OT (a bit) Speed Trap Detectors
Discussion in 'UK Motorcycles' started by Nick Aird, Oct 13, 2003.
  1. Nick Aird
    Nick Aird Guest
    I am thinking about buying a radar speed trap detector, can anyone give any
    guidance?
    Thanks in advance
    Nick
  2. Nick Aird
    Use your eyes - the're much more reliable.
    Ace, Oct 13, 2003
  3. Nick Aird
    Robbo Guest
    any
    Good pair of glasses and a watchful eye on yer speedo.
    HAND
    Robbo
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Oct 13, 2003
  4. Nick Aird
    Robbo Guest
    any
    HEH !
    U woz thinkin wot I woz !
    Robbo
    BotaFOF #19
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Oct 13, 2003
  5. Nick Aird wrote
    The best ones for that sort of thing these days are generally over a
    litre.
    steve auvache, Oct 13, 2003
  6. Nick Aird
    Sean at work Guest
    Ride did a piece on them a couple of months ago. Get searching for a back
    issue.
    My sprogs ripped mine up, so can't do a praisee of it.
    Sean at work, Oct 13, 2003
  7. Nick Aird
    Oldbloke Guest
    I use a BEL980 in the car, it's not bad, but a bit of a pain in town as it
    picks up traffic lights and automatic doors.
    Oldbloke
    2000 Honda CB500
    BOTAFOT #140
    "He's like Robbo's chubby kid brother"
    Oldbloke, Oct 13, 2003
  8. Geodesy is good for fixed speed cameras, but not for mobile ones. I don't
    think the other types give enough warning when approaching a mobile speed
    trap, by the time its gone off and you've reacted, you'll have already had
    your speed recorded.
    Daniel the Manual, Oct 13, 2003
  9. Nick Aird
    Wik Guest
    This argument's a bit like the GPS one, innit?
    I mean, yes, the ol' Mk1 eyeball is still the best in the daytime,
    however, for instance, on an unlit road at night you want a bit of help.
    Likewise for the times you're in an unfamiliar area; good to be be
    forewarned, eh?
    Not all /mobile/ speedtraps will be good enough to park themselves on
    motorway overbridges and the like. There was one I happened across
    recently near Ongar; just around a blind bend on a NSL road. I'm sure he
    made a pretty packet for Essex Constabulary. Not from me, mind.
    They /do/ have their uses.
    Certainly worked for me on the M40 a year or so ago coming back from the
    NEC: 10pm-ish, unlit stretch of Warwickshire, Suze and I motoring along at
    a little over a ton. Detector goes off with "LASER!" warning; off gas,
    apply brakes, 68mph in an instant.
    "WTF was that for?" we wonder.
    30 seconds later, a copper on "perch" in unlit T5, about a mile away from
    the initial warning, hoves into view.
    Anyhoo, what I /really/ need is a "sneaking up behind in an unmarked car"
    detector.
    | Wik -UKRMHRC#10- 2000 ZX12R-A1 -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Oct 13, 2003
  10. Nick Aird
    Wik Guest
    I'll assume we're talking for the bike, here?
    For starters, very few of them are waterproof and only one /detector/ is
    marketed specifically for bike use, the Bel 966R, IIRC.
    Note I highlighted "detector"; that's 'cause some people don't know the
    difference between a device that actively seeks certain electromagnetic
    radiation (a detector, i.e. Snooper, Bel, Valentine) and a device which
    uses GPS and a look-up database to warn of known, fixed traps (Geodesy
    Morpheus, earlier Road Angel, Blue-I, etc.)
    Check these out, first (Google is your friend...) http://tinyurl.com/qrkb
    and then later, when I'd unearthed a clue or two:
    http://tinyurl.com/qrjo
    Don't buy a cheap shit £150 thing; they're wank. For bike-only use, /the/
    device to consider is the aforementioned Bel 966R; it's a very small,
    compact, simple head unit with a remote sensor pack mounted on the front
    of the bike. It also has a very large, very obvious LED repeater on a
    "gooseneck" arm which can be positioned so as to be good and obvious.
    http://www.ukspeedtraps.co.uk/bel966.htm
    *cough* entirely coincidental that they used a silver -12R for the test...
    Of the /other/ flavour of device (GPS based), the original Geodesy from
    Morpheous is probably the best bet for bike use:
    http://www.geodesygps.co.uk/index.htm
    They're cheaper to buy than a good detector, but there's a subscription
    required to keep them updated (modem download/upload of database info).
