OT/Blog/FOAK: Paging the sundayroastisti
Discussion in 'UK Motorcycles' started by Gyp, Feb 8, 2009.
  1. Gyp
    Gyp Guest
    I was somewhat inspired by Jamie Oliver's pig cooking programme a couple
    of weeks ago, or more to the point I liked the look of the roast
    shoulder and bellies that he did.
    Anyway, I'm now the proud owner of a shoulder of pork. Except it's a
    different size, shape and preparation to the one that Oliver did. His
    was big flat and on the bone. Mines not so big, boned, rolled and in a
    stocking thing.
    I'm going to cook it slowly sat on a bed of mixed root veg, however does
    the panel think I should cook it as is in the stocking, or open it out
    and spread it out across the roasting dish?
    I'm still planning on the "stick it in on max hotness then turn it down
    low for 4-5 hours" rather than the 2 hours on 190 that the pack suggests.
    Gyp, Feb 8, 2009
  2. Gyp
    A typical Sunday at the Gyp household.
    Krusty
    '03 Tiger 955i
    '02 MV Senna (for sale) '96 Tiger (for sale)
    '79 Fantic Hiro 250 (for sale) '81 Corvette (for sale)
    Krusty, Feb 8, 2009
  3. Gyp
    Buzby Guest
    This is a firm favourite in the Buzby household.
    If I were doing it I'd leave it rolled up and in the stocking to keep
    the moistness in. I always cook a roast on a root veg base which I use
    specifically for the gravy - in this case I'd lob in a bit of cream and
    calvados. I expect JO's way will vary somewhat!
    Buzby, Feb 8, 2009
  4. Open it out flat - Doesn't look pretty but it'll cook more evenly and will
    be particularly scrummy.
    Cooking instructions on meat packs are for people with no clue. They usually
    say "Not suitable for microwave cooking" too, which proves my point.
    Mungo \Two Sheds\ Toadfoot, Feb 8, 2009
  5. Gyp
    Gyp Guest
    True
    Gyp, Feb 8, 2009
  6. Gyp
    Gyp Guest
    That one for flat, one for rolled. The UKRM ask the audience technique
    is coming up trumps as always :)
    Gyp, Feb 8, 2009
  7. Of course :eek:)
    It depends if you want big slices of meat or plenty of tasty, caramelised,
    crispy edges surrounding the lovely falling-apart sticky bits of meat which
    you can pretty much shred with two forks, like duck. Personally I use leg
    for impressive slices and flattened out shoulder or belly for more
    'mediterranean' style roasts using garlic, herbs, balsamic vinegar, olive
    oil etc.
    Shoulder generally falls apart when you try to slice a rolled joint anyway,
    especially if it's been cooked for hours. If it *hasn't* been cooked for
    hours it's not very nice, imo.
  8. Gyp
    Pete Fisher Guest
    How big is it and what do you call "max hotness" /"low". The Blessed
    Robert Carrier and Saint Delia both favour your approach, but talk about
    just 30 or 45 minutes to the pound after the initial searing.
    Jamie is a true disciple I see:
    http://www.channel4.com/food/recipes/chefs/jamie-oliver/bone-in-shoulder-
    roast-recipe_p_1.html
    Note that he does the initial searing sans veggies.
    Personally I would be concerned that it might go a bit dry spread out,
    if it ends up really thin, but perhaps the bed of veggies would prevent
    that.
    So in true UKRM spirit of furthering the interests of science - cut it
    in half and do both then report back.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 8, 2009
  9. Gyp
    Gyp Guest
    That's what I'm after.
    After due consideration, the joint has been de-stockinged, flattened out
    a bit, oiled, salted and placed on a bed of carrots and parsnip.
    Now all I have to do is cook it for 5 hours without drying it out
    Gyp, Feb 8, 2009
  10. Gyp
    Gyp Guest
    260/160. Only about 3lbs, so may not leave it in for as long as I was
    planning
    Too late. But it's inexpensive enough for me to experiment over the
    coming weeks.
    Gyp, Feb 8, 2009
  11. Gyp
    Gyp Guest
    Actually, contrary to the telly prog, he's got it in for a relatively
    short period. Hmmm.
    Oh well, we'll see :)
    Gyp, Feb 8, 2009
  12. Gyp
    Gyp Guest
    YHMMS
    Long story short, it was splendid. The meat just pulled apart. F tasty.
    Gyp, Feb 8, 2009
  13. Gyp
    Pete Fisher Guest
    I must try it, but details man, details - exactly how long at 160 to
    achieve such perfection?
    For Boxing Day at the 'chateau' we tried a pre-prepared pork joint from
    the Hyper-Casino, having done the big deal proper cooking bit the day
    before. It was rolled in a stocking like yours, but had been enhanced
    with Gruyere (IIRC or some similar cheese) and Bayonne ham. Sounds
    awful, but it worked. Crusty on the outside but moist on the inside.
  14. Gyp
    4-5 hours? Sod that.
    If I'm roasting pork I do it Hugh-style, 18 hours at about 120 degrees.
    Lush.
    ogden, Feb 8, 2009
  15. Gyp
    Gyp Guest
    Joint was 3 and a bit pounds. Bed of root veg, sliced into decent size
    chunks to fill the roasting dish and allow the meat to sit above the
    fluids. Veg and meat given a coating of oil with salt massaged into the rind
    Went in at 260, immediately down to 220 for 30 minutes, then down to
    about 170 for 3 hours.
    After the initial searing, I kept adding a little water to the juices as
    I went along to keep the whole thing moist. A little honey was added in
    a baste after about an hour an a half to keep Bear happy.
    At the end of the 3.5 hours, I let the meat rest for 15 mins while the
    gravy was made (little bit more water to the juice/veg mix, stir,
    reduce, done.
    Meat sliced/pulled apart and served in pile with crackling strips
    arranged, surrounded with the slightly caramelised root veg and roast
    potatoes. Brocolli and sprouts on the side and fresh apple sauce made
    with home-grown cider apples.
    Taste was exceptional, with the caramelised edges adding to the flavour.
    Texture was probably 8/10, and I think I'd try knocking it down to 160
    and leaving it 1/2 hour to an hour longer.
    Armadillo!
    Gyp, Feb 8, 2009
  16. Gyp
    Gyp Guest
    Really? I'm tempted, especially if I can do enough of it on the night rate.
    Gyp, Feb 8, 2009
  17. Gyp
    Pete Fisher Guest
    <Salivates>
    Thanks for that. We don't get the chance to do a proper Sunday roast
    very often these days, though, even in the winter. The lad is off to the
    climbing wall on most Sunday afternoons. We could feed him scraps on his
    return I suppose after we have pigged out, as the taxi of mum and dad
    rota would allow for alternative postprandial somnolence.
    If it's good enough for Darwin...
  18. Gyp
    http://www.pre.org/pork002.jpg
    Reduce for the size of the joint, do it in a slow cooker if you can
    because it keeps the moisture in - if you do it in the oven you'll be up
    several times during the night topping up the water bath.
    If you're doing a simple roast, don't bother with all the seasoning.
    ogden, Feb 8, 2009
  19. Gyp
    Snowleopard Guest
    8~O
    Snowleopard, Feb 8, 2009
  20. Gyp
    Gyp Guest
    The requested URL /pork002.jpg was not found on this server.
    So tasty the server ate it...
    Gyp, Feb 8, 2009
