Optimate 2 problem
Discussion in 'UK Motorcycles' started by Fr Jack, Feb 10, 2008.
  1. Fr Jack
    Fr Jack Guest
    Erk!
    Battery's a bit flat, as in won't crank the engine fast enough to
    start it.
    Connected the Optimate.
    Green light for "on", but no other lights for battery condition.
    The battery isn't stuffed, just low...
    Is the optimate stuffed?
    Fr. Jack
    The Un-Civil Servant
    http://craggy-island.myminicity.com/
  2. Fr Jack
    Adie Guest
    try switching it off and on at the plug. occasionally happens to our.
    Adie
    keeper of the ukrm faq for my sins
    YZF-R1 : ZX9R E1 : GPz 750 turbo
    Adie, Feb 10, 2008
  3. Fr Jack
    steve Guest
    Check the voltage drop when trying to crank the engine. It should stay
    above 9.5 volts as an absolute minimum and preferably nearer 10 to 10.5
    volts. If it's not sealed and you have a hydrometer, check cell specific
    gravity as that will often show a "dead" cell.
    A battery with a weak cell may show OK under no load but fail to deliver
    the neccessary when cranking.
    The charger can be checked. If you charge, the battery voltage should
    rise quickly to 12 volts, then climb to 12.5 to 13 volts within an hour.
    Fully charged could give 15 to 16 volts for a short time after
    disconnection.
    A voltage of 13 volts soon after connection to a charger could indicate
    a stuffed cell due to the cell sulphation.
    Do all the cells bubble when the charger is connected?
    Steve
    steve, Feb 10, 2008
  4. Fr Jack
    Derek Turner Guest
    must run on windows then?
    Derek Turner, Feb 10, 2008
  5. Fr Jack
    crn Guest
    Modern battery charges can be a PITA because they have a "safety" feature
    and will not start unless connected to a battery which has a voltage
    over a set limit, usually about 9 volts.
    If the voltage has dropped below that then TOUGH - dig out an old
    charger or jumplead it to another battery to get the voltage up past
    the threshold.
    Safety cnuts ...muttermutter.
    crn, Feb 10, 2008
  6. Fr Jack
    Fr Jack Guest
    Did that several times over a half hour, but no go...
    Nipped to Aldi and grabbed their one... Merrily charging away!
    Fr. Jack
  7. Fr Jack
    Fr Jack Guest
    It's a Hawker - I've not run the bike for a couple of months - looks
    like the clock may have taken a bit out of it.
    The voltmeter showed 10v and dropped to about 7, when I hit the
    starter.
    Nipped to Aldi and got one of theirs - worked straight out of the box.
    Seems to be able to cope with very discharged batteries.
    Another recommendation for the pikey charger!
    Fr. Jack
  8. Fr Jack
    crn Guest
    Bad move, the fastest way to stuff a battery is to leave it run down.
    If you are not going to use the bike for more than a few weeks either
    disconnect the battery or leave it hooked up to a trickle charge.
    Almays make sure it is fully charged before storage.
    crn, Feb 10, 2008
  9. Fr Jack
    christofire Guest
    You could've borrowed mine...
    christofire, Feb 10, 2008
  10. Fr Jack
    Fr Jack Guest
    Didn't want to bother you, mate.
    You were really tired, when I left, so I decided not to disturb you.
    Ta, anyway!
    Fr. Jack
  11. Fr Jack
    Fr Jack Guest
    Yup.
    Need to get a solar trickle charger, cos there's no lecky in me shed
    and its a bit crap running an extension lead out the kitchen window
    and having to take it in when it's too cold or wet... or when I nip
    out.
    Fr. Jack
  12. Fr Jack
    Beav Guest
    Probably not, but they DO need a few minutes connected before they start
    giving out info. Leave it connected and go back in an hour or so.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 10, 2008
  13. Fr Jack
    Beav Guest
    Well it's not like he'll be needing it this side of Michaelmas Tuesday, is
    it?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 10, 2008
  14. Fr Jack
    Fr Jack Guest
    True, but the real reason is I didn't want to subject myself to the
    sight of him shuffling around in his kecks again!
    Fr. Jack
  15. Fr Jack
    Beav Guest
    Oh thanks. I'd ridden myself of that image just an hour ago.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 10, 2008
  16. Fr Jack used his keyboard to write :
    Have you checked the inline fuse?
    Harry Bloomfield, Feb 10, 2008
  17. Fr Jack
    Fr Jack Guest
    It appears to be fine, now.
    I just tried it and its working fine, seems the low volts theory was
    right.
    The Aldi charger works better with deep discharged batteries than an
    optimate 2.
    Fr. Jack
    Fr Jack, Feb 11, 2008
  18. Fr Jack
    Also, if you have the Optimate supplied fly lead permanently connected to
    the battery then check the terminals. They will corrode over time. I had to
    give mine a bit of a jiggle to get a good contact last week.
    wessie, Feb 12, 2008
  19. Fr Jack
    Beav Guest
    Shove some Vaseline in the socket and corrosion woes are a distant memory.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 14, 2008
  20. Fr Jack
    I got terrible confusion with the Circumcision thread for a moment
    Hog, Feb 14, 2008
