OT : Boilers
Discussion in 'UK Motorcycles' started by fragmented, Nov 28, 2008.
  1. fragmented
    fragmented Guest
    'Grimly Curmudgeon' wrote...>
    Heh.
    The boiler's cheap shite, the rads are cheap shite and the original
    thermostatic valves are mostly seized up.
    I replaced about half the valves a few years ago (where I got them from
    didn't have enough) but the rest still need doing.
    The size of the rads feels about right, althought I want an extra one
    plumbed into the conservatory.
    Thinking more about it, and from the first hand accounts of BG, I might
    just get them to come round and give me a quote.
    Had a look on their website and they say they'll give you £500 of
    "energy saving devices" free with every order, but don't say what the
    hell they are - solar powered dildos? 15 x energy saving kettles?
    Good to know, ta.
  2. fragmented
    fragmented Guest
    'Wicked Uncle Nigel' wrote...>
    If you don't mind me asking, how much did that lot cost you?
    Email me if you'd rather reply offline, reply-to is valid.
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    <nods>
    Customer of mine.
    Sound fellows, obviously.
    Wicked Uncle Nigel, Nov 28, 2008
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, fragmented
    I honestly can't remember. £3k-ish, I think.
  5. fragmented
    Nige Guest
    Barratt Mk1 16v of course ;)
    Nige, 'That's not my name'
    Range Rover Td6 Vogue
    BMW K1200S (off soon)
    Suzuki GSX-R1000 K3
    Focus ST3 (off soon)
    Audi A3 Cab
    BMW F800GS
    Nige, Nov 28, 2008
  6. fragmented
    Doki Guest
    All have to be condensing these days unless you have some very good excuse
    AFAIK. Worcester Bosch were the mutts a while ago...
    Doki, Nov 28, 2008
  7. You really need a minimum of 9L/min for a proper shower - most pumped
    ones will do that easily as will most mains supplies, but many cheapy
    electric showers will struggle to do 5 or 6L/min, especially when
    heating up mains cold water. A new 8.5kW electric shower will do better,
    and actually be quite acceptable but performance falls off as things get
    a bit clogged with chalky deposits in many areas. The heating element
    gets fubared and the only way to prevent it is feed the shower with
    softened water.
    Grimly Curmudgeon, Nov 29, 2008
  8. fragmented
    ****. And that included the boiler?
    Cost us about three times that when we had a new boiler fitted, plus
    some extra piping for the pool and a couple of new and one re-used
    radiator.
    Mine dew, the size of the thing is probably worth that much in metal
    alone. And I have to say it does an amazing job with minimum hassle.
    And costs us about half as much to run as the previous one. Probably
    saving us a couple of grand a year in fuel oil. Which is nice.
    Ace, Nov 29, 2008
  9. fragmented
    Tosspot Guest
    I'm a big fan of combination boilers, but that's personal and I'm no
    expert.
    Tosspot, Nov 29, 2008
  10. fragmented
    Derek Turner Guest
    On the principle of 'recommend what you have' I'd go for a condensing
    combi-boiler by Vaillant. They're not the cheapest but they are the
    mutt's nuts according to the trade. If your airing cupboard has an
    outside wall then that's often the best place to fit it. However, if you
    have a house full of teenage girls (I should be so lucky) you may find
    their hot water output inadequate. Ours was in a 2.5 bedroom semi with
    one bathroom. It took about 25 minutes to fill a bath but was fine for
    showers, sinks etc. It was dirt-cheap to run. I imagine a decent heating
    engineer would be able to recommend a model suitable for your needs.
    Derek Turner, Nov 29, 2008
  11. fragmented
    Adrian Guest
    We had a Vaillant combi when we moved into this place. Out the ark, it
    was - early/mid '80s, apparently. It got to the stage where it was
    running luke-warm at best, and breaking down roughly twice a year.
