[OffT] Help files
Discussion in 'UK Motorcycles' started by William Grainger, Mar 4, 2004.
  1. Does anyone know anything about windows help files?
    I've got a (bought in) application, with an "incomplete" help file,
    and I want to add sections to it that are site specific...
    Is there a free way to do this?
  2. William Grainger
    antonye Guest
    Don't know if you can decompile the help file and it
    depends what type it is - Windows .hlp or their
    later HTML equivalent .mht, but there are certainly file
    compilers as part of the resource kits.
    IIRC, the old .hlp files were compiled from RTF files
    with suitably placed text in them for markers, not
    unlike HTML. The newer ones are obviously HTML based
    and should be easier to create.
    Try:
    HLP
    http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=microsoft+help+compiler
    HTML
    http://msdn.microsoft.com/library/default.asp?url=/library/en-us/htmlhelp/html/vsconwhtsdll.asp
    antonye, Mar 4, 2004
  3. William Grainger
    Pete Lees Guest
    William,
    What is the format of the help file -- WinHelp (.hlp) or HTML Help
    (.chm)? If WinHelp, you can decompile the .hlp file using Help
    Decompiler, which is available from:
    http://www.helpmaster.com/hlp-developmentaids-helpdeco.htm
    Once you've modified the source .rtf files, you can recompile the help
    file using Help Workshop, available from:
    http://www.helpmaster.com/hlp-developmentaids-hcw403.htm
    If HTML Help, you can both decompile and recompile the .chm file using
    HTML Help Workshop, available from:
    http://msdn.microsoft.com/library/en-us/htmlhelp/html/hwMicrosoftHTMLHelpDownloads.asp
    However, I'd recommend performing the decompile half of the operation
    with KeyTools, as that will re-create the project (.hhp) file that
    you'll need in order to recompile later. Decompiling with HTML Help
    Workshop will give you everything *except* the .hhp file.
    http://www.keyworks.net/keytools.htm
    All that said, there's a drawback to WinHelp/HTML Help decompilation
    that may make you want to proceed with caution: the
    decompile/recompile process isn't a "round-trip" process; not
    everything that the help author put into the original file is
    recoverable when you decompile, so some features may stop working.
    This would particularly be the case if the help file is set up to
    provide context-sensitive help for the application, but other features
    such as the index may no longer work. At the least, it's best to make
    a backup copy of the original help file before you tinker with it.
    Pete Lees, Mar 5, 2004
  4. William Grainger
    Christofire Guest
    Thanks Pete- very useful site.
    Christofire, Mar 5, 2004
  5. Cheers, useful to know...
    William Grainger, Mar 5, 2004
  6. Again, useful stuff. Cheers.
