Oops... Tyre pressures
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Mar 5, 2009.
  1. The ol' GTR was a little squirelly this morning. "Hmm..." I think, "the
    rear tyre's getting a bit worn, wonder if it's that".
    Then the "Rear Tyre Pressure Low : 20 lbs/in2" caption pops up on the
    console, with an accompanying Big Red Light.
    Ah. That would explain it then.
    Fuckwit, I really should press that button more often.
  2. Wicked Uncle Nigel
    that's nothing. I was out on my 'blade one time, and thought the
    steering seemed a bit slow. Checked the tyre pressures, and there was
    ~10PSI in the front. That'd do it. Amazingly, it'd taken me about 20
    miles to notice.
    How does the real time pressure monitor actually work - is there a
    transponder in the wheel/valve?
    darsy, Mar 5, 2009
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, darsy
    It's in the wheel. I assume it's powered by some sort of moving weight,
    since it only works once the wheel starts moving.
  4. Wicked Uncle Nigel
    Simon Wilson Guest
    Or the sensor's in the right place - the sensor's are passive and
    powered by the receiver AIUI?
    Simon Wilson, Mar 5, 2009
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simon Wilson
    A big fat "Whatever" to that.
    Haven't a clue.
  6. Wicked Uncle Nigel
    Simon Wilson Guest
    You mean you own something and you don't know how it works?
    How very ukrm.
  7. Wicked Uncle Nigel
    Eiron Guest
    The ukrm way is to think you know how something works, while being quite
    wrong about it.
    And flame anyone who points out your error.
    Eiron, Mar 5, 2009
  8. Wicked Uncle Nigel
    Simon Wilson Guest
    No it bloody isn't! Why don't you stfu and crawl back to where you came
    from, you snivelling piece of usenet shite.
    <plonk>
  9. Wicked Uncle Nigel
    Fr Jack Guest
    My bruv has just had the rear sensor changed on his GTR, as it stopped
    working. The dealer says it should warn at 30psi (it has warned my
    bruv at that pressure, before it died), he also reckons a few people
    have had similar problems with the sensor.
    As 20 psi seems awfully low for a warning to be of any use, maybe its
    worth having it checked out?
    Fr Jack, Mar 6, 2009
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Fr Jack
    Turns out I've got a slow puncture in the rear tyre, so it probably
    dropped below 30 overnight.
    Tyre's fucked anyway, so I've bought a new one.
    Wicked Uncle Nigel, Mar 6, 2009