    Could we find _anybody_ locally to even give us a quote on replacing the
    boiler? Could we bollocks. So British Gas reamed us rotten on fitting a
    Worcester Bosch, about five or six years ago. It's been flawless, with
    nothing more than the annual service (booked for this Tuesday, as it
    happens)
    At least, it WAS running flawlessly until about five minutes ago when
    there was a loud scream from the (suddenly very cold) shower...
    Fuckbiscuits.
    Adrian, Nov 29, 2008
  12. fragmented
    **** me rigid! The guy I use fitted central heating to the place I did
    up this year for £1,200. That was a full new fit, 3 bed / 2 reception
    house, including supply of everything. OK that's mate's rates, but even
    so...
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Nov 29, 2008
  13. fragmented
    fragmented Guest
    'Scraggy' wrote...>
    Looks interesting, the 1.1KW electricity should run my house for most of
    the time, and contribute half of the electricity I use in the evening
    when I'm in.
    I wonder if Valliant are going to make one? (for something like a
    boiler, I'll go for a reliable make)
    My current boiler is a Prima Potterton 50L, and according the the blurb
    on the label its 80% efficient.
    fragmented, Nov 29, 2008
  14. fragmented
    fragmented Guest
    'Adrian' wrote...>
    Was that because they didn't want to do the work, preferring charging
    £15,000 or so to fit a shower, or there's no one around you?
    <chortle>
    The curse of UKRM strikes again!
    Good job the service is due.
  15. fragmented
    fragmented Guest
    [This followup was posted to uk.rec.motorcycles and a copy was sent to
    the cited author.]
    'Simon Gates' wrote...>
    Very helpful information, thanks Simon.
  16. fragmented
    Pete Fisher Guest
    I thought that was more a function of the boiler thermostat setting (as
    opposed to the radiator thermostats or a room thermostat?
    In any case, I can recommend a high tech programmable 'room' thermostat.
    When it gets really cold I like to keep the heating on to stop my 1924
    detached house from cooling down too much as it takes ages for the
    structure to heat up again.
    I didn't want a full daytime temperature all through the house though,
    even if the bedroom radiators could be controlled thermostatically. It
    sounds from what someone said that new systems have to have a separate
    control for sleeping floors/areas anyway.
    That wasn't the case when I had my new boiler so I went for a British
    Gas PT5 programmable thermostat in the hall. You can set three different
    temperatures for night, day and morning/evening. Those can be different
    depending on whether it is a weekday or weekend.
    So now I just leave the main controller on continuous for heating and
    timed for hot water. Occasionally I have to override the PT5 if staying
    up late or being at home during the day on a weekday, but it's easily
    done by the prod of a button.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 29, 2008
  17. fragmented
    fragmented Guest
    'Nige' wrote...>
    Built on a Golf floor plan?
  18. fragmented
    fragmented Guest
    'Scraggy' wrote...>
    http://en.wikipedia.org/wiki/MicroCHP
    Reading into it a lot more since they only produce electricity when you
    need heat or hot water they don't actually produce a lot of electricity.
    Still, since they get a VAT reduction of 10% (now), if any of the enery
    companies give a discount when you buy one though them they'll be worth
    looking into.
  19. fragmented
    fragmented Guest
    'Bear' wrote...>
    And the fuckwit boosts his already impressive fuckwitted reputation.
    2 years out of date and counting.
    Someone might want to tell Bore that Reagans out of the Whitehouse and
    the Cold War is over, he's probably missed that too.
  20. fragmented
    Adrian Guest
    Those that bothered to answer the phone or return a message were
    universally "Nah, don't do combis, mate"
    British Gas basic maintenance contract rocks. For not much more than a
    tenner a month, they were here within 2-3 hours, diagnosed a fucked fan
    almost immediately, and persuaded it up'n'kicking. He was away again
    within about 15min, with it working. It needs a new fan, which he's
    bringing when he does the service on Tuesday - the guy who came today got
    himself assigned to the service for consistency.
Similar Threads
Loading...
