Optimate Says "No"
Discussion in 'UK Motorcycles' started by Statto, Mar 19, 2009.
  1. Statto
    Statto Guest
    I had planned on using the Daytona this weekend, in what may be it's
    swansong before outing it; so given it has the factory fitted alarm
    that flattens the battery after a while, in a stunning bout of
    thinking ahead I decided to attach the Optimate for a couple of days.
    Except only the Power LED lights up. Switch the ignition on - nothing.
    Make sure the Optimate's OK by plumbing into the Ducati - yellow
    charge LED comes on, so it looks like the Daytona battery is destined
    for the tip.
    Hopefully the local bike shop to where I work will have a suitable
    replacement.
  2. Statto
    SD Guest
    I had a similar experience recently with the Wing.
    | ___ Salad Dodger
    _/_____\_ GL1500SEV/CB1300SA-9/CBX1000Z
    |_\_____/_| ..99843../..00057.../..32117.
    SD, Mar 19, 2009
  3. Statto
    I still need to get an MOT for the RGV but can't be arsed.
    ogden, Mar 19, 2009
  4. Statto
    A bit of hard pounding from a standard charger might shock it into life -
    worth trying first.
    platypus, Mar 19, 2009
  5. Statto
    zymurgy Guest
    Ditto the FJ, but it's just easier to back the Triumph out and hit the
    starter :)
    Paul.
    zymurgy, Mar 20, 2009
  6. Statto
    antonye Guest
    Same here for the 748, on both counts.
    It is on the Optimate though...
    antonye, Mar 20, 2009
  7. Statto
    I could actually be tempted to out the RGV and replace it with something
    a bit more suitable for cross-town commuting like a DR-Z400SM.
    But I know the next time I ride it I'll fall in love with it all over
    again.
    So, third bike it is...
    ogden, Mar 20, 2009
  8. Statto
    Adie Guest
    I took the R1 for MOT today and had to jump start it from Andy's van.
    I got them to replace the battery while I was there.
    Adie
    UKRM FAQ: http://www.ukrm.info/faq/
    YZF-R1 : ZX9R-E1 (outgoing 26th March) : GPz 750 turbo
    keeper of the FAQ for my sins
    Adie, Mar 20, 2009
  9. Statto
    Statto Guest
    Or not as the case may be. After 14 hours on a car charger still no
    signs of life. I tried jump starting using the car, but the bike would
    run with the start button held down, but would die once the start
    button was released. New battery time.
    Statto, Mar 23, 2009
