Optimate and inductance - beware
Discussion in 'UK Motorcycles' started by Paul Carmichael, Feb 24, 2007.
  1. Thought I'd share this.
    My last battery went in the bin after a short life of a matter of
    months. This was because the Optimate said it was charged but in fact it
    was flat as a shrove tuesday delicacy. I know, I should have suspected
    the charger. Assuming the battery died of being left on the bike for a
    long time, I decided that when not using the bike, it would be a good
    idea to leave it connected to the optimate (off the bike).
    Next thing, the Optimate starts telling me that the new battery isn't
    taking a charge (permanent dim, yellow light). I'm thinking, "oh no -
    another battery buggered".
    Those of you that have Optimate chargers will know that the cables -
    mains in and 12V out are very long. Well, mine were all twisted up
    together. I un-twisted them and hey presto. All seems well again. I
    haven't yet tested the battery - perhaps I'll attach it and go for a
    spin tomorrow.
    I can only assume that this is down to inductance betwen the cables? ie;
    the 220V input was infecting the 12V output.
    Am I talking out of my bottom?
    Paul.
    CBR1100XX SuperBlackbird (Buen mueble de patio)
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
  2. Paul Carmichael wrote
    Probably not. It all depends on how Optimate do their checking and this
    is something we simply don't know.
    It has been noted before the Optimate system does seem to behave rather
    oddly at times and quite a few reports have been posted here verifying
    this.
    As to what causes it, **** nose but in the death the best test of your
    battery is to connect it to the bike and use it.
    That said I use a very simple, very cheap, battery charger of my own
    design and construction[1] which will charge any battery capable of
    being charged enough to prove it is working in about 5 minutes. To say
    that what I do constitutes a gross mistreatment of the battery in
    question is an understatement but I don't get battery problems. Draw
    your own conclusions.
    Does Optimate have a "charge regardless" function? If so, use it.
    [1] A 10V Hi-amp transformer and a full wave rectifier pack and bugger
    all else. Crude, to say the least, but very effective.
    steve auvache, Feb 24, 2007
  3. Which is what all the traditional LA chargers used. I had an ancient
    Wilmot-Breedon 4A charger that would rescue and recharge just about
    anything with acid in it. Replaced by a Halfords jobbie of the same
    design philosophy which is almost unbeatable.
    Fairly raw and ripply DC that pisses in the sink is what LA plates want
    to see, not a smooth New-Charger characterless Direct Current that eats
    quiche, washes the dishes and doesn't wipe its knob on the curtains.
    Grimly Curmudgeon, Feb 24, 2007
  4. Paul Carmichael
    Molly Guest
    Actually you're not. I've had similar problems with the connectors.
    Molly, Feb 24, 2007
  5. Grimly Curmudgeon wrote
    Well yes, although mine is capable of short bursts of 50A which makes it
    useful for the larger batteries of the sort found on the Mongvan for
    example.
    Yes and no. Yer modern sintered plate battery things are supposed to be
    designed for a slightly gentler approach to charging but how this
    relates to what the alternator puts out I would not like to say. Other
    than, batteries are generally tougher than the Optimate sales literature
    would have us believe.
  6. ian field wrote
    A Cockcroft Walton Voltage Multiplier you mean? Unnecessarily over
    complicated bollox for those who know little or nothing but who wish to
    impress those who know even less. Have you never heard of KISS?
  7. ian field wrote
    Otherwise known as a diode pump, I believe.
    Thus turning it into a diode pump.
    Quite.
  8. Paul Carmichael
    Eiron Guest
    Pity you got the circuit wrong though. You add a couple of caps but you
    also need to reconnect the transformer.
    Just putting a big electrolytic capacitor across the output of a traditional
    battery charger will give over 20v with no load. Of course, once you
    connect it to a 12v battery the output drops to 13v or so.
    Eiron, Feb 24, 2007
  9. Paul Carmichael
    Eiron Guest
    Sorry, should have done more thinking before posting.
