O.T. Ebay
Discussion in 'UK Motorcycles' started by tallbloke, Aug 30, 2005.
  1. tallbloke
    tallbloke Guest
    Someone on the group noted that ebay is running on Microsoft servers. This
    surprised me as I'd seen a 'powered by sun' logo on the site for ages, but
    Netcraft confirms it's true. I wonder when the changeover happened.
    I have noticed that recently, it often fails to do searches for completed
    listings. This morning even the 'ask seller a question' form is unavailable.
    How shite is that?
  2. tallbloke
    Ginge Guest
    What's to say they're not using both.
    IIS for the frontend webservers and Oracle on Sun for the backend DB?
    Ginge, Aug 30, 2005
  3. tallbloke
    tallbloke Guest
    Well the powered by sun logo has gone, so I'd guess not.
    And it's not working very well, which provides more circumstantial evidence
    IMO. ;-)
  4. tallbloke
    'Hog Guest
    I believe they are using some of both. It leaves me pretty speechless
    but I think I remember it was a corporate relationship decision rather
    than a technical solution....obviously.
    'Hog
    'Hog, Aug 30, 2005
  5. tallbloke
    Dr Zoidberg Guest
    The .com site still has the Java and Sun logos.
    I'd be inclined to blame Java more than anything
    Alex
    www.drzoidberg.co.uk www.ebayfaq.co.uk
    Dr Zoidberg, Aug 30, 2005
  6. tallbloke
    tallbloke Guest
    What, Sun standard Java running on a broken Microsoft JRE? I'd say it's the
    JRE that gets the blame rather than the Java programmers.
  7. tallbloke
    Maybe its only the front end processors that have changed? Big databases
    are best off running on a unix platform.
    Muck, Aug 30, 2005
  8. tallbloke
    mups Guest
    tallbloke said...
    IIRC the backend including the search engines are still running on Sun
    kit.
    mups, Aug 30, 2005
  9. tallbloke
    YTC#1 Guest
    Correct
    YTC#1, Aug 30, 2005
  10. tallbloke
    YTC#1 Guest
    The logo was up for grabs to the highest spender, the http://www.ebay.com/
    had "powered by IBM" until recently as we kicked up a bit of a fuss over
    what exactly was meant by "powered by" , oh and then paid some more moeny
    That will be the front-end then :)
    YTC#1, Aug 30, 2005
  11. tallbloke
    Christofire Guest
    Hasn't that drum got a hole in it yet?
    Christofire, Aug 30, 2005
  12. tallbloke
    Judge Guest
    Curious choice for a front-end, really. I'd put anything but Windows/IIS
    front-facing if I was starting with a clean slate.
    Judge, Aug 30, 2005
  13. tallbloke
    tallbloke Guest
    Must be getting well paid by M$ at a guess.
  14. my.ebay.com
    Device type: general purpose
    Running: IBM AIX 4.X
    OS details: IBM AIX 4.3.2.0-4.3.3.0 on an IBM RS/*
    my.ebay.co.uk
    eric the brave, Aug 30, 2005
  15. tallbloke
    Ginge Guest
    4.3.3 well, that's out of support.......
    Ginge, Aug 30, 2005
  16. tallbloke
    Judge Guest
    IIS does what it says on the tin IF you are very careful about how you
    construct your site AND hold its hand constantly.
    I used to blow the trumpet for MS solutions including IIS. I worked for
    years as a consultant concentrating on MS solutions and spent ten years as
    a journalist writing about nothing but MS stuff.
    When I started my company, it was a no brainer to install Windows servers
    and build all our client solutions on Windows.
    We now run some fairly busy web sites for clients but Windows & IIS are a
    recurring pain in the arse.
    IIS's memory management is so poor that MS had to bring out a tool,
    'iisreset', to kill/restart IIS processes that had chewed up too much
    memory.
    The endless round of security updates requires so much attention that we
    have had to appoint a patch manager. Each set of updates needs local
    testing before we deploy them because we've had servers shagged by applying
    crap updates.
    We now route all web requests to IIS through a firewall and then Apache
    first because new vulnerabilities can be exploited so quickly that you can
    find your web site taken over while you're having lunch.
    We're now in the process of replacing all our servers with Linux and Apache
    because we've had enough.
    Linux is more secure, more reliable, much more convenient, easier to
    maintain - and hasn't got a Registry.
    If you're still exclusively recommending Wintel, it is either because you
    think it is the politic solution or because you don't know all the
    alternatives.
    Judge, Aug 31, 2005
  17. tallbloke
    Ben Blaney Guest
    Yeah, Oracle/Solaris techies. Turkeys don't vote for Christmas, you
    know.
    Ben Blaney, Aug 31, 2005
  18. tallbloke
    Ben Blaney Guest
    Or because your client doesn't have any staff other than Wintel, and
    doesn't want to employ any beardie weirdies.
  19. tallbloke
    tallbloke Guest
    Cool, need a linux techy?
    tallbloke, Aug 31, 2005
  20. Or because the only languages and technologies that your programmers
    know is Microsoft. And your database programmers are SQL Server
    compliant..
    Phil
    Phil Launchbury, Sep 8, 2005
