Oil dilution
Discussion in 'Australian Motorcycles' started by Fat Crack Ho, Jan 12, 2004.
  1. Fat Crack Ho
    Fat Crack Ho Guest
    Just changed the oil in my bandit 250 last night. When I filled the crank last
    oil change I filled it to the "F" mark on the window. Over 2500 km, the level
    went up quite a bit. When I drained the oil, 3.3L cameout. The oil didn't
    smell like petrol but it was runnier than the clean oil I filled it with (GTX3).
    I usually ride 15km each way to work, and go for a 30 to 50km ride every
    weekend. Would the oil thinning be caused by dilution or moisture absorbtion?
    I've checked the crank vent hose, it's clamped securly, so I'm pretty confident
    water didn't go in through here.
    Any thoughts?
    thanks.
  2. Fat Crack Ho
    FuTAnT Guest
    Chances are when you filled it perhaps the bike wasn't quite level or on
    it's side a bit. Sump oil is generally thinner than fresh oil as the polymer
    chains have been broken down and the oil is starting to degrade and also it
    tends to be a bit warm when you're draining it out, hence being thinner than
    cold fresh oil.
    How does 3.3L compare to what you put in? it doesn't mean much unless we've
    got some kind of comparison. I extremely doubt there should be any dilution
    (dilution from what I cannot think!) or moisture absorbtion as it seems to
    ride the bike enough to get the oil temp up to burn off any condensation
    etc. Any other volatile chemicals like petrol etc would have evaporated.
    Other than that .. hmmph, who knows. You sure it gained oil???
    Cam
    '03 954
    FuTAnT, Jan 12, 2004
  3. Fat Crack Ho
    Chris Coote Guest
    Water in oil will make the oil creamy, like, well, cream. fuel in oil will
    make the oil thin, smell like fuel A LOT and the other telltale will give a
    'burn' feeling on the wrist if dabbed on, like a solvent. non-diluted oil
    won't do this.
    Primay culprit is the floats- one of the carbs is allowing fuel through that
    it shouldn't. turn the fuel tap off at night and see if that fixes it.
    otherwise make sure the fuel tap diaphragm isn't burst or the hose from the
    fuel tap to the manifold (the vacuum line, a small diameter hose), or the
    smog fitment (if any still in place) isn't filling the sump via the
    manifold. I don't think there is anything particularly wierd about the fuel
    system on them. But I still go with the floats- bet you have a float stuck.
    its a carb-off job to clean them properly. Have fun!
    Chris
    Chris Coote, Jan 12, 2004
  4. If water got into it go milky white.
    and if fuel was mixed in with it, well they don't mix, so it be sitting
    ontop of the oil or below the oil.. and probably wouldn't change the
    viscosity.
    Hope that heps crack ho
    www.mad-biker.com
    Mad-Biker.com, Jan 12, 2004
  5. Fat Crack Ho
    Theo Bekkers Guest
    My experience says brown.
    Petrol and oil don't mix? So what the **** am I putting into my
    whipper-snipper then? And what is that pre-mix stuff they sell in
    cans?
    Theo
    Theo Bekkers, Jan 13, 2004
  6. well that's 2 stroke, designed to mix :)
    Mad-Biker.com, Jan 13, 2004
  7. and it does separate, that why you have to shake the crap out of it before
    using it again..
  8. Fat Crack Ho
    Chris Coote Guest
    any oil will dilute in petrol- if it didn't you'd have mayhem on your hands.
    oil will go milky white with water, and if the oil has some carbon (eg
    older) a brownish. but still shitty looking.
    check that fuel system- it can happen anytime!
    Chris
    Chris Coote, Jan 13, 2004
  9. Eh? Can you explain this to me? Degradation products will decrease
    viscosity or is that temperature?
    Hammo
    PS does it matter if I'm not using synthetic oil, I wont have any polymes to
    break down, right?
    Hamish Alker-Jones, Jan 13, 2004
  10. Fat Crack Ho
    Theo Bekkers Guest
    "Mad-Biker.com Mad-Biker.com>" wrote
    Only if you leave it for a few weeks. There is a small chance it will
    be mixed just a little inside a crankcase.
    And would you believe that three litres of oil mixed with one litre of
    petrol smells like oil, not petrol.
    Theo
  11. I knew there was something wrong with you of late, you bloody petrol
    sniffer!
    Hammo