    But my circuit will give 20v at a lot more current than yours.
    How much voltage and current does a sulphated battery need?
    Eiron, Feb 24, 2007
  10. Paul Carmichael
    DR Guest
    Hey, I try hard to Rock & Roll All Night...
    DR, Feb 25, 2007
  11. ian field formulated the question :
    I don't think that advice will work with an Optimate, they use a switch
    mode system producing a perfectly smooth DC output.
    Harry Bloomfield, Feb 25, 2007
  12. Paul Carmichael explained on 24/02/2007 :
    More likely it will be a result of oxidation or corrosion on the
    connectors, preventing the charger seeing the battery voltage.
    This is the one thing I really dislike about the Optimate... I get a
    full set of 3 LED's lit whether it is connected to the battery or not,
    assuming the battery is fully charged anyway. It thus leaves you
    guessing as to whether it is connected properly or not. I wonder if a
    resistor connected across the Optimates output would pull its open
    circuit voltage down enough, to make the LED display a little more
    sensible?
  13. Harry Bloomfield wrote
    All a bit tenuous though innit?
    There is obviously a rather big flaw in the way Optimate does the
    checking and it seems to me they are looking at the battery as a current
    sink rather than a voltage source (if that makes sense) and any extra
    impedance in the circuit of the sort caused by corrosion or other poor
    contact buggers it completely.
    The fact that it is touted as The Ultimate Solution and folks come to
    rely upon it when it most demonstrably isn't is a good enough reason for
    me to dislike it.
    Which further reinforces my view that it is not the battery it is
    testing but it's own output.
    Only one way to find out really. How about substituting a resistor for
    the battery and see at what current things change?
    steve auvache, Feb 25, 2007
  14. Paul Carmichael
    mb Guest
    Which Optimate is that? My Optimate II doesn't do it.
    mb, Feb 25, 2007
  15. mb has brought this to us :
    I'm not sure which model it is. It is about 12 months old, but provided
    as a replacement for one which failed. All black plastic case and three
    LED's with opaque square plastic covers over the LED's.
    The LED's light up in an unpredictable way with mains, but no battery
    connected, but do make sense once the battery is connected. Trouble is
    that because they are so unpredictable that you can never be sure the
    battery is properly connected or the in-line fuse sound.
  16. Paul Carmichael
    DR Guest
    You should be aware that Optimate is in fact a brand name and trade
    mark, referring to a specific product. I've never seen a black one;
    my Optimate III is grey, with normal round LEDs - they certainly do
    not have square plastic covers. I believe that older designs are sold
    under other names, which may have black cases and other cosmetic
    differences.
    FWIW my Optimate functions perfectly, as far as I can tell. One LED
    if it's on and not connected, and two when it is connected, indicating
    the relevant charge status.
    DR, Feb 25, 2007
  17. DR pretended :
    What I have has now been renamed a 'Maximiser' - which explains some of
    the confusion.
    Mine is the one at the bottom of this page:-
    http://www.mandp.co.uk/productInfo.aspx?catRef=500070
  18. Paul Carmichael formulated on Sunday :
    Shocks from PC's, washing machines and similar high tech items will be
    due to the mains input filters. They are connected between L and E plus
    N and E. Some voltage can also be induced onto unearthed metalwork in
    close proximity to mains wiring.
  19. I was largely basing my assumption on recent experience with my house
    electrics. I live in a house built in franco's era ie; stuff wasn't
    available. There was no earth rod. All my stuff was plugged into
    extensions that were wired for earth. We kept getting electric shocks
    off the computer cases, washing machine etc. I put it to the test by
    simply plugging an extension lead into a earth-less socket and testing
    the earth core with my amazing Avometer. Sure enough, over a poxy 2
    metre length of extension, there was a lot of welly being induced
    (inducted?) into the earth wire. And I tried this with more than one lead.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Paul Carmichael, Feb 25, 2007
