One for the SOBeemeristi
Discussion in 'UK Motorcycles' started by Gyp, Oct 9, 2005.
  1. Gyp
    Gyp Guest
    Ebay item 4580471177
    (restored R54/65)
    Gyp, Oct 9, 2005
  2. Gyp
    Gyp Guest
    Certainly would. I've seen just shy of 120 on the speedo of my R65 in
    top with the needle in the red, so R65 gearing is a must! Motorworks do
    used bevel boxes for £135, but you can buy a 35 tooth cog to replace the
    31 tooth cog.
    Then again, with R45 gearing you could maybe wheelie off the throttle
    Yes please. I have visions of Taz from the cartoons
    Gyp, Oct 9, 2005
  3. Gyp
    Gyp scribbled on the back of a napkin:
    Experience with one suggests that an R65 really isn't up to pushing any
    kind of fairing unless you're a lot more patient than I am.
    Timo Geusch, Oct 9, 2005
  4. Gyp
    Bear scribbled on the back of a napkin:
    Probably, but then again IME the standard R65 is not really up to
    pushing a big fairing along. BMW tended to lower the final drive
    gearing on the bikes with larger fairings for that reason.
    Has anybody pointed out to him recently that this particular joke is
    getting just a tad old?
  5. Gyp
    Gyp Guest
    Good point. Mine pushes its RS fairing well enough, but I expect that
    the aerodynamics of the RS are significantly different to this one on
    eBay. TBH, if I were to buy it (which I'm not going to do), I'd be
    looking to remove the fairing and return it to its original naked look
    Gyp, Oct 9, 2005
  6. Gyp
    Timo Geusch says...
    Had no-one noticed I hadn't taken the bait?
    Lozzo, Oct 9, 2005
  7. Gyp
    Lozzo scribbled on the back of a napkin:
    We did, and we're soooo proud of you.
    Timo - the Anti-Lozzo
    Morini Corsaro 125 | CB450K4 | R1150GSA | XL250 Motosport | 900SSD
    GPz 550A
    BOTAFOF #33 TWA#10
    The UKRM FAQ: http://www.ukrm.net/faq/index.html
  8. Gyp
    <unmoved>
    If I was looking for a naked Beemer, I'd go for a 100/7 - which,
    interestingly, the panniers from that bike would suit, being as they're the
    ones with the cutaway in the top.
    platypus, Oct 9, 2005
