Oil From the rear Drive.
Discussion in 'Motorcycle Technical Discussion' started by has2manykids, Apr 15, 2004.
  1. has2manykids
    has2manykids Guest
    1982 V45 Magna...When I drive I get oil coming out of the Breather on
    the top. I filled it to the spec my mechanic said and it still pisses
    out. Anything to worry about here with this??
    TRevor
  2. has2manykids
    Dan Carter Guest
    I assume you filled it to the bottom of the fill hole while the bike was
    on the centerstand on level ground. Given that, the brand of oil can
    make a difference. I had a batch of oil that spewed from the breather
    excessively, but I cured it just by switching to another brand.
    Dan Carter, Apr 15, 2004
  3. has2manykids
    Charlie Gary Guest
    It's normal. My rear gear housing is a very dark grey most of the time
    because of it. I just see it as a great indicator of "there really is oil
    in there". Nothing more than a pita.
    Later,
    Charlie
    Fix the e-mail address and it will get to me
    Charlie Gary, Apr 15, 2004
  4. has2manykids
    has2manykids Guest
    I am using Honda Brand 80-90 Gear Oil. I bought it from the Dealer so
    I thought it would be ok But I will try a different type of oil.
    Thanx
  5. has2manykids
    Cees Keyer Guest
    wrote:
    ^^^^^^^^^^^^^^^^^ You might use a different kind of lubrication in that
    department too :)
    I always use castrol syntrax hypoid oil is great and the wear on a bmw
    final gear was almost zero. After 200.000 kM say 140000 Miles.
    On the mG site they have a message don't use syntrax it's to slippery,
    the gear box won't shift gear then.....
    Cees
    Cees Keyer, Apr 16, 2004
  6. has2manykids
    sammmm Guest
    what does the owners manual say for the level?
    i had a bike in that the owner filled. i got 9+ quarts out of the drain.
    something's wrong.
    i would check further.
    good luck, sammmm
    sammmm, Apr 16, 2004
  7. has2manykids
    Charlie Gary Guest
    The owners manual I have says fill it to the fill hole.
    I recommend checking your measuring cup. Those housings will not hold
    over two gallons of fluid. :)
    Later,
    Charlie
    Charlie Gary, Apr 16, 2004
