OT : Boilers
Discussion in 'UK Motorcycles' started by fragmented, Nov 28, 2008.
  1. fragmented
    geoff Guest
    what boiler is it?
    type "sedbuk" into google, you should find the efficiency of your boiler
    boiler quality ain't what it used to be.
    If you think its going to cost you a couple of thousand to get it
    changed and then allow for another couple of hundred after a couple of
    years when the pcb dies on you
    parts are **** off expensive for most condensing boilers
    You have also chosen the wrong time of year to think about changing your
    boiler, fitters can quote what they like because they are so busy -
    better to wait until it gets warmer
    Are you getting confused between combi and condensing ?
    A combi heats both hot water and central heating - good for a small
    house, for yours I would expect a 28-35kW boiler to be adequate. What is
    important is the flow rate for hot water especially for a shower
    A common problem is that if someone flushes a toilet when someone else
    is having a shower, you can get a reduction in flow rate and even with a
    modulating gas valve, a change in water temperature
    Legally, (more or less) you HAVE to install a condensing boiler you have
    little choice
    cheapest to run is a bit of a non question, boiler efficiencies have to
    be high, tanks are lagged - not much leeway
    whatever Nigel says
    DO NOT GO NEAR BRITISH GAS
    I'll repeat
    As for how much to ask a plumber to do - so you understand CH electrics
    ? If not go to the uk.d-i-y FAQs which you can access via my website
    www.uk-diy.org
    which will redirect you
    Where are you ?
    I might be able to find a sympathetic fitter
    but, as I said earlier, this is the wrong time of year to be embarking
    on such a project
    BTW - did I mention
    geoff, Nov 29, 2008
    #41
  2. fragmented
    geoff Guest
    doesn't matter - unless you qualify for a non-condensing boiler, it's
    illegal to fit otherwise
    Fan bearing quality has **** all to do with the price of the boiler
    Now - this is typical of British Gas
    Fan bearings are lubricated with grease. Spraying them with WD40 or
    similar will give temporary reprieve in an emergency, but is not a
    solution. Once the bearings have gone, they are gone
    The manufacturers use shielded bearings, when I recondition them, I use
    sealed bearings, which are more expensive, but are more reliable and
    last longer
    So you have effectively paid for a new boiler and (whatever the
    installation problem they contractually had to address) all they did was
    came and sprayed a bit of WD40 at your fan bearings.
    In general, being happy with something you have never tested is a false
    happiness - so sayeth confucious or someone
    There are much better deals around. Ask your local authority who they
    use for their social housing
    geoff, Nov 29, 2008
    #42
  3. fragmented
    geoff Guest
    and how much over the odds did you pay for a BG installation ?
    Or didn't you get other quotes
    And what have they actually had to do ?
    Normally you are not someone who I would say STFU to, but in this case
    It's a bit like recommending and accountant or insurance company you
    haven't claimed from
    geoff, Nov 29, 2008
    #43
  4. fragmented
    geoff Guest
    Cheap end - Worcester
    more expensive Vaillant / Viesmann / various others
    Avoid Potterton / Baxi
    Don't go for less known manufacturers like Saunier Duval, Biasi,
    Ravenheat etc that might sound cheap but you might find difficult to get
    parts for in a hurry
    Ask in the uk.d-i-y newsgroup, there are some impartial and
    knowledgeable people in there. Take anything that Doctor Drivel says
    with a sack or two of salt - he's our pet troll, and fairly harmless as
    long as he takes his medication
    geoff, Nov 29, 2008
    #44
  5. fragmented
    geoff Guest
    I would hate to be the one who says "told you so" in a couple of years
    BG - don't go near them JFGI the number of people who have been ripped
    of by / had problems with them.
    Have you never watched watchdog or any other consumer program ?
    they are bad news
    You have little choice - pressurised system with a condensing boiler
    geoff, Nov 29, 2008
    #45
  6. fragmented
    Pete Fisher Guest
    Just as well I got my new one when I did then. As a matter of interest
    how do you qualify for a non-condensing boiler ?
    So using cheap suppliers is never an indicator of overall price on any
    manufactured item that uses some bought in components, or are boilers
    special?
