# Oh, we march from here to there...
Discussion in 'UK Motorcycles' started by Eddie, Oct 13, 2008.
  1. Eddie
    Eddie Guest
    The Elefant hasn't been used for a while (possibly months, come to think
    of it), due to previously-mentioned front mudguard problems.
    This morning was the first time it's been out of the garage for ages,
    and it's not quite running right at low speeds, as if it's carb-icing a
    little bit (not cold enough, I'd have thought), or it's got a bit of a
    misfire. Seems okay at A-road and dual-carriageway speeds, it's just
    when pottering through villages that it seems a bit lumpy.
    I suspect it'll be much after some fresh petrol and giving it a damn
    good thrashing.
    Any other suggestions?
    Eddie, Oct 13, 2008
  2. Eddie
    C. U. Jimmy Guest
    Scrap it.
    C. U. Jimmy, Oct 13, 2008
  3. Eddie
    I'd suggest you go back to trainspotting.
    sweller, Oct 13, 2008
  4. Eddie
    Eddie Guest
    (Bear? Giving technical advice? What's the world coming to?)
    Oh, yes, indeedy. Starts with just the most delicate stroke of the
    button. You know, starting an Elefant is very much like making love to a
    beautiful woman...
    Eddie, Oct 13, 2008
  5. Eddie
    SimonM Guest
    Plugs?
    My (ex) gixxer ran like a pig following an extended lay off. Tried
    fresh fuel but it didn't run right until the plugs were changed.
    SimonM, Oct 13, 2008
  6. Eddie
    Eddie Guest
    Interesting suggestion.
    I wouldn't have thought that it would have started so easily if there
    was a problem with the plugs.
    Actually, that would also tend to rule out the stale petrol idea, so in
    the meantime I'm going for some fresh petrol and the good old "watchful
    waiting" cop-out solution.
    Eddie, Oct 13, 2008
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Eddie
    Stop fucking about and take it for an Italian tune-up.
    Wicked Uncle Nigel, Oct 13, 2008
  8. Eddie
    Eddie Guest
    Like "some fresh petrol and giving it a damn good thrashing", just as I
    said originally.
    Eddie, Oct 13, 2008
  9. Eddie
    SimonM Guest
    Yeah, well, I was sceptical that plugs could be causing my problems
    too. The bike would start fine but cough, fart and splutter at lower
    revs. Tried all the obvious stuff (including fresh fuel) but never
    managed to clear it. It was due a service so I mentioned it to the
    dealer when I dropped the bike in to them. "Bound to be the plugs" was
    service blokes response. He went on to say that additives in modern
    unleaded petrol fucked spark plugs up good and proper. Not sure
    whether that is true or complete bollocks. But right enough, when I
    picked the bike up it was running perfectly with new plugs.
    I've never had this symptom on any of my previous bikes though. Then
    again, this was the only bike I've ever laid up for a whole winter.
  10. Eddie
    Follow it up with a decent run across Europe in January.
    Andy Bonwick, Oct 13, 2008
  11. Eddie
    Pete Fisher Guest
    Was this the Morini ?
    | Pete Fisher at Home: |
    Pete Fisher, Oct 13, 2008
  12. Eddie
    Pete Fisher Guest
    said originally.
    [/QUOTE]
    A "dealer's decoke" often works wonders. Can be a kill rather than cure
    scenario though.
  13. It coughs, splutters and leaks vital fluids?
    The Older Gentleman, Oct 14, 2008
  14. Eddie
    Pete Fisher Guest
    Reads thread again properly. I see it was a gixxer.
    Such behaviour on the part of a Morini would not be unknown, but then
    their ignition system is endearingly idiosyncratic.
    Pete Fisher, Oct 14, 2008
  15. Eddie
    SimonM Guest
    Err.., no. The Morini isn't actually road legal at the moment but runs
    pretty well, all things considered. Must get round to sorting it a MOT
    and UK registration. The problems I refer to happened when I left my
    previous gsxr unused for a few months.
    SimonM, Oct 14, 2008
  16. Eddie
    Eddie Guest
    I would, but I can't afford it.
    Eddie, Oct 14, 2008
  17. Eddie
    Eddie Guest
    Well, it hasn't had fresh petrol yet, but it's had a bit of a thrashing.
    I also switched in the carb heater circuit last night, just in case it
    was a touch of carb icing, which seemed to be much more likely to happen
    this morning given the conditions.
    Seemed to be much happier this morning; I'll treat it to some fresh
    petrol once I get the capacious tank somewhere near empty.
    Eddie, Oct 14, 2008
