OT : Boilers
Discussion in 'UK Motorcycles' started by fragmented, Nov 28, 2008.
  1. fragmented
    fragmented Guest
    Not the ones at the NEC, the central heating type, sorry.
    The boiler here is about 12 years old, noisy, inefficient (if I believe
    the hype about condensing boilers), I've fixed a few times and to be
    honest I don't believe its worth coaxing it along much longer.
    Its a 4 bed detached, 1 bath, 2 showers fed directly from the hot and
    cold supply, hot water tank in the airing cupboard, no cold water tank.
    The hot water tank I swear is plumbed in back to front as the incoming
    cold water dilutes the hot water immediately and you only get 1/2 a bath
    full, or one shower. Also if the boiler heats the tank up, 2 hours after
    the boilers switched off the hot water is luke warm. So that needs
    ripped out and replaced with another or a direct hot water supply.
    What would be the best type of boiler for me?
    Plain water boiler with a replacement hot water tank?
    Instant hot water / combi boiler?
    Condensing or some other sort?
    Will the one thats cheapest to run have some compromise like its crap at
    heating the hot water or something?
    Also is it worth getting it from British Gas? Will they chuck in a year
    or 5 free boiler maintenance and guarantee plan or suchlike?
    Actually the ideal for me would be finding someone who will fit what I
    tell them to fit, plumb in the gas and do the water plumbing and leave
    me to sort out the electrics.
  2. Sounds like a combi might be what you need, but the drawback is the lack
    of stored water supply in the event of mains loss. Also no hot water or
    heating if the gas /electric fails too.
    Personally, I'd stick with the existing system and get a modern boiler
    as a simple replacement, but that's just me.
    If it's a normal hot cylinder, there's no way it can be connected
    wrongly - there's only one inlet (bottom, side) and one outlet (top).
    Grimly Curmudgeon, Nov 28, 2008
  3. fragmented
    Pete Fisher Guest
    Possibly best to have a look here first:
    http://www.diydoctor.org.uk/projects/domestic_hot_water_systems.htm
    Depends. One factor can be location. In a similar house to yours I was
    advised not to for a condensing boiler because the flue is very close to
    a patio window, and there was no where else to move the boiler to except
    at vast expense. Even the more efficient conventional one I have now
    chucks out a fair amount of steam when the air temperature is low. A
    condenser would really fog up the large area of glass nearby.
    A cheap one may well have a crap fan. Ours got very noisy a few weeks
    ago. British Gas came and lubricated it and the problem was sorted, but
    apparently the bearings may die fairly soon. In which case they assure
    me they will replace it quickly for free.
    Mine is still under guarantee from British Gas. I also paid up front for
    5 years service at 'bulk by' rate, but total cost delayed for 12 months
    IIRC. I was happy with the overall deal. Particularly given the
    unforeseen installation problems which they had to address at no
    additional cost to their quote.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 28, 2008
  4. fragmented
    Eiron Guest
    So there's one way it can be connected wrongly.
    Eiron, Nov 28, 2008
  5. fragmented
    A.Lee Guest
    Just you in the house?
    A Combi would be ideal IMO.
    You only pay to heat the water you use, unlike a stored water system,
    where you heat up a full cylinder, then maybe do not use it.
    Changing a convential system to a combi would be quite a change, witha
    lot of work to change pipes, so 2 days work for 1 bloke, maybe 3.
    You have no choice now, either a condensing 'stored water' type, or a
    condensing combination boiler.
    Cheapest to run = either more effiecient or doesnt get so hot.
    Boilers are rated into A, B, and maybe some at C still. As from next
    year iirc, all have to be 'A' rated, most already are, some B rated are
    being sold off quite cheaply, B+Q are doing a B rated combi at £300 now.
    I fitted one a few weeks ago, and though it is a little noisy compared
    to our old one, it does the job well.
    British Gas have, probably, the worst reputaion for supplying and fixing
    boilers. Whether it is true or not, I dont know, but there rarely seems
    to be good reports of them.
    I know a bloke who'll do that, though he is just south of Leicester.
    dead good, tells it straight, and does the job right.
    I can give you his number if you cant get anyone local.
    Alan.
    A.Lee, Nov 28, 2008
  6. fragmented
    fragmented Guest
    'fragmented' wrote...>
    <snip>
    Another thing is that my radiators are an open system, header tank above
    the hot water tank that tops it up when it needs it.
    I see most modern boilers require pressurised systems. If I try to
    convert my system to pressurised am I likely to find about 150 leaks
    hiding under the floorboards? Can you get condensing boilers that work
    with open CH systems?
    I haven't actually seen a pressurised CH system that hasn't needed
    frequent attention because the system looses pressure, are they very
    problematic? (sisters, Jackies, current work, previous work)
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, fragmented
    Mine has needed topping up[1] once, just after it was fitted and has run
    for over a year without further attention.
    [1] i.e. turn a tap, wait a sec, turn it off again.
    Wicked Uncle Nigel, Nov 28, 2008
  8. fragmented
    fragmented Guest
    'Grimly Curmudgeon' wrote...>
    Only ever had one period without water, which was when I was replacing
    shower/bathroom fittings.
    This place is a "family home" (well, it would be if I wasn't here
    IYSWIM), and the hot water can't even fill one bath.