    I was given the option of a possible instant fix, or them coming back
    with a new fan. The quick fix involved some lubricant, not sure what it
    was, but the fan is still functioning quietly after several weeks. They
    came out within a few hours of phoning as has been generally my
    experience of their service. It's due for an annual service before too
    long and they have agreed that the fan will be replaced then if it
    doesn't start getting noisy again before then. I've dealt with one or
    two noise problems involving fans so I'm not totally unfamiliar with how
    they behave when bearings are fubar.
    The installation problem was interesting. Agreed the flooring should
    have been spotted by the estimator. I hadn't paid for a new hot water
    cylinder.
    The boiler has been in for four years, and as I said up there it will be
    replaced free when convenient to me.
    They had the contract for the old boiler before and their service has
    been tested by me on more than one occasion.
    Define better. I suppose you mean cheaper. I work for a Local Authority,
    I suspect the deals they get are cheap because of negotiating a very
    large contract.
    Frag asked for some feedback on British Gas. I gave it. He can now
    interpret it as good as bad in the light of your comments.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 29, 2008
    #46
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, geoff
    Of course I got other quotes. One was suspiciously cheap, the others
    were within a few hundred of the BG one. None of them threw in new
    radiators throughout.
    I've had them service the whole system for some years now. I used to
    have an independent guy who did it, but he landed a big contract with a
    builder and lost interest. Oddly, he wrote to me recently saying that he
    hadn't heard from me for a while...
    The BG guys fixed the old system a couple of times. Once when the
    immersion heater went they came out the same day. They said they'd be
    back the next day as they didn't have the right size heater on board,
    but I pointed out that (at the time) we didn't have a separate circuit
    for the water heating, so the immersion was our only choice if the
    heating was off (it was summer). The guy went to Plumb Centre, got a
    heater, and fitted it the same day rather than see us without hot water.
    On another occasion the outlet from the hot water cylinder had chalked
    up. They diagnosed and fixed it (even though it strictly wasn't covered
    by the contract, chalking up isn't). No extra charge (but a drink for
    the bloke).
    Another time the shut-off valve on the water tank in the loft got noisy.
    I called them, they came out next day and replaced it. All part of the
    service.
    They have *never* failed to show up when they said they would, they have
    *never* not been on-site, with parts, by the next day when I've needed
    them.
    As you can see, I have. That's why I recommend them. When I was
    travelling a lot on business I needed cover that meant that Mrs WUN
    could pick the phone up and get a problem sorted. Plumbing, electrical,
    drains, whatever.
    That's what I pay for. That's what I get.
    Wicked Uncle Nigel, Nov 29, 2008
    #47
  8. fragmented
    fragmented Guest
    'geoff' wrote...>
    Potterton Prima 50F - those of the infamous dying PCB - hence its been
    fixed a couple of times by me.
    Simple failure - first was a dry joint, second was the same but on a
    high power lead/socket pin, arcing takes out the surrounding solder and
    a chunk of the PCB - half an hour with a soldering iron and some nice
    thick patching wire and it was up and working again.
    Hence why I'm finding out the good from the bad so I can avoid this.
    True, I might do that.
    The showers got a very good thermostatic control which will deal with
    that for me.
    <snip>
    Saying that without any URLs to proof or anything else holds about as
    much sway as anything Bore says, i.e. none.
    fragmented, Nov 29, 2008
    #48
  9. fragmented
    geoff Guest
    **** me -
    Lets do some sums
    decent gas boiler £700 - 800 (oil, somewhat more expensive)
    cost to BG with their buying power £500-600
    Lets be generous and say £400 for Rads, pipework and other bits - £1000
    Lets say 2 man days at £250 / day
    That comes to about £2000 in total
    which sounds about the top end of what most fitters would charge to
    install a system
    So having taken on a new install, they then sell you insurance cover at
    £120 / year on a system which they can be reasonably confident that it's
    unlikely to go wrong for three years, and can claim back on any failures
    for the first year anyway
    the money you could have saved would have easily paid for a new boiler.
    most problems (like replacing fans and pcbs) are fairly simple to fix
    hardly rocket science for rufty tufty bikers who can tie their own
    shoelaces
    geoff, Nov 29, 2008
    #49
  10. fragmented
    geoff Guest
    there is some kind of points system , you can prolly find it on the
    internet, which has to be filled out and signed by a competent person
    Not something I've been through
    That's not what I said
    What I am saying is that the bearings used by the fan motor
    manufacturers are no better on expensive boilers (e.g. vaillant) than on
    a cheap (e.g. Biasi) one
    Usually NMB 626ZZ
    So why have you had several problems ?
