O.T. Safes
Discussion in 'UK Motorcycles' started by John, Apr 2, 2006.
  1. John
    John Guest
    Bought a safe from Macro couple of months ago.
    Now it's decided to not open, correct pin number, even with the bloody
    key, bastard thing.
    Thank **** I have the 'tool'. (ukrm patent) I'm gonna take it from
    behind. ;-)
    Thank **** never bolted it down in the small cupboard where it is...
    It's gonna be a sparky afternoon.
    John, Apr 2, 2006
  2. John
    Scraggy Guest
    Quicker by far
    http://peterman.org.uk/explosives.htm
    Scraggy, Apr 2, 2006
  3. John
    Eiron Guest
    Do let us know how many discs you use up and how many fingers you lose.
    You could take it to your local safe shop tomorrow and get him to try
    his magic fingers or one of his bunch of keys. You're probably not wiggling
    the key properly.
    Eiron, Apr 2, 2006
  4. John
    SteveH Guest
    I assume this one is an electronic PIN job. However, there should have
    been a cylindrical type over-ride key for it to use if the battery
    fails.
    I very much doubt an angle grinder will make much of an impression on
    it, they're fucking heavy, which suggests they're quite robust.
    SteveH, Apr 2, 2006
  5. John
    John Guest
    I've wiggled the **** to death.
    Yes, key doesn't work.
    3mm. I'll get through that.
    John, Apr 2, 2006
  6. Anything in there that burns?
    Si
    Mungo \Two Sheds\ Toadfoot, Apr 2, 2006
  7. John
    Catman Guest
    If it's anything like the cheap ones they sell, and tested in which, take
    the hinges off with a sledge in about 15 secs.
    www.cuore-sportivo.co.uk
    Catman, Apr 2, 2006
  8. John
    John Guest
    Ah, where do you hit it then? Would you care to enlighten me bearing
    in mind Which magazine copyright ;-)
    No seriously, door of the hinges?
    John, Apr 2, 2006
  9. John
    Catman Guest
    Hit down on the hinges. Or crowbar in the front. Things are basically tin
    foil.
    Catman, Apr 2, 2006
  10. John
    John Guest
    I cant see how you can 'hit down on the hinges', you cant get a purchase
    on the door at all.
    Same with the door, no chance to get any implement in to pry..
    I'm going to get my angle grinder out, ands thats the end of it. :)
    John, Apr 2, 2006
  11. John
    Catman Guest
    Sounds like you have a different one then. The ones on test had hinges on
    the outside, and you could get a jemmy of some kind in the door
    Hope the contents survive.
    Catman, Apr 2, 2006
  12. John
    .. Guest
    It will be either the battery is dead or dying or the electromagnetic catch
    is sticking or weak.
    The sliders are usually steel with an alloy arm.
    Grind off the heads of the hinge pins and lever accordingly from the hinge
    side.
    It'll almost fall apart.
    BTDTGTTS
    .., Apr 2, 2006
  13. John
    DR Guest
    That explains a lot.
    "Rosebud..."
    DR, Apr 2, 2006
  14. Grimly Curmudgeon, Apr 2, 2006
  15. John
    Owen Guest
    good moovie...
    Owen, Apr 2, 2006
  16. John
    Tosspot Guest
    Am I the only person on the planet who thought it was shite?
    Tosspot, Apr 3, 2006
  17. John
    Catman Guest
    I thought it was shite enough not to bother watching it all the way through,
    if that helps.
    Catman, Apr 3, 2006
  18. John
    zymurgy Guest
    Mine's the same, but key operated only. No external hinges at all, and
    quite substantial steel.
    P.
    zymurgy, Apr 3, 2006
  19. I've sat through it twice, the second time many years after the first in
    the hope that age (mine) had improved it. Slightly, but not much.
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
    Grimly Curmudgeon, Apr 3, 2006
  20. John
    Owen Guest
    No. It was. I was being thingy...
    Owen, Apr 3, 2006
Similar Threads
Loading...
