....poorly car. [MEDIA=youtube]vP-XxL90gEg[/MEDIA]
Thats sounds more a very badly fucked UJ of some kind. -- Nige, Land Rover 90 Yamaha R1 Range Rover Vogue
Remove the traffic warden from underneath it. Does that model have a live axle or IRS? Sounds like it might be a uni joint if IRS.
Just jack it up on axle stands so the back wheels are off the ground, run it, and see where the noise is coming from. Sounds expensive to me but ICBW.
IRS - when I had it jacked up off there was a a lot of slop in the wheel bearing. UJ's looked ok but I didn't check properly (the outer one is hidden away). Noise definitely coming from the hub.
The brakes are in-board and the noise is definitely coming from the hub. The bearing is very sloppy when I had it jacked up. I've heard bearings like that (it was on the banger track though). Thursday is the day it gets taken apart so prace bets now!
I need to have the hub apart to check but there is a lot of slop from the bearing and spinning it by hand with wheel off the noise is definitely coming from the hub. I won't know for definite until Thursday when I have it in pieces.
Doh - of course, they are inboard disks. I was thinking the noise sounded like drums. [1] [1] cue old Geordie joke.
It does sound more UJ-like to the fickle ginger ear of fate - the bearing could well have broken up too, but that sound is distinctly UJish.
I will examine it in detail on Thursday - the excitement is killing me. Fortunately the prices shouldn't as the parts are pretty cheap (£28 for bearing set and £25 for UJ joint).
If that's yer wheel bearing, it will cost you more than that mate -- Nige, Land Rover 90 Yamaha R1 Range Rover Vogue