    Rather than define "better", I would prefer to cite the number of times
    they have been on Watchdog, the number of times someone comes into
    uk.d-i-y with a complaint and what I hear from the industry as a whole
    geoff, Nov 29, 2008
    #50
  11. fragmented
    geoff Guest
    Well, the only time I've used them as a "consumer" was when my business
    partner rang me from the states - could I sort out the problem with his
    CH
    I couldn't even get through on the first day and then they showed up,
    but not having part would be back in two days - they left his wife with
    a fan heater
    Your experience seems at odds with most other people who I've come
    across
    .... and their installation charges are prolly about 30-40% up on the
    industry average
    geoff, Nov 29, 2008
    #51
  12. fragmented
    Pete Fisher Guest
    Ah, I'll have a look at "Guide to the Condensing Boiler Installation
    Assessment Procedure for Dwellings" myself then. Forewarned is
    forearmed.
    All boiler makers use the same fan manufacturer then?
    Where did I say I have had several problems with the new boiler? This
    has been only the second. The first was a whistling noise from the
    electrickery somewhere. Fixed easily within hours of reporting it.
    The other tests of their service was on the old boiler. An ancient ideal
    sectional jobby. No idea if they originally installed it, but they fixed
    it a few times (igniter, thermocouple etc.)
    How many customers have they got? See my reply to WUN.
    #52
  13. fragmented
    geoff Guest
    At last - some one not wearing a "you saw me coming" T-shirt
    geoff, Nov 29, 2008
    #53
  14. fragmented
    geoff Guest
    look and then move on ...
    a decent thread on that subject in uk.d-i-y recently
    geoff, Nov 29, 2008
    #54
  15. fragmented
    geoff Guest
    In message <>, Pete Fisher
    just a bit more BG bashing ...
    The PT5 will just be a rebadged programmer from a manufacturer
    geoff, Nov 29, 2008
    #55
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, geoff
    <shrug>
    I really, honestly, couldn't give a **** who Frag buys his boiler from.
    I'm just saying what my experience with BG has been.
    Not in my case, but again, IDGAF.
    #56
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pete Fisher
    Oh, indeed.
    And I couldn't care less, so long as the service remains good. When it
    isn't, I'll stop dealing with them.
    #57
  18. fragmented
    geoff Guest
    There are a number of manufacturers - Fime, Smiths etc
    to take Smiths for example they buy motors from Micromotors [1] in
    Merthyr Tydfall where I buy them from - motors are built in China
    Fime are made in Italy, but they tend to go for the cheapest bearing
    manufacturer that they can get away with - usually NMB
    The bearings, with very few exceptions fit on a 6mm shaft and are
    standard across the industry
    [1] recently taken over by someone else
    you said one or two noise problems involving fans
    The problem is that people still see them as "The Gas Board" and trust
    them
    I'm saying that they are out for profit and not to be trusted - they are
    overpriced and their service is no better than can be got more cheaply
    elsewhere
    Heed my warning or don't, it's a free world, it's just that my ear is
    nearer to the ground than most people
    geoff, Nov 29, 2008
    #58
  19. fragmented
    geoff Guest
    why ?
    there is so much inertia in a CH system, you would hardly notice
    geoff, Nov 29, 2008
    #59
  20. fragmented
    geoff Guest
    £30 from me ... with 12 months warranty
    unfortunately, it takes a couple of years for problems to show up as
    being a problem. For example, the Worcester 24i was hailed as being a
    very reliable boiler - lots of LA authorities installed them
    5 years down the line I see a LOT of 24i pcbs coming in with faults on
    them
    geoff, Nov 29, 2008
    #60
Similar Threads
Loading...
