O.T. Ubuntu 9.10 weirdness....
Discussion in 'UK Motorcycles' started by Steve, Dec 16, 2009.
  1. Steve
    Steve Guest
    My dear old mum's PC needed a bit of a OS upgrade, and not wanting to
    spend on hardware (it is 5 years old), I opted for what I hoped was an
    OS to give the hardware an easier life and be easy for her to use.
    As she needs very little in the way of anything beyond internet, piccie
    browsing and some letter writing, I tried the Netbook version.
    Very slow operation and I found the CPU running at 100% constantly????
    Everything else appears OK, everything works, it just stutters along
    though. I've used the same CD for a couple of other applications (an
    Acer netbook and a IBM R52) and had no issues.
    Steve
    Steve, Dec 16, 2009
  2. Steve
    Andy Hewitt Guest
    Might be worth trying Xubuntu, which is a bit lighter. I installed that
    on a really old laptop my sister got, and it didn't seem too bad.
    Andy Hewitt, Dec 16, 2009
  3. Steve
    Simes Guest
    try #sudo top to see what's using all the cpu - could be just something
    easily fixable (like couchdb which will stop after a little while).
    Simes, Dec 16, 2009
  4. Steve
    Steve Guest
    Ta
    I'll give it a go
    Steve
    Steve, Dec 16, 2009
  5. Steve
    Switters Guest
    Dunno, why you asking us?
    One thing to watch out for (which won't be the problem in this case) is
    that IPv6 is enabled by default and if the router doesn't support it,
    you'll end up with a 20 second wait for nothing whilst the IPv6 DNS time-
    outs and it defaults back to v4.
    Disabling IPv6 is the way to go, without upgrading the router.
    Switters, Dec 16, 2009
  6. Steve
    prawn Guest
    As mentioned up there ^ somewhere, run top to see what is causing grief.
    It *may* be that system files are being indexed after install (I forget
    which indexing utilities are installed out-of-the-box.)
    Do an upgrade too before trying something else.
    Also: as mentioned in this thread, xubuntu will work well on low spec
    systems if you can live with <thinks> xfce?
    prawn, Dec 16, 2009
  7. Steve
    ginge Guest
    Actually Xubuntu isn't lighter any more.. but there is an easy fix
    using the LXDE desktop in place of gnome... Start wigth a regular
    Ubuntu install (not netbook remix).
    Next, install the "Lubuntu-Desktop" package.. Logout and then back at
    the login page change the session setting from Gnome to LXDE ....
    Login again ands as if by magic, a nice snappy desktop interface.
    Runs well enough for me on an old Pentium 700mhz laptop with 256Mb
    Ram.
    ginge, Dec 16, 2009
  8. Steve
    Andy Hewitt Guest
    That's pretty much the hardware I had installed Xubuntu onto. Like the
    tip though. Ta.
    Andy Hewitt, Dec 17, 2009
  9. Steve
    YTC#1 Guest
    Puppy Linux, its the future
    YTC#1, Dec 17, 2009
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, YTC#1
    Not Solaris, then?
    Wicked Uncle Nigel, Dec 17, 2009
  11. Steve
    YTC#1 Guest
    Not if you want something small and light that runs on slower procs :)
    YTC#1, Dec 17, 2009
  12. Steve
    Steve Guest
    Well, Xubuntu seems to have done the trick, as mouse operation is a lot
    smoother and the hard disk isn't chuntering away to itself.
    Time is a bit short ATM so the main thing was to install the OS and
    change the BT voyager modem to a modem \ router and get it up and
    running. XFCE is the desktop, and yes, she can live with it.
    All she needs is four icons - on, off, word processor and internet.
    Steve
    Steve, Dec 17, 2009
  13. Steve
    Switters Guest
    "Oooh, they got the internet on computers now"
    Switters, Dec 18, 2009
