of Double Garages
Discussion in 'UK Motorcycles' started by 'Hog, Feb 15, 2010.
  1. 'Hog
    'Hog Guest
    Has anyone built one recently? Thermal block with brick skin or cavity wall
    brick sort of thing. Roof profile that allows plenty of storage without
    looking like a second storey.
    I can find prices for prefab stuff, but in York that's baiting the Planners,
    nothing for conventional construction though. So how much?
    So many things have become bizarrely expensive in Engerland. Colleague round
    corner just had a single car size garage added to the end of his house, with
    a room above and the original roof line extended. Eighty Fucking Grand.
    "Mostly labour" he said. Good grief a team of 6 blokes working for a month
    could build an entire fucking house, but lets imagine they only achive a
    3x9m 2 storey extension. 960 man hours. <shakes head>
    'Hog, Feb 15, 2010
  2. 'Hog
    crn Guest
    Just hire the skills that you need from an agency. Thats what the building
    contractors do and then multiply the agency rate by the date.
    crn, Feb 15, 2010
  3. 'Hog
    Get quotes. Ask around for recommendations.
    I had a 12' x 24' single garage built about 12 years ago, single skin,
    pitched roof, about £8k. Single storey extension, 13' x 25', about 6 or 7
    years ago, £20k-ish.
    platypus, Feb 15, 2010
  4. 'Hog
    No, but I will be next month if all goes to plan.
    For a garage?!? **** that!
    Shedloads if you pay someone else to do it. Probably under 1500 quid if
    you DIY & forget about brick skins & cavities.
    Krusty, Feb 15, 2010
  5. 'Hog
    'Hog Guest
    Are you suggesting that garages shouldn't be warm and cozy? My house in
    Scotland had a 3 car garage built with cavity wall and d/glazing as well as
    heating. It's fanastic and encourages fettling into the wee hours rather
    than watching TV or playing WoW. Getting a windproof seal around the
    up/over doors was the hard bit.
    You can also store stuff without mildew growing.
    Do I look like an Oirish Fucking Navvy.......
    'Hog, Feb 15, 2010
  6. 'Hog
    If you might want to turn it into a habitable room a couple of years down
    the line...
  7. 'Hog
    No, but if you want it warm & cozy, single skin block with insulation
    on the inside will be far better & cheaper.
  8. 'Hog
    ....you have to build it completely differently to meet the regs e.g.
    floor/roof insulation. And if you're not worried about regs, you can
    just add insulated stud walls to convert it.
  9. 'Hog
    ginge Guest
    http://www.planningportal.gov.uk/en...kcommonoutbuildings/workmorebregsoutbuilding/
    Building a detached garage of less than 30 square metres floor area
    would not normally need building regulations approval if:
    * the floor area of the detached garage is less than 15
    square metres.
    * the floor area of the garage is between 15 square metres
    and 30 square metres, provided the garage is at least one metre from
    any boundary, or it is constructed from substantially non-combustible
    materials.
    So forget the planners and go prefab with 29.95 Sq M of floorspace.
    ginge, Feb 15, 2010
  10. 'Hog
    'Hog Guest
    Fair comment. But I think it needs to be red brick outer.
    'Hog, Feb 15, 2010
  11. 'Hog
    'Hog Guest
    Yeahbut it's quite a nice old red brick house and TBH I'd rather it matched
    anyway.
    as Krusty suggests, single skin with an insulation layer and drywall inside
    isn't a bad plan.
    A steel frame with brick forming the walls would be a nice and quick system.
    'Hog, Feb 15, 2010
  12. 'Hog
    ginge Guest
    I pasted the wrong link earlier, this is the one saying no planning
    permission needed..
    http://www.planningportal.gov.uk/england/public/buildingwork/projects/workcommonoutbuildings/
    Also you can get Brick finish on prefab these days
    http://www.comptonbuildings.co.uk/Concrete+Garages/Apex+Brick+Garages/Garages.chtml?intProductID=29
    ginge, Feb 15, 2010
  13. I'd strongly suggest that you used some sort of cavity block to stop
    condensation. I've got a single-skin garage and besides getting fucking
    cold it's been a bugger to stop condensation and water being driven
    through the single skin wall.
    Agree completely on the DIY point though.
    stephen.packer, Feb 15, 2010
  14. 'Hog
    We went for one of those, only the posh Banbury Spar job. Been there about
    7 years and very happy with the job. Compton sent a snagger after the
    installation to make sure all was well and, as detailed in another thread,
    did a good job of sealing the walls to the base.
    wessie, Feb 15, 2010
  15. 'Hog
    'Hog Guest
    That's the job, cheers.
    I'd seen brick effect facias for the front but not for the walls.
    'Hog, Feb 15, 2010
  16. 'Hog
    We had the garage made longer than standard with a wide side door. Room to
    park a car, as long as it's not a Daimler, plus have a bike or ride-on
    mower against the back wall. Bike/mower can be ridden out of the garage
    without shunting the car.
  17. 'Hog
    'Hog Guest
    I'm was thinking 911 length plus bike workshop/storage with side door. So
    4.5m plus. ~8m. Something like WUN constructed.
    'Hog, Feb 15, 2010
  18. Racedeck flooring?
    doetnietcomputeren, Feb 15, 2010
  19. 'Hog
    'Hog Guest
    Heh I don't think you can get that in the UK.
    I last used some oil resistant cushion lino with some spare office carpet
    tiles around the bike ramp area.
    'Hog, Feb 15, 2010
  20. Perhaps not Racedeck - but certainly other brands:
    http://dynotile.co.uk/ for example.
    Yuk.
