O.T. F.O.A.K. viewing page source
Discussion in 'UK Motorcycles' started by tallbloke, Dec 17, 2004.
  1. tallbloke
    tallbloke Guest
    Internet exploder no longer fires up notepad when I select view --> page
    souce from the menu. I've an idea it may have beeen somehow disabled by some
    code on a page whose author didn't want it to be viewed.
    Anyone come across this before and know how it might be fixed?
  2. tallbloke
    tallbloke Guest
    Ah sussed it. rename shortcut to notepad on desktop to something else.
    Good old windows.
  3. tallbloke
    Domènec Guest
    There must be some easy way around IE, but the nerd way is to have CygWin
    installed and use wget to get the source of the URL.
    Also, the page you're interested in must be in IE's cache, so at the menu go
    to [1] Tools | Internet Options | General | Configuration | See files, and
    there you are
    [1] Translated from Spanish IE.
    Domènec, Dec 17, 2004
  4. tallbloke
    dwb Guest
    I have a shortcut to Notepad on my desktop (and quick launch bar) and
    View -> Source works fine.
    dwb, Dec 17, 2004
  5. tallbloke
    tallbloke Guest
    http://www.mredkj.com/tutorials/tips_ie.html
    If there is a shortcut to Notepad on the desktop, delete or rename it to
    something other than Notepad.
    JR wrote how to reproduce the problem, then solve it:
    Open IE, go to any page, view source, works fine.
    Now go to Start menu and navigate to "Programs\Accessories", and right-
    click
    on Notepad, drag it to the desktop, selecting "Copy Here" when you let go.
    You should now have a shortcut file named "Notepad" on your desktop.
    Go back to IE, view source, and nothing happens.
    Go back to desktop and delete or rename the Notepad shortcut.
    Go back to IE, view source, and it works again.
    * JR and Dave wrote two independent mredkj feedbacks about this solution.
    Yet I have not been able to reproduce it myself in the following
    combinations: NT/IE 5.5, Win2000/IE 5, and XP/IE 6. There must be other
    factors that cause a desktop shortcut to affect view source, such as
    Windows/IE patch versions and registry settings.
  6. tallbloke
    dwb Guest
    So we're both right? Suits me :)
    dwb, Dec 17, 2004
  7. tallbloke
    tallbloke Guest
    Hmm, the fix above worked for me, but ta anyway.
  8. tallbloke
    tallbloke Guest
    Maybe it depends on how you create the shortcut. i.e. rightclick on .exe
    select create shortcut. Or drag from startmenu.
  9. windows has a telnet client bundled free with it; 'nuff said.
    Peter Windridge, Dec 18, 2004
  10. tallbloke
    tallbloke Guest
    I could use the telnet client to poll port 80 with a wget command and
    redirect the output to a file which I can then open with notepad. However
    I do have a life and would rather just click the view source button
    really. ;-)
    tallbloke, Dec 18, 2004
  11. tallbloke
    Christofire Guest
    Are you sure? I thought you were one of those unixy types?
    Christofire, Dec 24, 2004
  12. tallbloke
    tallbloke Guest
    Please do summarise your caricature of a unixy type so we can all have a
    laugh. ;-p
    tallbloke, Dec 24, 2004
  13. tallbloke
    "unixy type" : someone who has any sort of opinion as to the relative
    merits of Linux -v- *BSD.
    Oh, and if you've got a pony-tail past the age of about 25, you're
    definitely a freak.
    darsy, Dec 24, 2004
  14. tallbloke
    flash Guest
    Sandals and socks.
    flash, Dec 24, 2004
  15. tallbloke
    prawn Guest
    <sheepish>
    How about long hair sans pony-tail?
    prawn, Dec 24, 2004
  16. tallbloke
    *guilty*
    darsy, Dec 24, 2004
  17. tallbloke
    prawn Guest
    Heh.
    prawn, Dec 24, 2004
  18. First up against the wall when the revolution comes.
    Next!
    Phil (unix geek sans long hair, sans sandals)
    Phil Launchbury, Dec 24, 2004
  19. tallbloke
    Christofire Guest
    You.
  20. tallbloke
    tallbloke Guest
    Merry f*cking Christofireness to you too :)
    tallbloke, Dec 26, 2004
