Odd fettling events
Discussion in 'UK Motorcycles' started by Pip Luscher, Apr 25, 2010.
  1. Pip Luscher
    I gave the V11 some extra TLC today.
    New brake pads at the front; they went in without drama.
    I'd also noticed the other week that the rear wheel bearings had a
    tiny bit of slack in them and felt it was best to replace them early
    rather than too late.
    The old ones came out OK, better than I expected, though it could have
    turned nasty because one bearing outer had split all the way round the
    edge
    New bearings went in OK though initially the first one went a bit
    wonky until I changed around the press took I had improvised.
    Then th weird bit: getting the axle pin back in. It really, really
    wouldn't go through the bevel box. I could feel the end just poking
    out of the wheel side of the bevel box but it wouldn'r budge any
    further.
    After fifteen minutes of fruitless pushing, twisting and tapping, I
    pulled it out and had a look. All OK. I was sure I hadn't done anythig
    silly, just that the bevel box didn't quite line up with the swingarm
    hole. When I tried to push the bevel box forward, it resisted and
    sprang back. "Oh dear, what is the matter with the blessed thing" I
    thought, but not in so many words.
    After a bit of thought, I recalled that when I greased the splines
    last month, the shaft had extended slightly. So I undid the grease
    nipple and there was a brief sharp hiss. On the next attempt, the pin
    went in without further difficulty. Weird; never seen that before.
    As I was in a fettling mood and the valves had been sounding very
    tappety of late, I had a look at the valve clearances too. Worryingly,
    seeing as I only did them two thousand mile ago, they were way, way
    out. I'm now thinking about camshafts and oil delivery systems and not
    in a happy way.
  2. Pip Luscher
    Sounds like a fun way to spend an evening to me
    wessie, Apr 26, 2010
  3. Pip Luscher
    I was going to play a straight bat there but thought it might get
    misconstrued.
    Pip Luscher, Apr 27, 2010
