Old Pac Hwy - legality of conflicting Speed Limit and Speed Advisorysigns ?
Discussion in 'Australian Motorcycles' started by alx, Jun 10, 2009.
  1. alx
    TimC Guest
    Consistency heh. There are plenty of signs where you can safely go x2
    on the bike and maybe x1.5 in a car *most* of the time. But there
    have also been planty of curves I've met where my "safe" speed seems
    to be about the advisory sign. From memory, Tasmania is one of those
    states where the signs seem more likely to reflect reality.
    There's some roadworks near here where I was surpised that I had to
    keep to 40. Ok, gravelly off-camber corner down to a dip, around a
    bridge being ripped out, but I definitely was surprised by how much
    speed I had to wash off.
    TimC, Jun 11, 2009
  2. alx
    Nev.. Guest
    Is that scenic route sign a legal speed limit sign also or is the 40
    marking on it merely there for demonstrative purposes?
    Nev..
    '08 DL1000K8
    Nev.., Jun 11, 2009
  3. alx
    alx Guest
    There be two signs in one..those crafty moneysaving smart people at
    Council :)
    alx, Jun 11, 2009
  4. alx
    alx Guest
    And you can safely ignore the Scenic Route..it's only an advisory sign
    and you won't get booked for not looking at the scenic stuff.
    alx, Jun 11, 2009
  5. alx
    Heh! I remember hearing about 20 (maybe 30) years ago of some unknown
    body from around my hometown going for a drive in the middle of the
    night sawing off dozens of signposts at ground level, unbolting the
    signs and making off with the poles.
    It was speculated that they were making a nice set of sheepyards or
    something. ;-)
    BT Humble, Jun 11, 2009
  6. alx
    gwd Guest
    I'm sure you are correct. There are local modifications to cater for
    such things as poorly designed curves (multi-radius, off camber) worn
    road surfaces, possible rock falls, possible slippery conditions,
    off-road obstacle proximity - the list goes on. Then there is the "We
    Know Better" mentality that pervades local, state and federal
    bureaucracies, and then there are legal advisers with different
    opinions in every branch and department of government. So consistency
    could be modified, much like in every other area of multi-government
    operation. The AustRoads manual remains the backbone though.
    gwd, Jun 12, 2009
  7. alx
    ross_w Guest
    This suggests that Council's intent is to respond to the incident
    during the June 2007 floods when a family was killed when their car
    fell into the space where a culvert used to be. There was a lot of
    criticism levelled at the Council's tardiness in getting the culvert
    fixed, and their lack of mitigating measures to make the road safe.
    My guess is that this is part of their attempt to be seen to be
    "lifting their game" and preventing a similar incident. One of the
    defences available under the Occupational Health and Safety Act is
    that you did all you could to avoid the problem occurring again.
    They're trying to demonstrate that. I still think it sucks, but the
    days of people using the OPH as their own personal racetrack are long
    over.
    ross_w, Jun 12, 2009
  8. alx
    alx Guest
    So they left the higher advisory speed signs up for the so-called
    dangerous corners subjected to rock falls?
    Gosford Council Works Dept still have some processes to work through
    LOL.
    alx, Jun 12, 2009
  9. alx
    alx Guest
    It has occurred to me, on not so rare occasions, to step off the bike
    at Mooney Mooney and await passing patrol car with moontanned buttocks
    exposed.
    alx, Jun 14, 2009
  10. alx
    CrazyCam Guest
    ....and you know what that will get you.
    regards,
    CrazyCam
    CrazyCam, Jun 14, 2009
  11. alx
    alx Guest
    more than a slap on the wrist methinks.
    alx, Jun 15, 2009
  12. alx
    Nev.. Guest
    Why do you think the road toll would would drop if you stopped warning
    drivers about approaching bends in the road, particularly motorcyclists.
    Most rural motorcycle fatalities occur on bends, usually where the
    rider has approached the bend too quickly for the circumstances or their
    particular skill level.
    Advisory speed signs indicate to a driver that the corner they are
    approaching might not be taken as quickly as they might expect. For
    example if there are a series of bends which are easily navigated at the
    speed limit followed by another bend which is not consistent with those
    preceeding it.
    Nev..
    '08 DL1000K8
    Nev.., Jun 16, 2009
  13. alx
    TimC Guest
    But in reality, every damn corner has a warning sign on it, rendering
    the warning useless. Cars left wrapped around trees should be their
    own warning, dagnammit.
    If nothing had warnings and everything had sharp edges, people would
    have to take life a lot more cautiously, which has been demonstrated
    more than once to cause people to take more care when driving for
    example in a city that had been laid out with no delineation between
    "pedestrian space" and "car space".
    Bring back the spike in a steering wheel, I say.
    TimC, Jun 16, 2009
  14. alx
    Nev.. Guest
    Why is the warning useless? If I approach a corner with a 65kph
    advisory, followed by one with an 85kph advisory, followed by one with a
    45kph advisory... all of these signs give me useful information about
    the corner I am approaching. They don't need to be accurate, they just
    need to be consistent, which they usually are. The next time I approach
    a corner with a 65kph advisory I know I should expect it to be about the
    same as the first corner above. I am not going to start ignoring them
    just because there are too many of them. I only ignore the signs I have
    seen before on familiar roads.
    Nev..
    '08 DL1000K8
    Nev.., Jun 16, 2009
  15. alx
    Andrew Price Guest
    Listened to something interesting on Late Night Live this morning (ABC pod
    cast, for those of us that are trying to stay straight, avoiding drugs and
    staying up late)
    Total fatalities from all wars, genocides, ethnic cleansing, internal purges
    etc in the 20th century - say 150m people
    Anticipated trauma deaths from road accidents, particularly in developing
    countries that industrialise in the 21st century - 151m people.
    Sort of puts global warming into perspective, nes't pas?
    For mine its in the roads kiddo - get that right (and it requires $) and you
    will save lives - all the rest of it - airbags, driver education,
    enforcement of traffic regulations pales into insignificance compared to
    separated carriageways which dramatically reduce collisions.
    This I would like to see people campaigning for - and chance would be a fine
    thing Hortense ...
    Best, Andrew
    Andrew Price, Jun 16, 2009
  16. alx
    Nev.. Guest
    I never said anything of the sort. I wish you would learn how to use
    usenet.
    **** that. What kind of rider wants every road ruined by turning it
    into a dual carriageway?
    Nev..
    '08 DL1000K8
    Nev.., Jun 16, 2009
  17. alx
    GB Guest
    Separated carriageways certainly render collisions between vehicles
    far more difficult to achieve but there's nothing to suggest that
    putting people to sleep while they're driving will have the effect
    of reducing single vehicle accidents. As the cancer that is the
    dual carriageway proliferates, I predict a sharp increase in single
    vehicle accidents.
    GB
    GB, Jun 16, 2009
  18. alx
    theo Guest
    Look Andrew, this planet is overpopulated as it is. If we halved the
    current population we would only be back to 1970 levels. Still too
    high. We should be encouraging people to step off the edge, not save
    their lives so they can breed more people.
    Geez.
    Theo
    theo, Jun 17, 2009
  19. In aus.motorcycles on Tue, 16 Jun 2009 21:20:20 -0700 (PDT)
    And just how many kids did you produce?
    Zebee
    - who notes none so hard on current sinners as a reformed one
    Zebee Johnstone, Jun 17, 2009
  20. alx
    theo Guest
    Three, all before 1970. They have produced 6, with four partners.
    Theo
    theo, Jun 17, 2009
