Oi Loz - ETA - who knows?
Discussion in 'UK Motorcycles' started by Lady Nina, Mar 25, 2008.
  1. Lady Nina
    Lady Nina Guest
    Of course the trouble with an intermittent starting fault is when you
    can't start it so you can go and get said intermittent starting fault
    looked at.
    I'm going to have another coffee and warm up a bit then go and have
    another go. If all else fails I'll ring Aunty Carol.
    Any point spraying easy start at it?
  2. 'It it wiv an 'ammer.
    Whinging Courier, Mar 25, 2008
  3. Lady Nina
    ginge Guest
    It'a an old bike, innit?
    Is there no turning of the starter at all? If so my bet is that the
    earthing strap from the negative feed to the frame will be loose or
    corroded.
    ginge, Mar 25, 2008
  4. Lady Nina
    Only really works well with diesels. However, it is very useful in
    diagnosing fuel faults.
    Spray easy start and it doesn't fire then it's likely to be ignition, if
    it does then it's probably fuel.
    sweller, Mar 25, 2008
  5. Lady Nina
    And here I was up and awake bright and early, waiting with the kettle
    all primed for your arrival.
    Get here when you can.
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 25, 2008
  6. Lady Nina
    not having read the presumably existing previous thread to this, I was
    somewhat confused by the message body, as the subject line had led me
    to believe this was going to be about the Basques.
    darsy, Mar 25, 2008
  7. Lady Nina
    Works on several levels.
  8. Lady Nina
    Lily the pink a pink a pink
  9. Lady Nina
    I'd rather not imaging Lozzo in a basque.
    darsy, Mar 25, 2008
  10. Lady Nina
    # I want the doctor to take a picture
    # So I can look at you from inside as well
  11. Lady Nina
    Lady Nina Guest
    I was obviously using the wrong approach, threats didn't work, so I
    walked out to the garage - 'come on gorgeous, it's sunny and we are
    going out to play' - started straight away.
    I'll just go and put petrol in and I'll see you in a sensible sitting
    at 70 mph time.
  12. Lady Nina
    Cab Guest
    Heh, you too?
    Cab, Mar 25, 2008
  13. Lady Nina
    OK
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 25, 2008
  14. Lady Nina
    *bang*
    platypus, Mar 25, 2008
  15. Lady Nina
    Cab Guest
    platypus wrote:
    Heh, I thought it was a nice reply too. :)
    Cab, Mar 25, 2008
  16. Lady Nina
    Beav Guest
    Not a lot if it's an electrical fault. Maybe blathering inside any (and all)
    connectors around the bike with ACF 50 would be a start though.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 25, 2008
