Oil change maintenance?
Discussion in 'Motorcycle Technical Discussion' started by Phil, Squid-in-Training, Feb 23, 2006.
  1. So I'm ready to change the oil in my bike, which has a nice dark golden
    color to it when I wipe it off the dipstick instead of the nasty brown that
    came out of the car I drove in high school.
    I'll be replacing the filter, too, but should I go ahead and drop the oil
    pan to clean out any sludge/contaminants? What are the chances that when I
    get the oil pan back on, the gasket will leak? Is it more likely a metal
    gasket, or some other material?
    Also, there's no easy way to tell whether or not the oil needs to be
    changed, right? I mean, if it looks okay (not black), that doesn't
    necessarily mean it's okay because the polymers in the oil may have gotten
    chopped up by the tranny, and I wouldn't know that unless I did a cold/hot
    viscosity test, right?
    I usually do trips of less than 2 miles per trip(40 miles per week), and the
    occasional 120-mile excursion. Obviously I should be changing the oil more
    than once every 4000 miles and definitely more than once every 8000 miles
    like the Honda manual says, right? Ninty-five percent of all engine wear
    occurs in the first 5 minutes of engine startup, no? I'm asking lots of
    questions because I did a lot of research that agrees with each other, but I
    always like to confirm with the crowd.
  2. Phil, Squid-in-Training
    fweddybear Guest
    Here is what I do.....I usually change the oil at the beginning of each
    season... i put on about 3000 miles each season... usually a little
    less.....in fact i change all fluids... tranny, oil, and clutch....well not
    all fluids.. i dont change brake or fork oil each riding season....
    If you let it go more than a few months, chances are it will start to
    break down. You should ride it more than 5 minutes mainly because you will
    get alot of condensation build up in the oil and you can notice this because
    it looks like suds and wonder where the hell that came from....that is no
    good for your crankcase.... you will need to let that "boil" off and thats
    what a good half hour ride will do for it....
    Here;s the thing... if you plan on keeping your bike for a long
    time..... change fluids frequently... after all how much can it cost to
    change fluids? for me it runs around 15 bucks a season... thats cheap
    insurance.....if you don't plan on keeping the bike for a long time... then
    I am not saying not to change the fluids, but it becomes sort of a non
    issue... you probably won't get as much mileage out of the engine, but its
    either pay me now or pay me later situation....no matter what...
    I am kinda anal about changing oil and filters in my cars... usually
    every 2000 miles....but i guess when something decides not to work anymore
    you have no say in the matter.
    Fwed
    fweddybear, Feb 23, 2006
  3. I figured if it came out black and chunky like old milk, or small animals
    came out with it, that it might be bad.
    Because it's a 37k mi bike?
    Good point. I'm glad I saved mine from such a grisly death.
    I was hoping to hear this. ;)
    Hmm... can you elaborate? Are you say hard service as in "don't exceed this
    mileage without doing X service?"
    I've read that elsewhere, too.
    Cover your a$$ mentality, right?
    Oh, I see what you're saying... engine wear and oil breakdown are two
    different things.
    I also picked up some diesel oil (Mobil Delvac 1300 15w40) for this oil
    change. I did my research at
    http://motorcycleinfo.calsci.com/Consumables.html and was pleased to find
    that I could pick up a Walmart-branded oil filter that was a high-quality
    rebranded Champion. The box also has qualitative comparison figures on it,
    and it says "tests independently conducted by Champion, Inc." or something.
    I was looking for some 20w-40 or 50, but stuck with the 15 because it was
    all they had. I guess it's probably not all that critical.
    Given that I have 5 bicycles and 1 motorcycles as my only forms of
    transportation, the moto will get some use ;)
  4. Phil, Squid-in-Training
    John Johnson Guest
    If your oil comes out chunky, you might consider dropping the pan.
    Anything less and forget about it.
    37k is higher mileage than many motorcycles here in the USA get to, but
    let's face it, that's not a whole lot of miles on a modern, water-cooled
    engine. There's no reason to expect significant wear on the bike unless
    the previous owner was ignorant or abusive.
    [snip]
    Well, some vehicles come with an oil change interval like this:
    x000 miles*
    *hard service interval (x/2)000 miles.
    Where "hard service" means some combination of: dusty, wet, short trips,
    extreme temperatures, radiation, petroleum-eating fungus, space aliens,
    etc. ;-)
    I don't know if you CBR has a "hard service" interval or not. If it did,
    you would probably do well to follow it, given your riding style (better
    to change the style a bit, but that's not always how it goes, etc.). If
    it doesn't, then going from 8k to 4k intervals would make sense, IMO.
    Perhaps 4k intervals with an additional change before winter storage
    (should such a thing occur). Changing oil before storage prevents any
    built-up water or acids from damaging the engine in storage.
    Some people change oil before storage (and use the cheapest stuff they
    can get) and after storage (back to whatever they usually use). I think
    that's overkill in almost all circumstances, but then it's not my bike
    either.
    Or maybe the oil hasn't gotten better enough, or the engine tolerances
    demand it, or any number of other possibilities. The point here is that
    if your manual says 8k miles, that indicates the instructions given the
    technology (engine and lubrication) of the day. Things have changed in
    the meantime (see oil quality, above). This might affect how you
    approach your oil change interval. I'd certainly argue against going
    less than 4k mile intervals unless you just really like to change the
    oil, or you ride so infrequently that it would only be one or two
    changes a year in any case.