    No idea whats wrong with it, I suspected that they've taken the outlet
    from the bottom, so the cold water coming in just drops straight through
    the hot water cooling the whole lot down quickly.
    Hmm, there's a simple test I haven't done here isn't there? :)
    Thank.
  9. fragmented
    fragmented Guest
    'Pete Fisher' wrote...>
    Will do, thanks.
    Where it is now is as far from the conservatory as it can be, so I can't
    see (more) steam being a problem)
    Cheapest to run I meant, which most likely won't be the cheapest to buy.
    But I suppose if they're all "grade A" now (or soon will be) then
    running costs per KWh output should be roughly the same?
    Ta.
  10. Not by anyone with more than two brain cells.
  11. fragmented
    fragmented Guest
    'A.Lee' wrote...>
    Mostly just me. My nephew does turn up every morning for a shower and
    then dissapears off to work. (rents a room and never stays in it)
    S'wot I'm thinking.
    Can modern combis really deliver properly hot water at full flow mains
    pressure?
    I had a look at the Vallient specs and they quoted 10 mins to fill a
    bath with 35 deg C water? My cold tap can fill a bath in about 2mins so
    that doesn't sound like its anywhere near full mains pressure flow rate
    hot water.
    Also whats the flow rate for a typical shower? A proper shower, not one
    of those crap dribbly cheapo electric showers!
    I thought that would be the case, but with a £600 gas bill this year, I
    want to try to save some of it.
    (I should be looking at cuting down the lekky bill which is over twice
    as much)
    So cheapest to run will effectively mean less heat output and colder
    house?
    Ok, if they're all going to be 'A' rated I'll work it out on the heat
    output I need for the house and add 15% cause I'm nesh :)
    Heh, what I was thinking but always worth asking.
    Can you email it to me, reply-to email address is valid.
    Thanks.
  12. fragmented
    fragmented Guest
    'Wicked Uncle Nigel' wrote...>
    So thats a thumbs up for BG and pressurised systems, ta.
    When they fitted yours did they convert it from a non-pressurised system
    or rip it all out and start again?
  13. fragmented
    Pete Fisher Guest
    Condensers appear to be mandatory now in any case. I got my new boiler
    just in time it seems.
    Not necessarily though.
    Pass, but that sounds logical.
    See WUN's post. When they came to install mine they found the estimator
    hadn't allowed for some sheet flooring on the landing where they thought
    there would be boards (took me by surprise as well).
    They also found the calorifier in the hot water cylinder was leaking in
    to it. A valve had been fiddled with to compensate apparently. As they
    held the service contract for the previous four years they had to agree
    to replace the cylinder for no extra. That meant a new cylinder with a
    very efficient sprayed on insulation jacket. It also meant a very sweary
    installer who had to squeeze it in to a very tight built in cupboard off
    the bathroom. The whole job took a day longer than expected. I'm not so
    sure it would have been possible to get another contractor to stick to
    the estimate.
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, fragmented
    Pretty much started from scratch. The deal included new radiators
    throughout, since some of the existing ones were mis-sized, and none had
    thermostatic valves. They reused most of the existing pipework.
  15. It's not uncommon for older systems converted to pressurised to have
    leaks - the quantity varies from 'some' to 'lots', but usually of a
    small nature. Of course, if your 20 year old rads have weak corroded
    bottoms, expect that go suddenly from 'tiny' to 'massive' overnight -
    all over your carpets.
    You can get a straight replacement for your boiler that will work with
    your existing system and forego the pressurised option.
  16. fragmented
    SteveH Guest
    Our house is just a tad smaller than yours.... and we have a combi
    boiler.
    Hot water on demand, at mains pressure. Fills a bath no problem with
    steaming hot water and doesn't go cold if someone uses a tap elsewhere
    in the house.
    SteveH, Nov 28, 2008
  17. fragmented
    Ben Guest
    Yeah, run a hot tap and touch each pipe to see which is hot!
    Ben, Nov 28, 2008
  18. fragmented
    We fitted a new combi boiler just before the "must have a condensing
    boiler" regs came in. It's a Worcester 28SII and supplies hot water at a
    good rate. I picked the fitter by looking at the Worcester website. There
    was only one recommended fitter for our area and they gave me a reasonable
    quote compared to SWALEC and some others picked from yell.com. It's worked
    out very well. In 4 years I've seen the fitters 4 times: installation plus
    3 annual services.
    My fitter came to service our boiler a few days ago. Despite being a
    Worcester Bosch approved installer he says he would probably install
    Vaillant in his own place as their condensing boilers are the most
    reliable. They are expensive, apparently.
    You really need raden's view on this, to corroborate.
    Fine. Much better than the 7kW Redring shower we had in the last place. We
    just have a Mira mixing tap in the shower: one of those jobs that works
    like a joystick. There's a pressure equalising valve on the shower input
    which is very good at regulating flow if the washing machine does a rinse
    cycle when you are showering. One of these jobs:
    http://www.plumbworld.co.uk/pressure-equalising-valves-344-0000
    wessie, Nov 28, 2008
  19. fragmented
    fragmented Guest
    'SteveH' wrote...>
    What make and model please?
  20. fragmented
    SteveH Guest
    Big white thing with the 'Vaillant' brand on the front.
    Other than that, I have no idea.
Similar Threads
Loading...
