Open University Ads
Discussion in 'UK Motorcycles' started by Catman, Jan 2, 2011.
  1. Catman
    Catman Guest
    Should I be worried that a group of people are depicted standing in
    front of a jet engine, that appears to be blowing their hair *backwards*?
    Just curious, like.
    #www.cuore-sportivo.co.uk
    Catman, Jan 2, 2011
  2. Catman
    Paul - xxx Guest
    They might know something about physics that everyone else doesn't ..
    Paul - xxx, Jan 2, 2011
  3. Catman
    Catman Guest
    Thrust buckets are noticeable by their absence of deployment.
    Catman, Jan 2, 2011
  4. Catman
    Catman Guest
    I do hope so.
    Catman, Jan 2, 2011
  5. Catman
    Chris H Guest
    Chris H, Jan 2, 2011
  6. Catman
    Pete Fisher Guest
    Fairy nuff. URL so we can all have a laugh?
    | Pete Fisher at Home: |
    Pete Fisher, Jan 2, 2011
  7. Catman
    Catman Guest
    Catman, Jan 2, 2011
  8. Catman
    Catman Guest
    17 seconds and on
    Catman, Jan 2, 2011
  9. Catman
    Simon Wilson Guest
    I bet JD Bridges wished that happened to him.
    Simon Wilson, Jan 2, 2011
  10. Catman
    Being pedantic, one could point out that the fan was turning too
    slowly to create much of a breeze anyway, so an ambient wind could
    cause the hair movement.
    Having said that, I've noticed that high-bypass-ratio turbo fans
    windmill backwards if there's enough wind from astern.
    Against that, the sound effect was that of an engine winding up, so it
    could be suggested that the engine was just starting, hence just
    spinning the fan forwards.
    The final argument must surely be that the breeze was supposed to be
    associated with the engine though, so overall: it's bollocks.
    Pip Luscher, Jan 2, 2011
  11. Catman
    Pete Fisher Guest
    http://biggles-software.com/software/757_tech/engines_and_apu/thrust_reverse.htm
  12. Catman
  13. Catman
    Pete Fisher Guest
    Well I'm certainly no expert, but some blurb on high-bpyass turbo fan
    engines suggested that they achieved the trick more discretely using
    doors in the bypass ducts.
    Is it possible to tell what type of engine it actually is from that
    footage anyway?
    Still this is UKRM so it would be a shame to let the matter pass without
    a bit of uninformed (certainly in my case) argument wouldn't it?
  14. Catman
    Simon Wilson Guest
    Yes, AIUI newer engines don't use those bloody great barn doors out the
    back. Eg as depicted here:
    http://en.wikipedia.org/wiki/File:Air_Canada_777.jpg
    heh
  15. Catman
    Paul - xxx Guest
    Cue Ivan ...
  16. Catman
    Paul - xxx Guest
    Being a tad more pedantic one could ask if .. "Well, as it's only a
    fucking advert, is the engine turning and their hair blowing even
    meant to be connected?"
    Maybe not, they might just have had their heads in the clouds ... ;)
  17. Catman
    Thomas Guest
    It's quite simple, really. It's an advert. The producer says, we need
    to show air blowing and the people looking at the engine, but make the
    wind blow their hair back, 'cause blowing it forward makes their hair
    look ugly. The people were shot on a soundstage, the engine is an
    animation added later. The producer doesn't GAF about reality.
    Thomas, Jan 3, 2011
  18. Catman
    Ben Guest
    The people at the ad agency did a media studies degree, not an
    avionics engineering one.
    Ben, Jan 3, 2011
  19. Catman
    Catman Guest
    Excellent :)
    Catman, Jan 3, 2011
  20. Catman
    Jérémy Guest
    There's just a light breeze blowing from behind the engine, turning the
    fan slowly and ruffling their hair. It's also turning the wind turbines
    in the background.
    BTW, did you notice the flying whale at the beginning. Do they really do
    that?
    Jérémy, Jan 3, 2011
