wrote in
    1. Check the spark plug lead. Easy to disturb it when faffing about with
    the spinny bit.
    2. There's probably a foam air filter. Clean it out by washing in petrol.
    Let petrol evaporate before reassemblling it.
    wessie, Sep 1, 2004
  3. Gavsta
    Alan Crowder Guest
    Start by removing all clothing, then..........shit wrong thread.
    Well if you do the above the guy from next door will be round
    to help.
    Alan
    Alan Crowder, Sep 1, 2004
  4. Gavsta
    Steph Guest
    Hi,
    I decided that considering it was a gorgeous day I'd have a go at the
    garden with a petrol strimmer which we've kindly been lent. Donned the
    racing leathers and lid, primed the engine put on the choke and pulled
    the starter. Woo hoo! that thing gets through brambles like a hot knife
    through butter - well it did till the string broke....
    Sorted out the string no problem, but can I re-start the damn thing? I
    have spent the last half hour with the choke on every position you can
    imagine - ignition is on, engine has been primed, and yes there is
    petrol in there. I even left it to rest for 10 minutes in case I'd
    flooded the engine. The engine is almost firing, but not staying on even
    when I tweak the throttle.
    Mr Mups did say he'd do the garden this weekend, but I wanted to get it
    sorted before he got back from London. It's now got to the stage where
    it's the fucking principle - I refuse to be beaten by a bloody 2 stroke
    even though it's winning at the moment. It's lying there smugly while I
    nurse the blisters I've got from the starter handle. I have resisted
    kicking it, but even calling it a "fucking ****" doesn't work although it
    makes me feel better...
    OK, any suggestions how to get it started other than what I've tried so
    far?
    Cheers
    Steph, Sep 1, 2004
  5. Gavsta
    Ben Blaney Guest
    Get a man in.
    Ben Blaney, Sep 1, 2004
  6. Gavsta
    mups Guest
    Ben Blaney says...
    I've just phoned, the man's now arrived.
    mups, Sep 1, 2004
  7. Gavsta
    Sounds flooded to me, can be a right bastard to get them going again.
    One method is to switch the choke off, hold the throttle wide open and
    pull the starter until it fires.
    Same sorts of problems on my model 2 stroke engines if you over prime
    those or try to prime them before a warm start.
    Muck, Sep 1, 2004
  8. Gavsta
    Ginge Guest
    "Hello, I'm the gardener".
    <cheesy porno music>
    Ginge, Sep 1, 2004
  9. Gavsta
    porl Guest
    "Whoops, I've dropped my trowel."
    porl, Sep 1, 2004
  10. Steph wrote
    Once you have checked all the obvious things then: Easy-Start.
    Somebody else's strimmer almost always has a totally fucked/desperately
    in need of service motor in it. Often there is a "knack" to getting
    them started, especially when warm, Ether is a "knack" which works every
    time.
    steve auvache, Sep 1, 2004
  11. It was somewhere around Barstow, on the edge of the desert, when the
    "Hey, is that a dibbler in your pocket?"
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Sep 1, 2004
  12. Gavsta
    dB Guest
    erm, mine has a kill switch just like the bike, that isn't on as well is it?
    (just like my bike - but thats another thread)
    dB, Sep 1, 2004
  13. Gavsta
    Zymurgy Guest
    Only the Loz starting method. Choke off, throttle wide open.
    Yes. A fresh cat shit. And i'd seen it before I strimmed it. I thought
    it was a dry one but boy was I wrong :)
    I'm not googling for that ;-)
    Cheers,
    Paul.
    Zymurgy, Sep 2, 2004
  14. Gavsta
    Christofire Guest
    You did pump that little button didn't you? If you did I'll shut up as
    I have no idea.
    Christofire, Sep 4, 2004
  15. Gavsta
    mups Guest
    Christofire says...
    She did, however doing a Blaney sorted the problem. Our back garden has
    gone from rain forest to semi arid tundra. Much laying of turf is
    imminent I fear.
    mups, Sep 4, 2004
  16. mups wrote
    February.
    steve auvache, Sep 4, 2004
  17. Gavsta
    Eiron Guest
    The petrol pipe in my strimmer dissolved.
    Only the section inside the tank, so it looked ok from
    the outside. Brilliant idea to make a petrol-soluble
    petrol pipe.
    Eiron, Sep 4, 2004
