Oil question
Discussion in 'Australian Motorcycles' started by Yeebok, Sep 6, 2007.
  1. Yeebok
    Yeebok Guest
    OK I went and got some oil and a filter today. I've gone to do the job
    and I have 20w/50 oil (silkolene comp4 purchased with the filter) but on
    the screw thingy it says '10w/40'.
    Should I get the same oil or is that OK to use ?
    As you can tell I have no idea.
    Yeebok, Sep 6, 2007
  2. Yeebok
    VTR250 Guest
    It may be possible to get a definitive answer from the service manual
    (depending on whether you can get it).
    The owner's manual might say, otherwise you may be able to get the
    workshop manual off the internet.
    Failing that, phone the dealer and ask someone in the workshop.
    What is the make/model? Are you in SA?
    VTR250, Sep 6, 2007
    Dave Milligan, Sep 7, 2007
  5. Yeebok
    Theo Bekkers Guest
    Spit it out Dave.
    Oils is oils. 20/50 isn't gunna hurt your bike Yeebok.
    Theo
    Theo Bekkers, Sep 7, 2007
  6. Yeebok
    will_s Guest
    Same here. Went to the book and it said something like 10w/40 but ended up
    ringing my bike dealers and was told Shell Advance SX4 which is 15w/50
    will_s, Sep 7, 2007
  7. Yeebok
    Yeebok Guest
    To answer all the questions, the bike in question is a 2005 Hyosung
    GT250.. my alleged purpose of getting the bike was "just to ride to
    work" which has shrunk to a (saddening) 3km of late since I moved. The
    long way to work's 5km and goes past all the beaches so it's not all
    bad. However I like it so much it gets a lot more use, I've put 5000km
    on it since I got it around March.
    Kinda embarassingly, to me this is a major job. I work with PCs, not
    these confusing moving part things, dammit.
    I've read the manual which says 1.8l of 10w/40 and so does the filler cap.
    I have appropriate tools available to take off the 4 bolts I need to rip
    the skin off my knuckles undoing, and something to catch all the crap.
    Basically the process is -
    warm it a little
    undo filler
    remove sump nut (with probable swearing)
    drain most of it
    take the 3 filter bolts off and the cover
    take out the filter
    make sure there's no oil left in it
    redo the sump plug (with probable swearing)
    pop in the filter
    Do those bolts up
    Fill it carefully
    do up the filler cap
    optional :
    making a mess with oil
    getting in trouble for above
    That about right ?
    Yeebok, Sep 7, 2007
  8. Yeebok
    Yeebok Guest
    warm it a little
    undo filler
    drain most of it
    take out the filter
    pop in the filter
    Do those bolts up
    Fill it carefully
    optional :
    That about right ?
    Yeebok, Sep 7, 2007
  9. Yeebok
    MrMoped Guest
    Just a couple of extra points
    1. replace the sump plug washer - they are a crushable sealing washer, cheap
    as chips and will stop any oil leaking from the sump plug because one was
    too cheap to get a new washer.
    2. Don't do the sumplug up so tight that you stand in danger of stripping
    the thread - bad juju
    3. I haven't seen the filter setup on these but if the cover plate has a
    gasket either renew it (they are as cheap as chips) or use some good quality
    goolie-gum to ensure that you don't leak oil from the cover plate. If the
    oil filter is one of the spin on jobbies, put a smear of oil on the rubber
    seal before screwing the filter on.
    4. Have a beer or glass of plonk or whaever handy - makes the job so much
    more enjoyable.
    other than that you've pretty much got it sewn up.
    MrMoped, Sep 7, 2007
  10. I'd add recheck the oil level after running the motor for a short while,
    approx. 1 min., the new filter can soak up a fair bit of oil and lower the
    level.
    Capt. A. L.
    Capt.about_lunchtime, Sep 7, 2007
  11. Yeebok
    Theo Bekkers Guest
    People who wear latex gloves to change the oil in their bikes probably wear
    condoms whe they have sex with their wives. People pay a fortune for oils to
    rub on their skin.
    Theo
    Beer mate?
    Theo Bekkers, Sep 10, 2007
  12. Yeebok
    Theo Bekkers Guest
    Why would you own a Kia Rio in the first place?
    Theo
  13. Yeebok
    Yeebok Guest
    If you could afford one of them surely another bike was the better
    choice ? :)
    Yeebok, Sep 10, 2007
  14. Yeebok
    Yeebok Guest
    OK so here's how it went down.
    Warmed the motor
    Undid the filler cap and cleaned it off with a cloth nappy then put it
    down on another clean nappy.
    Bunged 3 big Moccona glass coffee jars under the bike on a clean nappy
    undid the sump plug
    the spanner managed to spin round and whack a jar. Lucky I had 3. (bonus
    points already for not whacking my knuckles!)
    Loosened the bolt and oil came out (into a jar)
    Dropped the now slippery bolt into the jar that was now half full
    Cursed (more bonus points!)
    Waited for an lull and placed a new clean jar under the bike
    Spilt a tad of oil but it was on the nappy.
    Waited for it to run dry
    Sat on the bike and leant side to side to get more out
    Opened the filter cover
    Spilt all the oil in there and watched it soak through the nappy
    (Going by the manual there's drain for the filer itself ?? Odd)
    Cursed a good deal
    Cleaned the spring and filter cover off with the clean nappy
    Got a new jar and siphoned off the old oil to see the crap on the
    bottom. Anyway, no metal.
    Put the old filter in the fullest jar
    Cleaned the sump bolt with the nappy
    Checked I had all the bits sat there clean (4 bolts, spring, cover, new
    filter and oil) all good
    Replaced the sump bolt after wiping its hole (eww)
    Replaced the filter and put on the cover
    Chucked in a bit less oil than the book said
    Checked the level
    All good. Replaced filler cap
    Started the bike and let it run a few seconds.
    Sounded OK so checked the oil, a little low so I topped it up.
    Thought to myself "That wasn't so bad" and turned to see the spring on
    the nappy.
    Sighed.
    Undid the filter cover and watched all the golden oil run out, quickly
    inserted the spring and wiped the cover and bolted it back up.
    Cleaned outside of it all (and the floor now)
    Started it - was OK so let it run a minute.
    No leak at all.
    Took it for a run for 5 minutes and checked for a leak of which there
    was a minor one. Cleaned it off and tightened the bolts about 1/16 turn.
    A smear since, but I presume that's remains from the initial leak. I'll
    know more tomorrow I guess but no leak or smear today.
  15. Yeebok
    bikerbetty Guest
    surely not as icky as baby's bum, Yeebs!!!!!
    So is your little one now nappyless after you used up all the supplies
    today?
    Bravo - I'm
    betty
    bikerbetty, Sep 10, 2007
  16. Yeebok
    Resound Guest
    I missed the bit where you topped up the oil again after letting most of the
    new stuff out and checked the level before you went for a ride. Or was that
    why there was only a small leak?
    Resound, Sep 10, 2007
  17. Yeebok
    They're a perfect car for motorcyclists!
    Knobdoodle, Sep 10, 2007
  18. Yeebok
    Boxer Guest
    They handle much beter on 2 wheels?
    Boxer
    Boxer, Sep 10, 2007
  19. Yeebok
    Is that like "I'm [pause 1..2..3...] Peter Hervey...."
  20. Yeebok
    Handle? It's a car; who gives a ****!
    They can carry 5 people and are really cheap to buy, rego, insure and run.
    What more would a motorcyclist require from a car?
