Got up early this morning (well, for a Sunday) and went out for a short ride on the ZXR. Did normal hooligan tomfoolery over about 25 miles. Turned around and started to return the way I'd come. I'd just overtaken a car and everything went dead, flicked the kill switch, ignition switch... nothing. Hit the horn, nothing. Fuck. Pulled over into a conveniently situated pub car park and looked at the fuses- 30A fuse gone, great. Put in the spare (which I had checked was good when I bought the bike and... ignition on... pop. Fuck. One step back. Got a lift home. Got to work on the K75, I've replaced the clutch and given it a fairly extensive service over the last two weekends. Put in the wiring for a temperature gauge (but no gauge because part of the loom is lost in my garage. Also repaired the tank, once I'd wire brushed it the small hole was the size of a match-head and there was a matching one on the other side of the tank 'lobe' (this was the lowest point of the tank. Odd. Still, gave it a good coat of some fuel tank stopper from the outside and also smeared a bit on the inside. Waited for it to dry, sanded it down, applied some more, sanded, painted... and finally left overnight with a little fuel in it. It's not leaking (at the moment). Put it all back together and hit the starter, after about 10 seconds to pressurise the fuel system it started. Huzzah! Took it out for a spin, it managed just about 105 on an uphill section which was more than acceptable (ZXR750 manages about 135 there). One step forward. Return for ZXR750. About two hours fucking around finding a trailer and vehicle and getting there. Bloody sunday drivers. Grr. Got bike home and left it in the dunces corner of the garage. Still, got to have a pint in the afternoon which made a pleasant change. K100's been stinking of fuel for about 9 months. Maybe a year... Thought I ought to have a look a couple of weeks back. The fuel rail (it's injected) was wobbly but the bolts were tight. The injectors have an O-ring top and bottom, I ordered new ones. My these are a fucker to get out. Got them out and sure enough the joint between the injectors and the cylinder head is not very good- dull and corroded. Cleaned up and replaced O-Rings and put everything back together. Hit starter for a few seconds and it started... two steps forward. Right... so that's two bikes fixed, one bike broken. I call that a result for a weekend. So next weekend... ZXR750 electrical problems and K1100 service. Hmm... maybe a haircut too. Aren't bikes great?