    [snip]
    Heh, I've got my boots, one push-bike, and one motorbike. The push-bike
    just blew the rear shifter (the thing on the bars, not the derailleur),
    and the bike's old enough that replacing it very likely means doing the
    whole drive-train because of changes in bicycle components. If that's
    the case, a used bicycle in reasonable shape would be similar in price
    (a perfect illustration of a machine becoming uneconomical to repair).
    Later,
    John
    John Johnson, Feb 23, 2006
  5. Ah, the joy's of year-round Florida riding ;) No need for storage or
    anything. Just the choke on cold days... I've been trying to avoid using
    the choke at all these days after the local shop told me my plugs were
    fouled. But ever since it's been hitting the high 70's in the last week,
    it's a lot easier to avoid the choke.
    I work at a bicycle repair shop, and virtually all shifter malfunctions can
    be attributed to grease gumming up. Shots of WD-40 or GT85 thins out the
    gum and allows the return ratchet to click into place. It happens all the
    time with 10+ year old bikes. Just find an open port in the shifter
    mechanism and insert the spray stick in there and spray around... actuate
    the lever many times over several hours, and it should begin to free up.
    My rear stand comes in the mail tomorrow... then I can get my hugger on and
    avoid wet feet syndrome ;)
  6. Doesn't the clutch run in the engine oil for wet clutches?
  7. No.
    Oh, and trips of less than two miles are a total waste of time and will
    kill an engine faster. Buy a bicycle.
    The Older Gentleman, Feb 23, 2006
  8. Phil, Squid-in-Training
    Brian Watson Guest
    I had assumed he has a hydraulic clutch - much like your hydraulic disc
    brakes.
    Brian Watson, Feb 23, 2006
  9. Phil, Squid-in-Training
    John Johnson Guest
    This isn't gum. I felt the ratchet break. The shifters are Old Shimano
    S100, the predecessor to the Rapidfires. It's a 7-cog rear and nobody,
    AFAIK, makes a shifter for these anymore. Combine this with the other
    issues that the bike has, and the fact that I'm writing my dissertation
    (so time is worth rather a lot to me just now), and I'd rather spend
    money on a new(er) bike than time on this one. As a grad student though,
    money is not spent lightly. ;-)
    But this is not the place for my bicycle woes. MY VFR on the other hand,
    works like a treat! It might even get warm enough this weekend for me to
    go for a ride.
    Huggers are most definitely a good thing. I installed a Pyramid hugger
    on the VFR and am overall pretty happy with it.
    Later,
    John
  10. Phil, Squid-in-Training
    fweddybear Guest
    I should have added that I should also change the brake and fork
    oil....it just seems to be a pain in the ass than the other fluids... my
    biggest fear is that i would never be able to replace the fork caps once I
    have taken them off....which is a lame excuse huh??
    Fwed
  11. Phil, Squid-in-Training
    fweddybear Guest
    In some bikes,. clutches use the engine oil, but in opther bikes, they
    have a separate case for their own oil.... I have two bikes... one uses the
    same as engine oil, and the opther uses different oil.
    Fwed
  12. I have five already, and I ride them most days. On my lazy days I don't
    want to get sweaty and smelly so that it drives away customers. It's uphill
    both ways to my destination. Think of it as my home in the middle of an
    impact crater.
    But I'm glad I have some time left in that engine...
  13. Phil, Squid-in-Training
    John Johnson Guest
    Fwed[/QUOTE]
    Check out this page for a fork maintenance walkthrough:
    http://darladog.com/forks/
    It's written specifically about cartridge forks, and it's a full
    tear-down, but the pictures will help even for your damper-rod forks
    (should you have them). It takes me about 1.5 hours to do both my fork
    legs when I do them; I call it "quality time" (but then I'm also a grad
    student).;-)
    When you get to step 2, you might find it helpful to wind on full
    preload. That exposes more of one of the locknuts, making it easier to
    remove the cap from the rod.
    As for getting the caps back on, don't forget to wind out all the
    preload! Then it's about the same difficulty as putting the cap onto a
    D-cell Mag-light (not terribly difficult, really).
    As for the brake and clutch, I bought with my father a MightyVac when
    working on the brakes on his car one year. I borrow it when I do my
    clutch and brake fluids!
    I've also put teflon tape on the threads of my bleeder screws to limit
    air bubbles getting past them (it works), and have never had problems
    with having to re-bleed.
    I can post more complete instructions for either procedure, but this is
    commonly-posted stuff, and it's in the archives, so check there first.
    Later,
    John
    John Johnson, Feb 24, 2006
  14. Phil, Squid-in-Training
    fweddybear Guest
    student).;-)
    [/QUOTE]
    John...
    thanks for the info!! i have bookmarked it and will look it over
    when i have more time to... probably on the weekend...I also have (service)
    manuals for both bikes, so i am sure it would be outlined in them as well...
    thanks again!!
    fwed
    fweddybear, Feb 24, 2006
  15. Phil, Squid-in-Training
    John Johnson Guest
    No problem. I say go for it. I was kinda nervous when I did mine the
    first time, but it turned out to be a piece of cake. You need to be a
    bit careful, but it's really straightforward and you'll be amazed at the
    difference in handling. Good luck with it.
    Later,
    John