    The Geodesy has clear, bright LEDs that are visible even in quite strong
    sunlight. Not waterproof, but water resistant.
    I notice now they're doing a "bundle" which combines a GPS Geodesy and an
    ol' fashioned detector (of unspecified make) for a gnats under £600...
    Personally, I've currently got a Snooper S5 which is *the business* in the
    c*r, but is a pain in the arse on the bike as the warnings are primarily
    audio ones and there's no output for headsets on it.
    HTH.
    Wik, Oct 13, 2003
  11. Nick Aird
    kAnO Guest
    The Snooper S6 has an optional ear piece if memory serves.
    kAnO, Oct 13, 2003
  12. Nick Aird
    Dan White Guest
    <snip>
    Just as an aside, relevant as many of you come to these blessèd shores at
    regular intervals. Radar detectors are illegal in France, and could cost
    you 1,500 EUR (~£1000) in fines, rising to 3,500 EUR (~£2500) for
    subsequent offences.
    { snip }
    Not to mention the fact that French plod use a different band radar anyway
    IIRC...
    Dan White, Oct 13, 2003
  13. Nick Aird
    Wik Guest
    Does it? Fury muff. Mined ewe, it's a "hybrid" unit -- a GPS unit with a
    laser/radar detector supplied as a separate module -- hardly compact and
    has an LCD display. Not ideal for sprots-bike mounting I'd have thought...
    Wik, Oct 13, 2003
  14. Nick Aird
    kAnO Guest
    It tells you about the optional ear piece in the PDF manual here...
    http://www.snooper.co.uk/snooper-s6-r-gatso-and-radar-detector.htm
    ....although it doesn't go into much more detail than to "hear audible alerts". Been thinking about
    one of these for the car for a while. I'm yet to be convined they're very practical on a bike
    though.
    kAnO, Oct 13, 2003
  15. Nick Aird
    Tosspot Guest
    The human eye doesn't normally perceive electromagnetic radiation in that
    part of the spectrum [1], though.
    [1] 3x10E8 Hz, IIRC ...[/QUOTE]
    Sewerly about 5x10E14 for the average Gatso?
    Tosspot, Oct 14, 2003
  16. Nick Aird
    Tosspot Guest
    5x10E14 is bright yellow. Honestly, you should be ble to spot one :)
    Inneresting the Frogs use a different frequency though. I wonder how
    many detectors it would take to drive from England to Turkey?
  17. Nick Aird
    Dan White Guest
    le Mon, 13 Oct 2003 21:42:37 +0100, dans l'article
    I didn't know that.
    S'ok. It's not like anyone would slag you off for that... ;-)
    Dan White, Oct 14, 2003
  18. Nick Aird
    On Mon, 13 Oct 2003 19:20:24 +0100, Wik
    We call that a "mirror", Wik. You know, you look in it - and it
    reflects what is behind you, magically, to being right in front of
    your eyes ...
    Having thought about it a bit; travelling at the speeds I habitually
    do - which will be largely similar to yours, I expect (as fast as the
    road/traffic conditions will allow in reasonable safety) then an
    approaching car is uncommon except on Friday nights going North on the
    M1.
    If I spot a car closing, the little alarm bells always go off and I
    can't help but to lift off and hide in the traffic. 9 times out of
    10, the closer turns out to be a repmobile or the Home Sec in a hurry,
    and they whizz past in the outside lane and disappear. If the car
    appears to match my speed, we get legal in as subtle a manner as
    possible (this has included a little drag of handbrake or a sneaky
    downchange, on occasion ;-)) and then the fun starts.
    You've got to flush the bugger, haven't you? So you mentally check
    that tax, MoT and inswearance are up to date - and edge up the speed a
    bit. Fixing your head in the "straight-ahead" position, one eye
    _firmly_ on the mirror, squeeze the gas. Out a lane and pass the car
    in front, nip back in and assess the situation.
    If the suspect car moves out and back in too, keeping station, then
    the prickle of sweat starts down the ribs ...
    Happy Motoring.
    Pip, Oct 14, 2003
  19. That feeling. Almost nice. but nasty all at the same time. the sweet and
    sour of emotions perhaps. well said.
    Doesnotcompute, Oct 14, 2003
  20. Nick Aird
    It's rather nice to discover I'm not alone in this paranoid and bizarre
    behaviour
    Hog, Oct 14, 2003
