Hi All, Got a 1994 Volvo (sorry) 940 Turbo Estate. More and more regularly now it's cutting out. Tacho drops to zero (even if the wheels are still turning the engine) and Lambda light comes on. Leave it a minute or so and it will restart and drive normally - until it happens again. Seems mostly to happen after a hot restart - not so often when cold. Now the fault code that is set (although it doesn't set a code every time) is 1-4-4 - no fuel load signal. My first thought was the ever troublesome fuel pump relay - but with the tacho dropping too it could be the ignition amplifier on the front inner wing... Or am I wrong? Checked all the connections to the AMM and to the ignition module on the wing and to the sensor just downstream of the AMM - all look good - clean and tidy with a smear of grease on them. Any thoughts would be jolly helpful!
